HobbyKing Track Star 1/10 Chassis Set-up System
Dial-in your 1/10-scale on- or off-road chassis!
Improve your vehicles handling with the Track Star 1/10 Chassis Set-up System!
When racing, having the chassis precisely setup for the track will make all the difference when the competition is fierce. The Track Star 1/10-scale Chassis Set-up System is the tool you need to properly tune the chassis. This set-up system works with on- and off-road vehicles equipped with 4mm axles. You can simultaneously check caster, camber and toe at all four corners of your vehicle. The components are made of CNC-machined aluminum and are ball bearing supported for optimal accuracy. Judging these adjustments by eye is not accurate enough and once you start using a set-up system like this, you will find that your vehicle has more consistent handling because you can check the settings before each outing.
KEY FEATURES
  • Simultaneously check Caster, Camber, and Toe-in for the entire chassis
  • Precision CNC-machined aluminum parts with anodized crinkle finish
  • Laser etched degree marks
  • Laser cut acrylic Toe/Steering plate
  • Ball bearing supported
  • For 1/10-scale on- and off-road chassis with 4mm axles
  • Zipper enclosed carrying case
ITEM NO. DESCRIPTION PRICE
9171000281-0 Track Star 1/10 Chassis Set-up System$52.80
Visit the site for more info on products fromóHOBBYKING!
There are no posts
Discussion whts your favorite DLG battery/ power system set up? elkski Hand Launch 22 Dec 07, 2013 03:01 AM
Question help wilh power set up for Hobbyking BAE Hawk 90mm ryang22 Electric Ducted Fan Jet Talk 3 Dec 04, 2013 05:22 PM
Discussion hobbyking speed set up scrub monkey High Performance 12 Nov 26, 2013 07:33 PM
Sold Airtronics 10-G Set-up ScottCondon Aircraft - Sailplanes (FS/W) 3 Nov 22, 2013 06:12 PM
Discussion Set up system for 1/10 off road mav1970 Off-road Cars 6 Dec 03, 2009 10:35 PM
