Old Dec 24, 2013, 07:54 AM
Mahadeesh is offline
Find More Posts by Mahadeesh
Joined Nov 2013
KK2.1 FC board Arming happens for left rudder instead of right Rudder
Hello All,
Arming is happening when left rudder is given, But actually as per the KK2.1 manual, arming should happen for right rudder.
I thought the rudder channel is reversed and tried to correct it using t6config and digital radio s.w. There i could see that rudder channel is not reversed, it is moving in proper direction.
Is there any setting in FC board to correct this problem ?
or else i should reverse the Tx channel using t6 config
Mahadeesh is offline Find More Posts by Mahadeesh
Old Dec 24, 2013, 02:34 PM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Is this the new board with the LCD?
Steveis is offline Find More Posts by Steveis
Old Dec 25, 2013, 11:48 PM
Joined Nov 2013
Yes. You are right.
https://www.hobbyking.com/hobbyking/...mel_644PA.html
Old Dec 26, 2013, 02:31 AM
Steveis is offline
AVR Dude
Joined Jul 2011
Look in the receiver test menu option. If you move the yaw right and the display says you are moving it left, you will have to reverse the yaw channel in your tx.
Discussion KK2 board will not arm unless calibrated every time obito94180 Multirotor Electronics 1 Mar 11, 2014 07:11 PM
Discussion kk2 board works when armed but quits Hastethemoment Scratchbuilt Multirotors 0 Nov 23, 2013 11:26 PM
Sold KK2 FC control board with Delrin case Papajeff Aircraft - Electric - Multirotor (FS/W) 5 Oct 21, 2013 08:46 PM
Discussion right rudder causing left wing drop markhodges78 F3A Pattern 8 Oct 05, 2013 04:06 PM
Help! Have to arm KK Quadcopter with left rudder, not right --backwards fly_right Multirotor Talk 8 Jan 19, 2012 07:54 PM
