Mar 02, 2004, 08:42 AM
Toronto Canada
Joined Dec 2002
There is an article in the February 1982 issue of Model Airplane News by Andy Lennon in which he plots the lift/drag ratios of various airfoils, including a flat plate, curved plate and semi-symmetrical.
It turns out that at low Reynold's numbers (<40,000), curved plates are best, followed by flat plates and finally semi-symmetrical.
At higher Reynold's numbers (>120,000), the lift/drag ratio of the semi-symmetrical has significantly improved, while the curved plate and flat plate remain roughly the same as they were at 40,000.
The formula for Reynold's number at sea level is
Speed(mph) X Chord(in) X 780
A model with an 8" chord, flying at 10 mph would encounter a Reynold's number of 62,400. For this model the curved plate and flat plate would provide more lift for the same drag.
At low speeds curved plate and flat plate are best.
At higher speeds (20 mph) the Reynold's number would be 124,800 and the semi-symmetrical would have a higher lift for the same drag. The lift/drag ratio for the curved and flat plate would be roughly the same as it was at the lower speed.
The key factor in the curved and flat plates is the fact that they are linear and their performance does not change with speed.
A semi-symmetrical airfoil can give a nasty surprise when coming in for landing because the lift that it provides decreases not only because of the decrease in speed, but because of the decrease in lift/drag ratio at low speeds.
For tapered wings, the tips of a semi-symmetrical wing would stall first because of the decrease in Reynold's number at the tips.
For low aspect ratio wings the Reynold's number would be higher at low speeds. Flat plates have an advantage because at slow speed their lift/drag ratio is not only higher, but would be relatively constant regardless of speed.
This helps explain the terrific performance of all the IFO's, Sukalyns and 3dExtras.
