Old Mar 03, 2004, 12:09 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
The Alpha Corsair... by Pilot44 V2
It's time for a part 2, and this is it.
Part 1 can be found here:
http://www.rcgroups.com/forums/showt...88#post1633588
Carry on
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Mar 03, 2004, 12:21 AM
the Swamp Fox is offline
Find More Posts by the Swamp Fox
the Swamp Fox's Avatar
Wadmalaw Island ,SC
Joined Dec 2003
Thanks Martin and Pilot44 (Jim ) for starting this mayhem !
20,000+ views on mkI !
My Corsair should hit 100+ flights tomorrow. Only repair; A blob of epoxy on the elevator where my mom grabbed it ,fresh out the box.
I've had at least 5 combos in the F4U-1
great little machine... my "everyday" plane
--sf
the Swamp Fox is offline Find More Posts by the Swamp Fox
Old Mar 03, 2004, 12:25 AM
JDMstuff is offline
Find More Posts by JDMstuff
JDMstuff's Avatar
Torrance, CA
Joined May 2003
Just chiming in to this thread to keep up to date.
JDMstuff is offline Find More Posts by JDMstuff
Old Mar 03, 2004, 12:44 AM
Trikster is offline
Find More Posts by Trikster
Zoom, zoom...
Trikster's Avatar
Roseville, CA (Sacramento area)
Joined May 2003
For those "in-the-know" on the Corsair, how does this sound for a setup?
MP 25/25
TP 2s1p Thunder Power
Phoenix 10
Prop (suggestions)
2 x HS-55
Trikster is offline Find More Posts by Trikster
Old Mar 03, 2004, 01:55 AM
Wadmalaw Island ,SC
Joined Dec 2003
sounds solid !
what's the capacity of that TP pack ?
I'm unfamilair with the CC 10 I use 25's and a Jes 18
general all around favorite prop for this combo apc 9x6 sf
You'll be light and quick !
Good luck ! Ya flown 'er yet ?
-sf
Old Mar 03, 2004, 09:24 AM
sarge is offline
Find More Posts by sarge
sarge's Avatar
Fayetteville, NC
Joined Dec 2002
I've done most of my 30 or so flights with the Corsair on TP 2s 1320, 25/25-26, JES 18, and a APC 9x6E. I really can't think of anything I'd change about my set-up, I think it's perfect for this plane and the way I fly.
sarge is offline Find More Posts by sarge
Old Mar 03, 2004, 10:17 AM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Fox
I have an AXI 2208 on the way for mine. My backup plan is the PJS 550 -- plan to use 1200 Etechs (2 or 3) or maybe 1500 Kokams. Do you have some advice for balancing these birds. How far forward did you go with the batteries and your AXI?
Also what is a nice power combination--I am not sure I need 140 watts--thinking that 75 or so should be ok. Am I off with that number?
Pat Daily
Pat Daily is offline Find More Posts by Pat Daily
Old Mar 03, 2004, 11:16 AM
No Step is offline
Find More Posts by No Step
My hangar is,... "almost" full
No Step's Avatar
United States, WA, Marysville
Joined May 2003
Well, I flew my stock 350, 8 cell 720 setup yesterday against a friend with GWS with a Himax brushless. He kicked my A$$!. I guess it's time to step up to a 25/25 and 2s lipos. I was happy as long as I was flying alone, but to have a GWS Corsair fly past me was humiliating. Who says GWS are nice little cheap models when you stick a $120 worth of motor and esc in them,... well, two can play that game Captain. Meet you over the firing range Sir, this is war! Watch your six. I'm coming!
Friends, don't let friends, fly GWS
Fred G.
