Old Feb 29, 2004, 04:46 AM
Swamp Thing is offline
Find More Posts by Swamp Thing
Joined Feb 2004
CD-ROM : How about that little sled motor?
Much has been said done re. the spindle motor... but I'm wondering if the pickup sled servomotor in the CD-ROM drive is any use ? I have one weighing 17 gms; 10 ohms res.
Maybe it could work in a niche application, like bigger than pager motors and smaller than CD-Rom spindle motors.
Has anyone been there / done that?
Swamp Thing is offline Find More Posts by Swamp Thing
Old Feb 29, 2004, 05:42 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
I took apart a few CD drives to get access to the brushless parts and I discovered that the ancilliary motors of which there are two, are both relatively high voltage brushed DC type which would have to be rewound with fewer turns of thicker wire to make much use of them.
Andy
AndyOne is offline Find More Posts by AndyOne
Old Feb 29, 2004, 09:39 AM
Rad Racer is offline
Find More Posts by Rad Racer
Hi Wattage Electrics - Cool
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
If you remove the rotor and knock out the magnets you can use the case for a CD rom endbell. The cases are deep, and allow you to double stack stators You will have to mix and match stators and do a little machining but works quite well.
Wayne
Rad Racer is offline Find More Posts by Rad Racer
Old Mar 01, 2004, 09:51 AM
Joined Feb 2004
Wayne, Andy, -- Thanks for the info. I guess that motor will have to just wait in the junk box till I acquire enough skill & confidence to tackle that sort of modification!
About that little hole in the propeller -- ? Pete2 Beginner Training Area (Aircraft-Electric) 1 Mar 02, 2005 02:29 AM
That little tail motor Heliofagoodtime BladeRunner Heli 13 Feb 01, 2005 04:58 PM
So, how about that weather... eBird Life, The Universe, and Politics 8 Nov 03, 2004 06:43 AM
CD-ROM how-to? daisycutter Power Systems 1 Sep 08, 2003 10:15 AM
