Old Mar 04, 2004, 07:06 AM
daryl is offline
Find More Posts by daryl
Wow!My plane flies!
daryl's Avatar
Sarawak,Malaysia
Joined Sep 2003
Cox 0.49 engine
Is the cox 0.49 engine throttle or non-throttle?
daryl is offline Find More Posts by daryl
Old Mar 04, 2004, 10:47 AM
Vince77 is offline
Find More Posts by Vince77
Registered Misuser
Vince77's Avatar
United States, CA, Tehachapi
Joined Jan 2004
Typicaly non-throttled. The ones without an intake in front of the cylinder are simple reed valve engins that are typicaly throttled, although poorly, by exhaust restriction. They also have a TeeDee line that have a throttled carb in front of the cylinder. It's a large metal block with the typical lever on one side and needle on the other.
Vince77 is offline Find More Posts by Vince77
Old Mar 04, 2004, 12:21 PM
Ledbetter is offline
Find More Posts by Ledbetter
Central California
Joined Aug 2003
Which is not to say that all Tee Dee engines are throttled. They will say so specifically if they are, or state that they are for R/C, not C/L.
Ledbetter is offline Find More Posts by Ledbetter
Old Mar 06, 2004, 12:06 AM
Lynn S is offline
Find More Posts by Lynn S
Bolivar, TN
Joined Feb 2003
The only Cox engines currently being made are non throttled. I have seen Cox TDs as small as the .010 that do very well with the exhaust throttle.
Lynn S is offline Find More Posts by Lynn S
Old Mar 06, 2004, 03:46 AM
daryl is offline
Wow!My plane flies!
daryl's Avatar
Sarawak,Malaysia
Joined Sep 2003
So how do we stop these engines?Do we use nitro fuel?
Old Mar 06, 2004, 01:07 PM
Lynn S is offline
Bolivar, TN
Joined Feb 2003
The engine runs until it is out of fuel, or you do something dumb like stick your hand in the prop.(I have done that)
After it stops you make a dead stick landing. You need "1/2 A fuel" for the cox engine. I use Byron's 1/2 A fuel. 1/2 A means .049-.061 size.
It is 25% nitro and 16% castor oil. I add more castor oil to make it 20%.
Old Mar 07, 2004, 04:46 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Originally posted by daryl
....Do we use nitro fuel?
To clarify....
You CAN run them on lower nitro fuel but they will typically run very poorly, unevenly and with low power. They don't really work well until you use 15% nitro and they really sing with the 25% suggested already. For sport flying or training where you don't mind a bit less power 15% is OK.
BMatthews is offline Find More Posts by BMatthews
Electric conversion of a Cox 0.49 Lazy Bee BackYardFlying Electric Plane Talk 7 Mar 28, 2014 08:30 PM
Question Cox 0.49 thrust info A.Kovala Engines 2 Mar 21, 2007 07:32 AM
cox 0.49 engine jermaine Aircraft - Fuel - Airplanes (FS/W) 1 Jan 17, 2003 03:37 PM
cox 0.49 engine jermaine Aircraft - Fuel - Airplanes (FS/W) 5 Jan 17, 2003 03:34 PM
FS - two Cox Teedee 0.49 motors Haldor Aircraft - Fuel - Airplanes (FS/W) 2 Sep 13, 2002 08:46 PM
