Old Dec 09, 2013, 08:53 PM
MrWhhaaaaat is offline
Find More Posts by MrWhhaaaaat
MrWhhaaaaat's Avatar
Joined Jun 2012
Help!
5.8ghz rx and tx batteries?
I have decided to get a 5.8ghz 25mw video transmitter (http://www.immersionrc.com/product-d...fpv_product=11 )
and a 5.8ghz video receiver (http://www.hobbyking.com/hobbyking/s...er_Cables.html) for FPV.
What type of batteries will work best for the transmitter and reicever? I am wondering because I do not want to take any chances on messing up the tx and rx.
Any information would be appreciated.
Also I am going to use a small sony camera (http://www.hobbyking.com/hobbyking/s...era_NTSC_.html),
circular polarized antennas (http://www.hobbyking.com/hobbyking/s...a_Set_SMA.html),
and am just going to use an easycap to see the video through my laptop.
MrWhhaaaaat is offline Find More Posts by MrWhhaaaaat
Old Dec 09, 2013, 11:42 PM
joop1987 is offline
Find More Posts by joop1987
United States, NJ, Trenton
Joined Sep 2006
Don't mix the Immersion VTX with Boscam receiver. It won't work good. Picture will be very distorted. The antennas' you want also are for RP-SMA and don't work on Immersion VTX's.
Immersion VTX's use the black colored spironet antannas (SMA).
http://www.hobbyking.com/hobbyking/s...a_V2_SMA_.html
Boscam VTX's use the gray colored spironet antannas (RP-SMA).
http://www.hobbyking.com/hobbyking/s...2_RP_SMA_.html
If you want Boscam VTX's, the TS352 and TS353 are favorites. The TS832 seems to be over rated on the output power, so avoid it for now. The RC832 receiver seems to just as good as the old RC305.
The 600mW immersion VTX is excellent mated to the Uno receiver with the Nexwave RF receiver chip.
joop1987 is offline Find More Posts by joop1987
Old Dec 10, 2013, 09:42 AM
Wrice4 is offline
Find More Posts by Wrice4
Blacked out 350z - Texas
Wrice4's Avatar
Joined Nov 2012
The product description should tell you what type of batteries can be used with each different vtx.
Wrice4 is offline Find More Posts by Wrice4
Old Dec 10, 2013, 07:27 PM
Joined Jun 2012
So if I used the Uno reciever with a 600mw or 25mw immersion Tx would the battery be the same for both transmitters or do different power inputs of the frequency require different batteries?
Old Dec 10, 2013, 08:34 PM
joop1987 is offline
Joined Sep 2006
You can use any 3S or 4S lipo. Most run it off the same battery that's powering the multi-rotor or plane. The 600mW will take a little more current so you'll get a couple seconds less flight time. I'd skip the 25mW and go 600mW.
Old Dec 10, 2013, 08:47 PM
panaceabeachbum is offline
Find More Posts by panaceabeachbum
Joined Jun 2013
I use a seperate 950 mah 2s to power the 600mw immersion transmitter, HK Osd and RMRC 420 line camera, gives me a solid 45+ minutes of clean video
panaceabeachbum is offline Find More Posts by panaceabeachbum
Old Dec 11, 2013, 08:39 PM
Joined Jun 2012
OK thank you everyone
Sold Boscam 200mw 5.8GHz tx/rx combo with Cloverleaf and Skew Planar Wheel antennas cyber_06_wolf FPV Equipment (FS/W) 3 Dec 03, 2013 01:20 PM
Sold FPV equipment: 5.8GHz video TX, 5.8GHz video RX and Bluebeam antennas jaywatay FPV Equipment (FS/W) 1 Oct 16, 2013 11:46 AM
Sold FPV set - Mondo Stinger 5.8 TX & Nano 5.8GHz Modular RX mike80 FPV Equipment (FS/W) 0 Sep 24, 2013 04:05 AM
Sold Haier 7" LCD.....Fatshark 5.8ghz RX module.....Immersion RC 600mw 5.8ghz TX crd FPV Equipment (FS/W) 7 Jul 24, 2012 10:42 AM
