Learn How to Solder From a Legend
Do you shy away from soldering? Do you wonder if you are doing it right? Lean from the master!
Learn to solder like a pro from a pro - Mr. LA Johnston.
My second airplane was a Zagi wing. This was my first electric and required soldering. I needed some parts so I loaded up my bird and took a trip to Hobby Lobby. I laid my Zagi on the display case and was looking at the extremely cool nickel metal batteries that were the hot ticket of the day. An older gentleman in glasses walked up behind the counter and pickup up my Zagi. He made a close inspection of the wiring, looked disgusted and then said to me, "Who the hell taught you how to solder?!"
I wasn't sure how to respond. I figured all I needed was a soldering iron and some solder. The man said, "Well the phones are down anyway, come back here and I'll teach you how to make a decent solder joint." I followed him through the isles of parts that I had memorized from the Hobby Lobby catalog, we passed through shipping and finally we arrived at his work bench.
I found out later this was LA Johnston. He was the lead tech for Hobby Lobby International. He has been building models for over 70 years, he attended the first AMA Nationals in 1945, and worked in the full scale aircraft industry designing ground support equipment for planes like the B-2 Bomber and the F-16.
LA had me solder everything on the Zagi until it met with his approval and sent me on my way. As I was leaving I thought, "I would like to work here one day" and I did. LA was a great friend to me in my early RC career. One other thing - the work bench that he taught me how to solder on is now the desk I work from everyday. Life is funny.
I was reminded of this story when I stumbled on this video tutorial on how to solder from LA himself. Now you can learn from the master that taught me so many years ago.
Part 1- Learn to Solder with Hobby-Lobby and L.A. Johnston (6 min 7 sec)
Part 2 -Learn to Solder with Hobby-Lobby and L.A. Johnston (5 min 43 sec)
Old Dec 05, 2013, 03:34 PM
Taurus Flyer is offline
Find More Posts by Taurus Flyer
I bail out, anywhere, anytime
Taurus Flyer's Avatar
The Netherlands, OV, Almelo
Joined Nov 2010
Jim
Old School don't need a Master, only have to smile!
Taurus Flyer
Taurus Flyer is offline Find More Posts by Taurus Flyer
Old Dec 05, 2013, 03:39 PM
Meatball is offline
Find More Posts by Meatball
Meatball's Avatar
United States, AZ, Chino Valley
Joined Feb 2005
Great 2 Videos
I passed these videos on to my club members and students. We are never too old to learn!!
Randy
Meatball is offline Find More Posts by Meatball
Old Dec 05, 2013, 05:19 PM
jhazz138 is offline
Find More Posts by jhazz138
"Do not touch the trim!"
jhazz138's Avatar
United States, IA, Cedar Rapids
Joined Nov 2013
Very good clear info. He contradicted a lot of stuff I've read and I bet he's rite. Thnx for the info!
jhazz138 is offline Find More Posts by jhazz138
Old Dec 05, 2013, 09:46 PM
slam555 is online now
Find More Posts by slam555
United States, MO, Stockton
Joined Oct 2013
old school
great videos, haven't had to solder things in years but now changing some of my planes to electric, I'll definately be soldering more
slam555 is online now Find More Posts by slam555
Old Dec 06, 2013, 08:33 AM
Jim T. Graham is offline
Find More Posts by Jim T. Graham
Administrator
Jim T. Graham's Avatar
United States, TN, Nashville
Joined Mar 2002
I spoke with LA for the first time in years yesterday after I published the article. I sent him a link to this thread and he wrote back with some updated info. I will paste his response here. Note that LA types in all caps. I asked about this a long time ago. It seems to be the way engineers write. Here you go:
I AM GOING TO TELL YOU SOMETHING. THAT IS THE FIRST TIME I HAVE EVER WATCHED THE VIDEO WE DID ON SOLDERING!!! DON’T KNOW WHY I HAVE NEVER GOTTEN AROUND TO IT, BUT I JUST NEVER HAVE. ALL THE INFO IS STILL GOOD, “EXCEPT” NOW WITH THE NEW “NO LEAD” SOLDER, THE MELTING TEMP IS A LITTLE HIGHER THAN THE OLD TIN, LEAD SOLDER. WHEN I FOUND OUT THAT THEY WERE DOING AWAY WITH THE OLD SOLDER, I WENT OUT AND BOUGHT SEVERAL ROLLS OF THE OLD STUFF, JUST TO MAKE SURE I HAD ENOUGH TO LAST FOR SEVERAL YEARS.
WITH THE NEWER HIGHER MELTING TEMP, YOU HAVE TO BE A LITTLE MORE CAREFUL ABOUT SOLDERING TO THE DEANS CONNECTORS, OR YOU MAY GET THE BODY OF THE CONNECTOR HOT ENOUGH TO MELT THE PLASTIC IN THE BODY. IF YOU DO, IT WILL BE OK WHEN IT COOLS, “BUT” IF THE CONTACTS MOVE WHILE THE PLASTIC IS STILL SOFT, THE CONTACTS WONT LINE UP CORRECTLY, AND YOU CAN GET A HIGH RESISTANCE JOINT BECAUSE THE CONTACTS ARE ONLY MAKING LINE, OR POINT CONTACT!!! AND THE CHINESE KNOCK OFF CONNECTORS WILL SURE AS HELL MELT AND GIVE YOU PROBLEMS. THAT MAY BE ONE OF THE REASONS THE BULLET TYPE CONNECTORS ARE GETTING SO POPULAR NOW.
