Old Mar 02, 2004, 01:39 AM
dakotaman20 is offline
Find More Posts by dakotaman20
Joined Jan 2004
Can someone please help me out
Well I purchased a Turbo Hawk a while back and now im ready to put the kit together. I am very intrested in using LIPO batteries instead of the the regular batteries that I have been using for years. I have no clue where the best place to purchase these batteries and charger from? If somoene could get me started in the right direction that would be great. The type of motor that came with this plane is a type 400 motor with a ducted fan unit. I also purchased a pico reciever to cut down on weight but I have no transmitter to run with it. Does anyone know what transmitters work with pico recievers??? ONe more question ----> What type of esc should I get. I have no clue about amps and volts whne applying it to this. All help is appreciate thanks.
dakotaman20 is offline Find More Posts by dakotaman20
Old Mar 02, 2004, 04:48 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Try
www.aircraft-world.com
and
www.cheapbatterypacks.com
for a start. Usd both, reliable and cost effective both.
Speed 400 is generally in the 10A region, which is pushing e-tech 1200' too hard, but is just about acceptable for Irate 1100's I am not familiar wih the model layout, so more than that I can't say. Make sure that whatever packs youuse will do 10-12A tho, and will actually fti in the model. Lipo cels are bot cylinders that are large and very thin. Read up everything on safety aspects too and chargers.
Any transmitter with the right shift will work with a pico receiver if on the correct channel. However small receivers are almost all comprmised in performance in someway, so be cereful what you use and where you fly. You may get more interference than you would normally expect.
Old Mar 02, 2004, 06:42 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
If you have no clue about amps and volts, and no experience with Li-poly, it would be helpful for you to read the sticky entitled Ultimate Guide to Lithium Polymer Batteries at the top of the Batteries and Chargers forum. Li-poly cells are more susceptible to damage than NiCd or NiMH, and require special care and treatment to avoid starting fires. They can be relatively safe when used properly, but first must be thoroughly understood.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Mar 02, 2004, 07:49 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
You may have problems obtaining the correct cg with LiPo cells as they are much lighter. If the design of your plane does not allow moving the batteries forward a good distance from where they are now located, it could be a problem requiring adding nose weight to get the cg correct. That's assuming they have the batteries in a position other than on the cg.
The Turbo Hawk uses a 10 cell 5/4AAA pack which weighs 5+ oz. A 3 cell IRate 1100 Lipo weighs about 2.5oz. What you can do is build the plane and then use fishing sinkers in place of the batteries to find out if you have cg problems,
hoppy
hoppy is offline Find More Posts by hoppy
Old Mar 02, 2004, 01:24 PM
Joined Jan 2004
Well I took a look at http://www.aircraft-world.com/ and there are two chargers available for LIthium batteries. Theres the
http://www.aircraft-world.com/shopexd.asp?id=454
and
Old Mar 02, 2004, 01:34 PM
Joined Jan 2004
Well I took a look at http://www.aircraft-world.com and there are two chargers available for LIthium batteries. There is the
and
http://www.aircraft-world.com/shopexd.asp?id=453
I dunno WHich one I would need if I went with a 3 cel LIPO battery pack. When purchasing a LIthium battery pack how do I know hweither to choose one that is 250mAh 700mAh or higher??? Usually how long it generally takes to charge a LIPO battery pack??
For a speed 400 motor, would this http://www.aircraft-world.com/shopexd.asp?id=1991 Jeti Micro ESC running 12 to 15 amps work for me or do I need less or more???
Once again all help is appreciated.
Old Mar 02, 2004, 04:19 PM
Norman Adlam is online now
Find More Posts by Norman Adlam
Official Old Git!
Hampshire, UK
Joined Sep 2000
Hi,
Again, the advice to read the sticky is paramount!
You need to understand that batteries are charged in multiples of their capacity e.g. a battery that has a 700ma hr capacity will be charged at '1C' when it is charge at 700ma, or '2C' when it is charged at 1400ma.
Different batteries of different types can be charged at varying 'C' ratings e.g. Ni-Cd (typically) can be charged at 3C - 4C. Li-Po are (currently) charged at 1C.
At 1C a battery with take 1hr ('coz the battery capacity is specified as xxx ma per hr e.g. 700ma battery actually mean 700ma for 1 hr), 2C = 30mins etc.
Clear as mud?
Cheers,
Norman Adlam is online now Find More Posts by Norman Adlam
Could someone please help me out? gws addict Batteries and Chargers 2 Feb 21, 2005 09:17 PM
Can someone please help me with this?? epc2 Power Systems 0 Dec 27, 2004 06:32 PM
Alert can someone please help me setup my Heli-Max gyro? crx_ef8 Electric Heli Talk 0 Nov 25, 2003 07:58 PM
Gyro ttrouble please can someone please help me??? zetex Micro Helis 5 Sep 15, 2003 09:51 PM
Help!! Can someone please tell me how to hook up a twin in paralell? Joe Elston Power Systems 6 Oct 22, 2001 06:37 PM
