Espritmodel.com Heli Air
Old Dec 13, 2001, 11:49 PM
ultramega super star
stealthy's Avatar
Tucson,AZ 365 days of Sunshine
Joined Sep 2000
How many turns on a speed 400 motor
I read sometime back that the speed 400 7.2v had 45 turns and the 6v had 35 with 28gauge wire I bought some speed 400 @15-20v 9000 Rpms for 60 cents a piece for experimenting on rewinding them myself, but at 28guage wire and 35 turns, the motors on a gunther prop would only pull 3-4amps with moderate rpms, 30 turn @4-6amps with higher rpms, but not high enoungh.I couldn't fit more then 35 turns of wire with the 28guage, I was using 8cell CP-2400 Sanyo's, Does anyone know how many turns there should be. I've tried 24 gauge wire and could only get 16 turns in, and amps where at 20 and to much rpm for the gunther prop.
I know the motors can be bought fairly cheap and ready to fly, but at .60 and .03 of wire per motor,it's worth a try.
stealthy is offline Find More Posts by stealthy
Old Dec 14, 2001, 09:13 AM
London UK
Joined Sep 2001
400 info
Check out this link. I hope it helps.
http://www.microhydros.com/400_motor_complete_info.htm
Neil
Neil McGrath is offline Find More Posts by Neil McGrath
Old Dec 14, 2001, 09:44 AM
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
Generally speaking:
Thicker wire=more effiencient
Fewer windings= greater amp draw and higher amps that motor is most efficient.
Since you can't get more windings of the theoretically better 24 ga wire on, try using fewer and fewer windings of the 28 ga till your amps are where you want them.
It should be interesting to see if you can get improvements this way.
It should be possible to exactly place your amp draw right where you want it for a given prop and battery.
Your differing amp draw with nominally the same windings has me wondering if your wire has a different resistance than what the motors come with stock.
I'd compare your total resistance to a known good 6v 400 and see if your even close.
Its too bad you could'nt squeeze in enough windings of the 24 ga as you might have had a real gain that way.
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Dec 14, 2001, 10:25 AM
Ithaca, NY USA
Joined Oct 2000
Here are a couple of resources for rewinding motors. The first is a set of instructions (directed at slot car motors), the second is info about speed 400 type motors.
http://www.ncphobbies.com/rewind.html
http://www3.sympatico.ca/rwoolley/5.htm#section29
I tried rewinding a speed 400 using the suggested 28 turns of #24 wire, for use with 6 cell packs. I didn't glue the wire in place at first, and after a short time some of the coils moved and got scraped against the magnets.
Bob Chiang is offline Find More Posts by Bob Chiang
Old Dec 14, 2001, 12:46 PM
stealthy's Avatar
Joined Sep 2000
Thanks for the input and links. The other problem is get the wire as tight as the stock motors, Having to wrap wire 35 turns X 5 really starts to hurt the hands and everything around you starts to distract you from remembering the last number of turns you were counting.
The other problem is the solder staying on at high rpms, I'll try some different solder. I'll have to build a mini Spotwelder when I find the best number of turns needed.
Would a 5 post comm. have any difference compared to a 3 post, This is one reason I can't fit enough 24 gauge, but it must have some effect having more wire. Better efficiency, cooler running motor?
Jim
Old Dec 14, 2001, 11:34 PM
stealthy's Avatar
Joined Sep 2000
I decide to pull apart a Promaxx 400 7.2v and count the turns and to my suprise, only 40 turns on 26 gauge, unlike the Mabuchi 400 7.2 at 45 turns with 26gauge from what I've read, although I haven't torn one apart, Because I don't have any Tired out yet.
Jim
Discussion battery recommendation on speed 400 motor kogibankole Electric Plane Talk 8 Apr 06, 2006 12:00 AM
Suppression on a speed 400 motor Jonh Electric Plane Talk 1 Jun 19, 2005 05:40 AM
How Many turns on a 22.7 mm stator? bz1mcr Power Systems 6 Mar 15, 2005 09:14 AM
Questions and suggestions on a speed 400 motor mjse Parkflyers 12 May 04, 2002 03:41 PM
How do I time my speed 400 motor? rockdean Foamies (Kits) 8 Mar 12, 2002 09:14 AM