NOW LAST BUT NOT LEAST!!! I WAS ABOUT 75 WHEN THAT VIDEO WAS DONE, AND I HONESTLY STILL LOOK THE SAME AS I DID THEM. THE YEARS HAVE BEEN PRETTY KIND TO ME!!! I WILL TURN 83 ON THE 14TH OF THIS MONTH, SO, I DON’T KNOW THIS FOR SURE, BUT I SUSPECT I AM ABOUT THE OLDEST “ACTIVE” FLIER IN THE AREA!!! I PUT IN ONE FLIGHT TUESDAY, JUST TO SHOW A NEW FLIER HOW MUCH BETTER BIGGER AIRPLANES FLY IN THE WIND.
WELL THE WIFE JUST CALLED ME TO EAT. BETTER CUT AND RUN!!!
YOURN,
L.A.
Jim T. Graham is offline Find More Posts by Jim T. Graham
Administrator
Old Dec 06, 2013, 12:21 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Glad to see guys like this still trying to help out and "pay it forward." I hope I still can when I get into my 70's.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Dec 06, 2013, 01:22 PM
mjsas is offline
Find More Posts by mjsas
Joined Nov 2007
Years ago I used some very high current motors in a combat robot. I found that solder joints were not good enough. I noticed that automotive starters and alternators used spot welds for joining wires inside the unit. The Denso SC alternators are an extreme example of spot welding. Those alternators have hundreds of spot welds. Actually all high current joints in autos are either spot welded or crimped.
Copper wires can be spot welded with a standard spot welder and the joints are much better then any soldered joint.
mjsas is offline Find More Posts by mjsas
Old Dec 06, 2013, 10:18 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
he is right about the Deans connector body getting too hot !
KCinNC is offline Find More Posts by KCinNC
Old Dec 07, 2013, 02:08 AM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Cool to see this video here. I remember watching it quite a while back on youtube and it being very sound advice and methods. I don't have a lot of fancy tools and made a soldering jig years ago from left over scrap 2x4 from other projects. I made one for a buddy two but at the time used some small metal clamps i picked up at the dollar store or somewhere for holding wire and drilled holes for soldering bullet connectors. Its time to make a new super deluxe version soon .
Get Real is offline Find More Posts by Get Real
Latest blog entry: Simplecopter T-Copter
Old Dec 07, 2013, 09:27 AM
Ken Smith is offline
Find More Posts by Ken Smith
United States, TX, Johnson City
Joined Mar 2005
Very good thank you for sharing been soldering for a long time but I see where and how I can improve. I too am always looking to learn and improve, thanks again
Ken Smith
Ken Smith is offline Find More Posts by Ken Smith
Old Dec 07, 2013, 12:26 PM
SpadCat2000 is offline
Find More Posts by SpadCat2000
United States, AZ, Lake Havasu City
Joined Feb 2010
Ken Smith
Me Too!
SpadCat
SpadCat2000 is offline Find More Posts by SpadCat2000
Old Dec 07, 2013, 10:00 PM
dee-grose is online now
Find More Posts by dee-grose
Wishing I was at Torrey Pines
dee-grose's Avatar
Tanner, Alabama
Joined Oct 2003
You guys ought to fly with LA sometime. I've enjoyed the couple of times he's been down to my house to fly with us. He's one of those guys that you can just sit around and talk planes all day long. LA has so much airplane knowledge in his head...it's amazing. He cracks me up too. He has big Telemaster planes that he calls his OMPs....Old Man Planes. He says he flies big planes cause they're easier for old men like him to see!
And here's an early Happy Birthday to you, LA. I wish you many more, and I look forward to our next opportunity to fly together.
Andy
dee-grose is online now Find More Posts by dee-grose
Old Dec 08, 2013, 06:07 AM
Joined Nov 2010
Well well, my pictures shown in Hot Pics.
Old Dec 08, 2013, 10:17 AM
MikeAnderson is offline
Find More Posts by MikeAnderson
ago involo ergo sum
MikeAnderson's Avatar
Kemptville, Ontario, Canada
Joined Dec 2000
A modern HD equivalent
For your consideration, there's this from he who shall not be named:
Soldering basics for RC planes (36 min 42 sec)
MikeAnderson is offline Find More Posts by MikeAnderson
Discussion Which Simulator to learn how to fly helicopter? flugobjekt Beginner Training Area (Heli-Electric) 18 May 14, 2014 07:11 PM
Help! How to repair solder pad that fell off? JoeR DIY Electronics 5 Nov 23, 2013 12:16 PM
Help! How to repair solder pad that fell off? JoeR DIY Electronics 0 Nov 21, 2013 08:17 PM
Learn to solder, how? almies The Builders Workshop 4 Dec 28, 2003 04:11 PM
