Go Back   RC Groups > Aircraft - Electric - Airplanes > Electric Plane Talk
Old Aug 02, 2001, 09:24 PM   #1
Clayton's Avatar
What is a good sport plane for an Astro 050 brushless?
I have an astro brushless 050 that i was going to use on a plane but I think that I am going to use the manufacture recommended motor instead. And as I am always preparing for the future (and turning the future into the present as fast as I can) I want to plan for a good sport plane that I would get vertical performance from.
What are your thoughts?
Clayton is offline Find More Posts by Clayton   Reply With Quote
Old Aug 02, 2001, 10:08 PM   #2
Senior Member
Paul Penney's Avatar
What batteries do you want to use?
What cell count do you want?
What amount of thrust does the o5 put out on your favorite setup??
I would reccomend the House of balsa p-51 mustang, and if the 05 has more then 48 oz of thrust, your laughing <- like this!!!
Paul Penney is offline Find More Posts by Paul Penney   Reply With Quote
Old Aug 02, 2001, 10:41 PM   #3
Clayton's Avatar
Ok, here it is on 10 x2400 mah with a 13x6 APC electric prop it puts out 6,700 rpm with 31amps at 340 watts.
I'd love to get the Estrellita by Icare but I don't think this is the right motor.
But I am open to coversions.
Old Aug 02, 2001, 11:21 PM   #4
Senior Member
WOW!!! Mine has only 100 pounds and it does 60 foot loops (05 cobalt). IT is a gas conversion adn you do have to replace almost everything in the way of wood.... awsome
Buddly6
Old Aug 02, 2001, 11:37 PM   #5
Clayton's Avatar
how much does it wiegh?
Is this a .40 size?
Old Aug 03, 2001, 01:44 AM   #6
Senior Member
auw with 10 1700 nims is 48 oz
Old Aug 03, 2001, 01:53 AM   #7
Ed Waldrep's Avatar
Instead of the House of Balsa P-51, consider the Herr Engineering P-51, it's got laser cut parts. The House of Balsa kit has a few solid blocks to carve away, so the Herr may end up lighter. Also the Herr has a leading edge extension so it looks a bit more like a real Mustang.
Ed Waldrep is offline Find More Posts by Ed Waldrep   Reply With Quote
Old Aug 03, 2001, 03:43 PM   #8
H2OFLY
There may be significant size difference between the Herr kit, and the other.
I flew my brushless 05 in my MEC Zero, with only 8 cells, and it is a Wonderful flyer...very scale; easy to handlaunch; and with just a little time invested in the finish it took a prize in a Scale contest - even without landing gear!
And the "kit" is all foam, it is the Kyosho tough-skin kit that MEC resold in their box.
Out of production, but still some around. I know Tammies Hobbies had one yesterday - call 503-644-4535 (just a mile from me.
Terry
temacc is offline Find More Posts by temacc   Reply With Quote
What pattern plane for an Astro 010 ? compuatic Parkflyers 9 Sep 17, 2004 09:57 AM
What to use an Astro 050 brushless in? mlehman Sport Planes 4 Dec 27, 2003 01:43 PM
Good fun plane for an IPS E drive motor isaac-bees Parkflyers 1 Jan 20, 2003 10:07 PM
Plane for an Astro 010? TheAddler Parkflyers 12 Jun 28, 2002 12:03 PM
What is the best plane for an Astro 010 DIRECT drive? Clayton Parkflyers 2 Jan 23, 2002 05:30 PM
Bored? Want to fight?
Join the RCGroups clan!
