The Wraith FPV Truck - Stage II
In this next phase of the FPV truck I upgrade the camera mount, install a GoPro, mod the electronics and more!
Welcome to stage two of the Axial Wraith FPV truck project.
I really enjoyed taking a stock Axial Wraith and using FPV gear I had on hand to make it an FPV rig. It exceeded my expectations as a fun FPV rig that I could use to bash around the track or my back yard. You can read about stage one of this project here.
The RC Truck FPV Project Phase 2 - RCGroups (12 min 37 sec)
The Truck - The Axial Wraith
I went with the Axial Wraith because this is a truck that everyone loves and there are a lot of aftermarket parts for it. In particular there are FPV parts available for it. Axial sent me the RTR Wraith. The only thing I needed was batteries for the truck. It is truly a plug-and-play vehicle that hasn't given me a moments issue. I have taken it on rock courses, jumped it and bashed around creek beds. It did it all without a hick-up and allowed me to enjoy this FPV adventure.
The Camera - GoPro 3
I wanted to upgrade the camera in the truck and the natural choice was the GoPro 3. I had to order a USB out cable for the GoPro to transmit to my RC Logger 5.8 transmitter. RC Logger sells this cable and it works great. The GoPro has it's own battery built in and I will use that for now.
GoPro 3 Axial Wraith Mount - ReadyMadeRC
Our friends at ReadyMadeRC sell a killer carbon fiber mount for the GoPro. This is made specifically for the Axial Wraith. The kit allows you to utilize the rear deck behind the Wraith's seats. It provides a mount for the camera and tx.
What's included:
  • FPV mounting plate (from fiber reinforced plastic)
  • Camera mounting plate (from fiber reinforced plastic)
  • Double and single sided foam tape
  • Camera strap with 5 zip ties
Internal Mods
To get more weight on the front axle for better hill climbing I wanted to move my battery to the front of the Wraith. To do this I had to at least move the speed control. Since I was there I went ahead and moved the receiver as well. All other electronics were moved to the back of the truck where the battery originally went. This was pretty straight forward. I did have to extend some wires from the lights. I also used a servo cable extension to get that to the back of the truck.
Ultimately I found that pulling power from the truck rx to run the FPV tx created interference. I also felt like the 5.8 tx and the Wraith rx needed to be farther apart (to combat interference). I left the ESC in the back and moved the truck rx in front of the driver dash using a zip tie. This allowed me to run a battery under the hood and stop the interference.
Aluminum Axial Wraith Body Panel Kit - AdvancedMetalFab
I found AdvancedMetalFab when looking for a way to raise the roof. They make the aluminum roof with the GoPro mount. This allowed me to remove the top of the roll cage that was restricting my view and really opened up the top of the truck. They didn't want to stop there. They sent me their Axial Wraith body panel kit. This replaces all the body panels on the Wraith.
Aluminum Hood - The aluminum hood is a nice addition. Instead of screwing it down I used magnets to attach it to the frame. This allows me to easily remove the hood to get access to the battery.
Belly Pan - I wondered if I needed a belly pan. After one outing it was obvious I did based on the dirt and dings under there.
Differential Protectors - The diffs also showed wear and tear from my first outing. Be careful not to strip your screws when removing them from the Wraith.
Tail Light Protectors with Tow Hook - This just looks cool and the tow hook would be nice to have if you decide to pull a trailer.
View the World Through Goggles!
The small LCD I initially used was cool but I had to try some FPV goggles. I received the new SkyZone goggles from Foxtech and did a complete review on them.
Goggles literally put you in the cab of the truck. The real trick is to not try to move your head around with the motion of the truck!. I also modded the goggles to be used with some motorcycle goggles for more comfort.
Stage II of FPV build offered a lot of fun with not a lot of work. The gear I used on my truck I also use on my quads and my plane. The Wraith never gave me any trouble and allowed me to focus on getting the FPV gear set up and running. The addition of the goggles really made the experience of FPV immersive.
I have read that starting with FPV on a ground based vehicle is a great way to start exploring first person video. If you get disoriented you can simply stop moving (not so with an airplane). It's also a ton of fun. Putting the goggles on spectators while you drive around is not only interesting for them but fun for you too. They tend to lean forward and back with the movement of the vehicle. One guy almost knocked me over!
If this is something you have thought about doing I urge you to try it. It was more fun than I ever thought it would be!
Old Dec 13, 2013, 10:03 PM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
These articles are doing nothing more than making me want to build a ground-pounder with the quickness!