No Step is offline Find More Posts by No Step
Old Mar 03, 2004, 11:37 AM
sarge is offline
sarge's Avatar
Fayetteville, NC
Joined Dec 2002
Don't know if you can touch a Himax equiped GWS stock, but you can do a bit better than a GWS350 (I assume thats the one you meant) just by going with a speed 300 and a 2s 1320 TP. Of course, you'll never be satisfied until you go with the 25/25. I know others have had problems with 3s on the 25/25, but I have had good luck (so far). Of course, it's so damn fast I usually chicken out and back out of the throttle! If you are buying new batts anyway, try the Tanic 2s 1500. Full throttle in my P-47 for almost the whole flight, and the batt was barely warm to the touch.
Old Mar 03, 2004, 12:37 PM
JDMstuff is offline
JDMstuff's Avatar
Torrance, CA
Joined May 2003
Of course you can. Just install a Himaxx in a GWS box and you'll be able to give him a run for his money.
Old Mar 03, 2004, 12:39 PM
No Step is offline
No Step's Avatar
Joined May 2003
I thought a GWS 350 was "better" than a Graupner Speed 300? Thanks for the battery tips.
Fred G.
Old Mar 03, 2004, 01:08 PM
bigjake is offline
Find More Posts by bigjake
Tri-City Airport Municipal, Tennesse, United States
Joined Oct 2003
What would be better/hotter than a GWS 350. I'm looking to upgrade this motor if possible. What about a speed 400?
bigjake is offline Find More Posts by bigjake
Old Mar 03, 2004, 02:04 PM
Wadmalaw Island ,SC
Joined Dec 2003
Pat,
I'm very unscientific when it comes to balancing,
I just put 'er on my fingers,at the designated balace points under the wing...Then make sure she noses down just a tad..Then I fly.Adjust if necessary.Then make a mark on he batt tray when I like the way she flies. I'm unfamiliar with your motor,but if your numbers check out and you keep 'er light you'll be fine...any of ALFA's recommended set-ups work great as well.
Bigjake ,
I've never tried a 400 ..don't see why not..
SF
Old Mar 03, 2004, 08:39 PM
Pat Daily's Avatar
Joined Mar 2001
SF
Got an AXI 2208/26 today with the mounting bracket and am thinking about trying that for a starter. Can you post of pix of your motor mount with the AXI? Did your motor stick out far enough that you had to cut a larger hole in the cowling's dummy motor?
Pat
Old Mar 03, 2004, 09:48 PM
sarge is offline
sarge's Avatar
Fayetteville, NC
Joined Dec 2002
Blaze, I can only post my experience, as I don't know how to even use motocalc. I swaped a GWS350 in my Corsair after I burned up the second speed 300, and while I was waiting on the MPjet 25/25-26 to get here. On my Corsair, with 2s 1200 Etecs, the speed 300 was noticably faster. I didn't try any other GB or prop combinations, so it is certainly possible that a GWS 350 can be made faster than a speed 300. I've only had one opportunity to fly with someone that had a GWS Corsair. His was stock, and mine was also (if you accept Speed 300 as stock). He was a much better pilot than I am, and he knew how to use the rudder, so HE flew better than I was capable of. The plane was a no-contest, however. The Alfa was faster, slower, floatier, bigger looping. Probably an unfair comparison, though, as the GWS Corsair weighs a lot more than the Alfa. I really think that the best combo for the Alfa is a Mpjet 25/25-26 (maybe the 25/35) on 3s 1500 Tanics. For as long as the motor lasts, I doubt you'll have any more problems with your friends GWS Corsair. And, of course, your's looks so much better!
F-4U Corsair by GWS Herb Parkflyers 316 Apr 14, 2004 02:58 PM
Oh, Boy, Looks like Alpha Corsair is on the way to me Pilot44 Parkflyers 0 Dec 16, 2003 06:01 PM
Alpha Corsair, when...????. hurry .....Please Pilot44 Parkflyers 2 Nov 26, 2003 01:56 PM
Corsair...... by e-flightline w/ vids Splash Parkflyers 9 Sep 17, 2003 11:57 AM
Corsair by S&B Models - Building Hints Randy G Foamies (Kits) 6 Sep 28, 2001 07:16 PM
