This thread is privately moderated by Homebrewer, who may elect to delete unwanted replies.
Old Mar 02, 2004, 11:12 AM
Homebrewer is offline
Find More Posts by Homebrewer
Joined Sep 2003
Mini-HowTo
How to set/tune your engine
Too often, I see newcomers to our hobby ask online how many turns do I set my needle valves, or I messed up the factory setting, how do I setup my low end needle so I can start my engine? Here are some great tips to make you an expert engine tuner.
How to setup the needles so you can get your engine started:
Start by opening the high end needle about 4 turns from fully closed. This is just a starting point to ensure the high end needle valve isn't restricting fuel to the carb so you can adjust the low end needle setting.
The low end is easily set to a good starting point with the following procedure:
Close low end needle valve completely.
Install a clean piece of fuel tubing into carb fitting, make sure it is long enough for you to blow into it with your mouth.
Open carb to 1/5 open from closed position
Blow into fuel tubing while slowly opening up the low end needle valve. Stop turning low needle valve when you first feel air blowing into carb from your mouth or hear the sound of air blowing into carb. The flow should be restrictive and very small. We only want a small amount of fuel to flow (air to flow) at 1/5 throttle opening. This low end needle setting will get your engine running and may require further adjustment. THis is just a ball park setting.
Now close high end needle valve and open carb to full throttle. Blow in fuel tubing and simulataneously open high end needle until you have FREE FLOW of air into carb. You should not experience as much resistance to airpressure as you did on the low end. Your needle valve should be open between 2-5 turns (it all depends on the carb folks).
This procedure gurantees you don't have a blocked carb or closed needle settings for low and high. This will get you in the ballpark which then will require you to fine tune your low end and high end for best performance--highly recommend the pinch test .
Pinch test procedure:
First start engine this way:
Prime engine by opening up throttle to full and blocking exhaust with finger. With blocked exhaust, rotate engine until fuel just enter's the carb-watch fuel line to see fuel displacing the air in the fuel line.
Remember the following rules about needles:
1. Low end needle affects the mixture below 1/2 throttle for most engines. Use it to adjust the idle and the transition from idle to full throtttle.
2. High end needle affects mixture above 1/2 throttle. Adjust it so engine is running 300-400 rpm shy of max lean rpm at wide open throttle.
Reduce throttle from full to about 1/5 throttle opening. Apply glow ignitor and rotate engine (hopefully w/ starter) counterclockwise (for 99% of all engines out there) until engine starts. When engine starts, move throttle to 1/2 throttle and then remove glow driver.
If engine won't start, try more throttle until it does. If engine will only start above 1/2 throttle, it means your initial low end needle setting was too lean. Richen it about an 1/8th of a turn until the engine starts at a low throttle (1/5 throttle) setting.
If engine will not advance to 1/2 throttle w/ glow driver is on then leave at 1/5 throttle with glow driver until engine is warmed up-about 2 minutes should do the trick.
Advance throttle again to 1/2 throttle slowly. If engine dies then your low end needle is probabably too lean. Richen by 1/10 increments.
Once you can get your engine running at 1/2 throttle then its time to remove the glow driver/ignitor. With ignitor removed, advance throttle to full throttle. Chances are your engine will be too rich and may even quit. If so, briefly pinch and release fuel line as you advance to full throttle to verify the mixture is too rich. If it is too rich, then in small increments lean it out until it will run at full throttle without quitting. This does not mean the high end mixture needle is set. This is just a starting point to ensure your engine is running at wide open throttle (WOT) so you can make the proper adjustments.
With engine running at full throttle, slowly and carefully lean the high end needle valve until the engine is spinning at its max rpm. This can easily be determined by sound alone-no tach needed. This is where engine is producing most power but the mixture setting will cause the engine to run too hot and overheat. So, as a safety feature, always richen the mixture about 300 rpm shy of max lean rpm. Verify this by briefly pinching and releasing the fuel line to the carb. If the pinch test causes the engine to speed up and back down, then you have correctly set your high end needle setting. If engine doesn't speed up much or dies then you are still to lean and need to riche the mixture slightly until it passes the pinch test.