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Dec 14, 2013, 02:23 AM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Cool setup.
SoloProFan is offline Find More Posts by SoloProFan
Latest blog entry: Pictures of various boats
Old Dec 14, 2013, 11:18 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Great looking truck, I like the aluminum parts
carguy1994ca is offline Find More Posts by carguy1994ca
Old Dec 15, 2013, 04:02 PM
Jimmy the Heater is offline
Find More Posts by Jimmy the Heater
Jimmy the Heater's Avatar
United States, WA, St John
Joined Jun 2012
I'm not an FPV'er yet but that Wraith with the aluminum body panels is great!
Jimmy the Heater is offline Find More Posts by Jimmy the Heater
Old Dec 16, 2013, 06:45 PM
Quebec, Canada
Joined Sep 2006
You better not start then ! FPV is addictive and a money pit, ask me how I know !
Old Dec 18, 2013, 03:13 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
ive been looking for a good 4wd to do fpv. right now ive got a nice bulldog tank that shoots bb's set up for fpv, aka squirrel hunting
stoneenforcer is offline Find More Posts by stoneenforcer
Old Dec 18, 2013, 03:19 PM
Quebec, Canada
Joined Sep 2006
Good FPV truck = Summit 1/10 Actually, its the best
Old Dec 24, 2013, 11:12 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
I fpv my twin hammers
Tis fun
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Dec 25, 2013, 12:28 AM
Jim T. Graham is online now
Find More Posts by Jim T. Graham
Administrator
Jim T. Graham's Avatar
United States, TN, Nashville
Joined Mar 2002
Do you have a build thread on your Twin Hammers?
Jim T. Graham is online now Find More Posts by Jim T. Graham
Administrator
Old Dec 25, 2013, 10:32 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
no.
I was just using fat shark pred v2 set up with cam mounted on hood.
I have since got the skyzone goggles (waiting for replacements currently) and I will change the fpv gear.
I can use a modified stripped down Walkera TX5805 or, I'll use the walkera DV04 cam and tx5803 (newer white fpv gear) because I can do onboard fpv recording to cam.
OR
I may do a pan and tilt set up using mobius or 808#16 as fpv cam with onboard recording.
I have other options as well to explore.
I'll also be converting twin hammers to work on my DX8 for more range - stock RTF transmitter wont go further than 200 feet.
Plus with DX8 I can add more fun to the mix with 8 channels
Merry Xmas
Old Dec 25, 2013, 10:49 AM
Administrator
Joined Mar 2002
I have the Wraith running from my DX18 now. I also just received a pan and tilt cam that I will install, as well as a 600mw Boscam vid tx.
Administrator
Old Dec 25, 2013, 11:12 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
nice
Looking forward to seeing results
Old Dec 27, 2013, 11:56 PM
KCV6 is online now
Find More Posts by KCV6
lurking in the HOLE :)
KCV6's Avatar
Australia, SA, Edinburgh
Joined Aug 2009
Jim I'll be real interested to hear how you go with pan and tilt. I really struggled with car FPV with reduced peripheral vision, always ended out running into stuff off to the side.... like the curb. LOL
Love the ally body kit by the way.
Mark
KCV6 is online now Find More Posts by KCV6
Old Dec 28, 2013, 12:09 PM
Dacono Air is online now
Find More Posts by Dacono Air
Certifiable
Dacono Air's Avatar
USA, CO, Dacono
Joined Aug 2009
I can not help but wonder if the Aluminum body panels are going to affect signal propagation?.
I'm not saying don't try them I am genuinely curious though Because of a "Maybe" future mod on my Summit.
Perhaps Alex (IBcrazy) would know?.
Dacono Air is online now Find More Posts by Dacono Air
Discussion GSTV - "Ground Station TV" - FPV Meets of 2014 CaliDave FPV Talk 5 Sep 28, 2014 10:19 PM
News Axial Wraith FPV mounting kit Matt Gunn FPV Talk 3 Jul 14, 2014 12:06 PM
Discussion need help setting up an fpv truck nsolcis FPV Talk 0 Nov 24, 2013 01:25 AM
Help! SloShark - slow and stable FPV/Photo/Video plane. DESIGN STAGE RoCkaZ Giant Electric Planes 2 Apr 03, 2009 08:26 AM
Swift Heli - Bling Stage II jdbercic Electric Heli Talk 5 Nov 28, 2005 10:55 PM
