Old Mar 01, 2004, 02:59 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Post your Century Heli conversion info here
Trying to see what works for everyone. I have done 3 and made may kits for you guys doing these conversions.
I have heard the Mega 22/45/3 does very well with 16 cells.
These are what I have done so far;
1) Hawk 3 SE with Aveox 1412/4 on 16 and 20 cells. Flew very well on 20 cells and OK on 16 (needed higher gearing)
2) Hawk Sport with High Torque 12turn and 16 cells. Needs more cells, KV is to low.
3) Raven CCPM 50 with Tango 45-6 and Joker 25t pinion. 2x4s4p 2000 lipo (unflown for radio programming only)
Fred Bronk is offline Find More Posts by Fred Bronk
Old Mar 01, 2004, 03:45 PM
JimmyW is offline
Find More Posts by JimmyW
Columbus Golden, Mississippi, United States
Joined Oct 2003
I have only done one.
Predator Max Actro 32-4, Schultz 40.70, 12s3p tanicbatteries, 11t penion, 93 tooth main. Needs a little work on the gear ratio.
Jimmy
JimmyW is offline Find More Posts by JimmyW
Old Mar 02, 2004, 09:52 AM
RCheroske is offline
Find More Posts by RCheroske
T-ride!, Co @ 9545' ASL
Joined Jan 2003
I've got a Hawk Sport with a Mega 22/45/3 as well. With a 23t pinion gear. But I've barely flown mine. I'm still dialing in the set-up.
What I want to hear is what pinion gear you guys are using. That's the one variable that I keep seeing that's all over the place.
RCheroske is offline Find More Posts by RCheroske
Old Mar 02, 2004, 05:34 PM
jfruge is offline
Find More Posts by jfruge
RC Nut!
jfruge's Avatar
Madera, California, United States
Joined Oct 2001
Raven 50
Raven 50 CCPM (on hand)
Tango 45-8 20T pinion (on hand)
TP 2 X 4S3P NextGen cells (on order)
CC HV ESC (soon to me on order)
Hitec Digi's on the CCPM (on hand)
Gyro 401 and its servo. (on hand)
Eagle Tree Data logger. (on hand)
I cant wait to get this think going
John Fruge
jfruge is offline Find More Posts by jfruge
Old Mar 04, 2004, 07:04 PM
lbs444 is offline
Find More Posts by lbs444
SE Texas
Joined Mar 2003
I have a Hawk Sport with Phasor 45/3 and Jeti 40-3p opto esc.
Ultimate BEC with 40mm cooling fan on motor.
I use both speed up gears for 4 cycle set-up and 24t pinion with 16 - GP 3300 cells. Head rpm is around 1700 to 1800 (tach broke)
I'm using 515mm FG semi sym blades from my ECO16 and get 7+ min flights.
The motor is mounted with the shaft pointing down with Fred's motor mount and cells are in the center of the frame under the motor and are not visible from the side. (no pics yet). It flies very crisp for first 5.5 to 6 min and still stable at 7.5 min but I always stop at 7 min.
My century Gyro is junk but it's ok til I can get a Good one.
Seems to have fair power for pull-outs but could use more.
I like the Hawk Sport better than the ECO16 and have not flown the 16 in a few months. The Hawk Sport is a much better machine in construction and flying characteristics than the ECO16.
May go to 20 cells later but as of now the Hawk is very dependable and has no quirks, wobbles, vibrations or any strange things going on so I can just charge and fly.
I have over 400 flights on the Hawk Sport and very pleased.
The gears were noisy until around 50 to 60 flights and began to quieten.
Happy "Hawk Sport" Camper!!!
lbs444 is offline Find More Posts by lbs444
Old Mar 05, 2004, 01:25 PM
wilsonjc81 is offline
Find More Posts by wilsonjc81
Joined Jan 2004
It Works!!
Hawk, Bell 47
600mm Blades
Mega 22/45/3, 1000KV
23t pinion
20 gp3300
phoenix 60
UBEC
Batteries:
I found the GP3300 really respond to a 5a charge, 6a would be the better! But it really starts to wear the cells. Then you have to monitor temps closer. I was only charging at 4.5a. But 5a makes a noticable difference!!
