Old Feb 29, 2004, 07:06 PM
rmasonjr is offline
Find More Posts by rmasonjr
<burp>
rmasonjr's Avatar
Brookhaven, Mississippi, United States
Joined Mar 2002
KAN950 making my servos stutter!
Not sure if this belongs here or not....
I have a brand-new KAN 950 - cycled once on a triton.
I mounted it on my Slow Stik with a GWS 350 and 11x8 prop with an ElectriFly C-10 speed controller. The servos are JR 331 servos. When I go full throttle-up, the rudder servo starts twitching wildly and going crazy.
Formerly, I was using qualcomms on the Slow Stik without any problems.
Could it be that the 11x8 is drawing too many amps through the C-10? I only have 9x7s and I don't think those will work too well.
Thanks in advance...
rmasonjr is offline Find More Posts by rmasonjr
Old Feb 29, 2004, 07:28 PM
fliir is offline
Find More Posts by fliir
FLYER spelled I-squared-R
fliir's Avatar
Grand Rapids, Michigan
Joined Sep 2001
You didn't tell us how many cells of KAN950 you are using.
It is possible you are loading down the system (this includes wires, connectors, etc.) enough that the C-10 can't supply adequate voltage to the radio system. There are other possibilities as well. Start by telling us the cell count.
David
fliir is offline Find More Posts by fliir
Old Feb 29, 2004, 08:27 PM
rmasonjr is offline
<burp>
rmasonjr's Avatar
Joined Mar 2002
sorry - it's an 8-cell KAN 950
Thanks!
Old Feb 29, 2004, 08:48 PM
frederm2002 is offline
Find More Posts by frederm2002
CheapBatteryPacks.com
Beaverton, OR
Joined Dec 2002
A loose weld/solder joint. Bad plug connection might cause this. See if putting pressure (twisting and pushing at various places) on the battery while pluged into your plane with Tx and rx on causes the twitching to stop or get worse.
frederm2002 is offline Find More Posts by frederm2002
Old Mar 01, 2004, 05:47 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
May just be the increased noise of the motor at the higher speed and load due to the higher voltage. Double check your capacitors on the motor.
Gene Bond is offline Find More Posts by Gene Bond
Old Mar 01, 2004, 09:15 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
An 11x8 prop is an awful lot for an EPS350C on 8 cells. What gear ratio? Try a 9x7 prop.
mkirsch1 is offline Find More Posts by mkirsch1
Old Mar 01, 2004, 09:20 AM
rmasonjr is offline
<burp>
rmasonjr's Avatar
Joined Mar 2002
The caps appear to be in place...
It's the 'C' gearing. I was afraid that the amp draw would be a little much for the C-10. I'll try a 9x7 tonight. Ultimately, I think either an 11x6 or 12x6 might be better.
When an ESC's amp limit is exceeded, shouldn't it just shut down? Maybe that's what it's trying to tell me...
Thanks!
Old Mar 01, 2004, 11:14 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
When an ESC's amp limit is exceeded, shouldn't it just shut down? Or SMOKE.... Does it have an overcurrent limiter built in? Check specs -
hoppy
The overload protection just shuts off the motor -
"Battery Eliminator Circuitry provides sufficient current for the
receiver and two micro servos. The motor battery powers the
receiver and servos, then when voltage is reduced to 3.7 v, the low voltage cut-off circuitry stops the motor while continuing to supply power to the receiver and servos. Built-in thermal shutdown protection turns the motor off if the transistors overheat."
Sounds like electrical interference ot the RX.
hoppy is offline Find More Posts by hoppy
Old Mar 01, 2004, 11:17 AM
Matthew Allen is offline
Find More Posts by Matthew Allen
Formerly of mcba fame
Matthew Allen's Avatar
Luxembourg
Joined Apr 2001
I think that may well be a factor. AFAIK, 10x8 is considered to be about the limit for your motor on 8 cells.
Matthew
Matthew Allen is offline Find More Posts by Matthew Allen
Old Mar 01, 2004, 12:28 PM
rmasonjr is offline
<burp>
rmasonjr's Avatar
Joined Mar 2002
hoppy - you might be right. That's a brand-new 350 that I put in there. The only break-in was to put a drop of oil on the bushings.
I think I'll drop back to the 9x7 or 10x8 and try it out.
Thanks, guys!
Rob
making my zaggi fly arkie Beginner Training Area (Aircraft-Electric) 8 Nov 05, 2002 09:04 PM
[Movie making] my finger sliped Beige Electric Plane Talk 0 Jun 10, 2002 01:13 PM
needing help making my depron delta kushal_22 Foamies (Kits) 4 Apr 13, 2002 04:40 PM
Why don't my servos keep their neutral point settings? tempest411 Electric Sailplanes 17 Feb 20, 2002 06:29 AM
Whats happening to my servos? CheapDad Parkflyers 9 May 16, 2001 12:11 AM