You are almost there. With high end needle setting set about 300 rpm rich of max lean rpm, recheck idle and transition. Let engine idle for 30-60 seconds and then snap throttle to WOT. If engine hestitates in the transition, fine tune mixture so that the transition is snappy and idle is reliable. I personally like a lean idle mixture so I can idle for long periods without fuel pooling up in the crankcase which causes stumbles when transitioning to full throtttle. You can also use the pinch test when the engine is idleing. Pinch and hold fuel line with engine at a fast idle. Engine should speed up and die about 4 seconds. If it takes longer, your low end needle is too rich, if it takes less time or if your engine dies instantly, you are to lean and need to richen your low end needle.
Once low end needle is set, you will probably never have to adjust it again. However, your high end needle should be checked before every flight by doing the pinch test at WOT to verify the mixture is slightly rich. This 5 second test and adjustment, if necessary, will gurantee you a reliablie engine that will last a long time. Our carbs do not adjust for changes in temperature, humidity, barometric pressure, etc... and a small change of 5 degrees in temp can cause a properly tuned carb to be out of tune and possibly too lean (or too rich depending on whether it gets hot or cold outside).
Hope this essay helps the newcomers to our hobby and prevents them from becoming one of the set it and forget it crowds that do not benefit from optimum tuning for the best engine performance and longevity out of an engine.
Homebrewer is offline Find More Posts by Homebrewer
Old Mar 29, 2004, 08:05 PM
firstimer is offline
Find More Posts by firstimer
VT
Joined Mar 2004
this is just what i was going to ask!! thanks guys!! also being my first motor(gms .47)i ran one tank of fuel(omega 10%) and noticed some oil comming out of the exhust. is this normal? if so, how much should i see? when i removed it from its test bench and tipped it up some more oil was dripping from the exhust. now is this normal? ANY INFO WILL BE HELPFUL!!!!!!!!!
firstimer is offline Find More Posts by firstimer
Old Mar 30, 2004, 10:13 AM
ghee-grose is offline
Find More Posts by ghee-grose
Honey, I got more planes!
ghee-grose's Avatar
USA, AL, Athens
Joined Jun 2003
I'm a newby to this glow stuff, but I'm sure that some oil coming out of the exhaust (dripping) is normal. Especially when idleing for a while. I think the flow of exhaust coming out is too slow to blow the oil out, so it pools in the exhaust pipe. So when you pick the plane up and the pipe points down you have a spill of oil that pours out.
Like I said.... I "think" this is normal... the Pro guys might chime in and agree/disagree. Just trying to help.
ghee-grose is offline Find More Posts by ghee-grose
Old Mar 30, 2004, 12:32 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Oil in the exhaust is normal and necessary for long life for a 2-stroke engine.
DaveSawers is offline Find More Posts by DaveSawers
Old Apr 26, 2004, 11:35 PM
pbailjr is offline
Find More Posts by pbailjr
Joined Apr 2004
An oily, sloppy 4-stroke, or is it perfectly normal?
I am a beginner with a new OS 51 4-stroke in my Kadet Senior. I ran a half tank of gas through the motor last week and noticed there was alot of oil coming out of the exhaust. Is this normal? I thought 4-strokes were supposed to run cleaner than 2-strokes.
To start the motor, the directions say to close the needle valve, then open it about 2 - 2.5 turns. Did this, then cranked the motor w/o glow power, then cranked with glow power and eventually got the motor running. Removed the glow starter, then turned the needle valve to a little less than one turn. Expected alot less oilyness out of the exhaust at this leaner setting but it was still spewing more than I thought it should. Is this normal? Is there a way to get it to run cleaner? I'm sort of an anal-retentive neat freak.
pbailjr is offline Find More Posts by pbailjr
Old Apr 27, 2004, 03:05 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Sorry, some oil from the exhaust is necessary for a 4-stroke too. It's the way the lubrication system works. If all the oil was being burnt you'd be in real trouble. It does get better after they are correctly run in but it will never go away.
If you're really a serious "neat freak" you might have to go electric .
Steve
steve lewin is offline Find More Posts by steve lewin
How do you prime your engine? globemaster3c17 Engines 26 Jun 13, 2009 08:10 PM
How to Set Your Headspeed and Blade Pitch Properly bobandris Electric Heli Talk 0 Jul 15, 2004 07:13 PM
How do you set up your flap and aileron with Eclipse? Magna Electric Sailplanes 7 Jan 20, 2004 04:21 PM
How did you set up your Electro Pulsar? Ron Williams Electric Sailplanes 4 Oct 11, 2002 11:26 AM