Performance:
Good power, good temps, great headspeed, and no bogging 5deg hover 9deg high. Flys way better than the 20t I had on there.
Trivia!!
And for piece of mind...... Hacker vs Mega..... The Hacker 15xl is a better motor in design, but from a performance point they are very much the same!!!!
James
wilsonjc81 is offline Find More Posts by wilsonjc81
Old Mar 05, 2004, 09:35 PM
Xnaron is offline
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
Hawk Sport
Mega 22/45/3
pinions 20T - not happy with performance... trying a 23T this weekend
20cells gp3300 (soon to go lipo)
phoenix 60
ultimate BEC
carbon fiber main blades, tail blades, tail fins, and boom supports
CCPM upgrade
With the 20T pinion I had on it I found it to be very lethargic. I am trying the 23T tomorrow and will post results.
Brendin
Xnaron is offline Find More Posts by Xnaron
Old Mar 08, 2004, 08:17 AM
Joined Jan 2003
So James, Did you really like the 600mm blades? Did you have a chance to compare them to a stock Hawk 550 blade? What brand blades are they? And how much does your Bell 47 weight?
Old Mar 08, 2004, 10:08 AM
Joined Jan 2004
Blades make a new heli!!
I noticed a big change on my Bell! With 550's I was running 7.5deg to hover. With 600's Im running 5deg. The blades are the century wood blades for 50 size helicopters. They cost $23. The Bell weighs in just under 9lbs total.
If your lighter the 550's should be fine, thats what I run on my other hawk. But that 23t pinion is where its at right now on the 20 cell setups that's making the big difference.
james
Old Mar 08, 2004, 04:25 PM
Joined Jan 2003
Is there enough room on a Hawk Sport to run 600s without hitting the tail rotor?
Old Mar 08, 2004, 04:34 PM
Joined Jan 2004
Yes!!
Still even have room!!
James
UAV Pilot USA
Old Mar 08, 2004, 11:42 PM
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Guys, lets keep it to setups please.
Feel free to start a new thread or use PM for questions
FB
Old Mar 14, 2004, 08:04 PM
Joined Jan 2004
Hawk II
hacker b50 11xl 1435kv
hacker 77-3p 'opto'
13t pinion 19.5:1
24 2000 nimh cells
550mm blades mabey 560mm (weight dependent)
Looks mean on moto calc better than the mega on 23t.
James
Old Mar 15, 2004, 03:04 PM
Brill 1 is offline
Find More Posts by Brill 1
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Schweizer
Century Schweizer 300
Mega 22/54/3
25T pinion
Caste Creations Phoenix 60
16-3300mah
UBEC
Everything else stock.
8lbs RTF weight and 7 plus minutes of flight time.
Love it!
Brian
Brill 1 is offline Find More Posts by Brill 1
Old Mar 15, 2004, 03:30 PM
buzzsaw 46 is offline
Find More Posts by buzzsaw 46
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Re: Hawk II
hacker 77-3p 'opto'
13t pinion 19.5:1
24 2000 nimh cells
James
James where can one find a 13t pinion that will work on the Century helis. Last night I was searching for the gear pitch and found three listed one said Mod 1.0 the seond said mod 0.5 and the third said mod 0.7 so which one is correct??
buzzsaw 46 is offline Find More Posts by buzzsaw 46
Alert Post Your Micro Heli Records Here! Minimole Micro Helis 44 Aug 22, 2005 06:36 PM
Alert Post Your Micro Heli Pics Here banshee_dude Micro Helis 33 Jun 30, 2004 09:22 AM
Post your best planes list over here someone special Parkflyers 15 Dec 30, 2002 12:52 AM
Yippee! post your micro heli! t_predator90 Micro Helis 0 Oct 07, 2002 06:59 AM
Post your ideas for The E Zone here jbourke Site Chat 68 May 17, 2002 09:54 AM
