Old Nov 30, 2013, 03:15 AM
Benagen is offline
Find More Posts by Benagen
Blurry Iriot
Australia, WA, Swan View
Joined Sep 2013
Data
Phoenix models Boomerang 60 Mk ll fresh EP setup and testing
Hi all,
Boomerang 60 Mk ll by Phoenix models.
I bought the model second hand still in box and am pleased with its build quality.
It now contains the following;
Turnigy SK3 5045-500kv (Rated @60A max cont and 1350W)
Turnigy 85A ESC with 5A SBEC (SBEC not in use)
1x Nano-tech 5s 5000mAH 25-50c lipo fully balanced and charged
APC-E 15x10
COG is 95-100mm from leading edge alongside fuselage
AUW is 4250g
Measured 7800 RPM @ 100% throttle
24'c and 100m above sea level
2.5 inch ground clearance
Here are some pics
Had to add two of the size 4 sinkers not the four in the photo! to the nose even though everything is as far forward as possible and it has a 2650mah rx pack tucked in too.
RPM: 7800 Volts: 20.00V Current: 59.39 Amps Power: 1187 Watts
Height ASL: 150m Speed: 119 km/h Thrust: 3927.1 g
Temperature: 24C Torque: 1.2157 Nm Power: 993.0 W Efficiency: 83.6 %
(http://www.badcock.net/cgi-bin/power...+200&Temp=20.0)
Thrust Constants Tfact: 58.9359 Tpower: 2.04
Power Constants Pfact: 1.0681 Ppower: 3.33
Benagen is offline Find More Posts by Benagen
Old Dec 01, 2013, 02:21 AM
Benagen is offline
Blurry Iriot
Joined Sep 2013
She had her maiden today. Took off in 15-20 feet what a wonderful bird!. Flew nice and gentle and I was happy with the punch provided by the setup.
The motor and ESC were almost cool to touch and the battery was the good kind of warm, but going to cut some vents in the fuse to vent battery heat anyway.
I think she was up for about 4-5mins with quite a lot of WOT, I landed and still had 3.7v in each cell and put about 3300mah back in)
Im looking forward to flying again next Sunday
Ben
Discussion OrangeRx T-six setup for Phoenix v4.0.m setup rcfan7712 Simulators 6 Nov 25, 2014 07:25 PM
Discussion Ultralight New Pitts 12 EP RC Wooden model Fixed-wing plane vivianpell Giant Electric Planes 1 Nov 27, 2013 10:55 PM
Wanted World models EP mini midget mustang Mike_eee Aircraft - Electric - Airplanes (FS/W) 1 Nov 23, 2013 08:35 PM
For Sale Phase 3 phoenix ll RTF artman51164 Aircraft - Electric - Airplanes (FS/W) 4 Oct 11, 2013 09:30 AM
Question phoenix models boomerang 60 trainer mrleenagle Fuel Plane Talk 3 Aug 18, 2009 10:12 PM
