This thread is privately moderated by RDTague, who may elect to delete unwanted replies.
Old Dec 04, 2013, 04:52 PM
RDTague is offline
Find More Posts by RDTague
Trader Rating: 5
RDTague's Avatar
United States, IL, Cowden
Joined Mar 2013
Trader Rating: 5
Sold
4x SunnySky X2216 KV880 II motors
Here are 4 SunnySky X2216 KV880 II motors. I purchased a bunch of these for various 450, 450+, X8, 550, and 550+ builds. I have since moved on to "big prop/ super low KV" builds and these are just laying around the bench.
The right 2 are brand new, complete with bullets. The left 2 were used as spares in an X8 build, hence the shaft ends removed. Also, the bullets are removed on these 2 motors, as I direct solder my motors. I can throw the bullets in, if you want them.
These are AWESOME motors as replacement motors to the cheap and cheesey stock 920kv DJI motors. With these motors, you can safely use 4S and 10" props, with NO worries of over heating. In fact, I'm currently using these on my 550+ craft on 4S spinning 12" APC's. Motor temps run about 125F in the summer.
$80.00 + 2.95 s/h to CONUS only.
Description:
Here's what SS says about them:
SunnySky brushless motors are made of quality components that are normally only seen in high end products, and are designed to give years of high performance. Every motor has been carefully balanced and tested in the factory.
All SunnySky motors are covered by two year limited warranty.
Every motor comes with a cross type mount and a propeller adaptor as shown in the following photos.
Features:
Durable Japanese NMB ball bearings
Efficient Japanese Kawasaki stator steels
Rare earth neodymium magnets stable up to 180 OC
Polyesterimide enameled oxygen free copper wires that work up to 180 OC
CNC machined and anodized aluminum case
Laser-engraved motor model and KV number
Soft silicone wire leads
Patented balance techniques
Specifications:
Stator Diameter .......... 22 mm
Stator Height..............16 mm
Outside Diameter ..........28 mm
Body Length ...............32 mm
Shaft Diameter ............3.17 mm
Motor Kv ..................880 RPM / Volt
Motor Weight ..............68 g
Accesory Weight...........13 g
RDTague is offline Find More Posts by RDTague
Old Dec 04, 2013, 06:31 PM
RDTague is offline
Trader Rating: 5
RDTague's Avatar
Joined Mar 2013
Trader Rating: 5
Sold
For Sale 4 x SunnySky X2216 1250kv Brushless Motor jjmelo Aircraft - Electric - Multirotor (FS/W) 2 Jan 12, 2014 01:04 AM
Question sunnysky v2216, x2212, x2216 ii alvinrenz Multirotor Power Systems 1 Aug 20, 2013 09:59 PM
Discussion Sunnysky x2216 880kV for sport flying? thijmen5 Multirotor Talk 4 Mar 21, 2013 09:56 PM
Sold SunnySky 2216 KV880 motors signal7 Aircraft - Electric - Multirotor (FS/W) 1 Feb 26, 2013 09:38 AM
Sold Motors: 5 x Sunnysky x2216-12 800kv Radial Mount Captain3D Aircraft - Electric - Multirotor (FS/W) 9 Jun 17, 2012 10:23 PM
