Old Nov 28, 2013, 07:32 PM
jameschen072 is offline
Find More Posts by jameschen072
The flightless bird
jameschen072's Avatar
Joined Aug 2004
Mini-Review
The Vitality FT009 review
The Fei-Lun/Vitality FT009 review
Hey guys,
In early 2003, my neighbor (who saw my early R/C attempts at flight) invited me to go R/C sailing with him; this led to me to learn a lot from him with regards to the construction, rigging and sailing of these graceful, magnificent watercraft. Iíve always missed the boating experience, perhaps itís because I grew up in Auckland or maybe itís because of those beautiful hand-crafted sailboats my neighbor made; either way it has always been in the back of my mind although I eventually developed planes, helicopters and quads as my passion.
Fast forward to 2012, I had the opportunity to see the final prototype of the Fei-Lun FT007; The performance, reliability and affordability sparked this old passion of mine. I knew that the FT007 was going to become a hot seller, indeed; a lot of you who got the FT007 (and rebrands) are now fans and love it as much as I do.
Building upon the success of the FT007, Fei-Lun recently announced the FT009; a larger, more powerful, water-cooled improvement upon the FT007.
In this review I would like to explore the various aspects of this boat to see if it really does live up to our expectations and whether or not she should be a part of your fleet.
Before we begin, I would like to thank T-Mart for providing the review sample and their willingness to stand behind a fair and unbiased review.
From the dock
The FT-009 comes well-packed in a Styrofoam box. Sheís even got her own plastic stand, unfortunately it was missing one of the three parts so I wonít be able to use it (itís most likely sitting somewhere in the Tmart warehouse )
The box that the FT009 comes in- Styrofoam inserts have been placed to provide maximum protection for the boat
In the box youíll find the following
1x FT-009 boat (assembled, thankfully)
1x 2.4GHz 2 channel proportional radio
1x 7.4V 1500 mAh Lipo battery
1x Spare propeller
1x Lipo charger
1x Display stand
1x Nose bumper (which mine didn't come with for some reason)
1x Instruction manual
The stated range is around 100-150 meters (or around 330-490 feet)
Charge time takes around 4 hours with the stock charger (but the standard balancing plugs, it should allow you to use more professional chargers)
Finally, run-time is expected to be 5-6 minutes.
Construction and design
The FT009, like its predecessor, is made of ABS plastic. This plastic has proven to be quite tough in my experience; it doesnít become brittle even in the freezing lakes around Beijing in the winter.
When I picked the boat up, my first impression was that WOW THIS THING IS REALLY HEAVY!
The boat hull is quite similar to that of the FT007
Letís take a look at what's inside the FT009:
The ESC/Receiver is located in a sealed box in the bow of the boat;
The motor is a water-cooled 540 class brushed motor; it is located behind the electronics bay for better weight distribution. The coupling between the motor and the drive shaft is the same as the FT007 unit but the air-cooling fan has been removed.
Water-cooling system: the water inlet is located next to the drive shaft just slightly forward of the propellers. Tubing brings the water around the motor and exits from the bottom of the hull.
Behind the motor sits the battery bay; located above the drive shaft, it is unlikely that the battery would come in contact with any water that may get into the hull.
Finally, the servo is a standard 3 wired servo. The servo linkage exits the hull through a rubber seal and connects to the large rudder.
An interesting design feature of the FT009 is the double canopy. A plastic cover with an o-ring seal is locked into place with four tabs and provides a watertight seal. A decorative canopy fits above this cover and is locked aft of the canopy.
An additional feature of the FT009 that I appreciate is the hole located at the stern of the boat; from which water could be emptied without opening the boat canopy.
A self righting feature is built into the boat; if the boat becomes inverted, give full reverse then full forward throttle and the boat will right itself.
From the bridge
Included is a very basic two channel 2.4GHz transmitter (the same unit as found on the FT007); it features trims on both the throttle and the steering channels but provides no other functions (not that you really need them for this product anyways). I would say that the plastic is somewhat nice though the finish is quite unrefined. The transmitter feels quite nice to hold in my big hands, and itís not unreasonably heavy even with the 6 ďAAĒ batteries it requires.
The throttle does not have much of any feedback at all, I prefer a little tension in the springs; as to the steering the spring tension is just right for my likings.
On the water
With batteries charged (and yes unfortunately it does take a good four hours to charge this Lithium Ion battery), off I went to the local pond. Binding required a few tries but after the boat is bound to the transmitter, the radio signal is as solid as ever and I could run her as far as I could see without losing control. Off the bat the FT009 is blazingly fast compared to its little sister! There's a really tall rooster tail (which I know you'll appreciate Romeo); Iím surprised that it could manage such speeds being that sheís quite hefty when compared to similar-sized competitors; she gets on plane very quickly and effortlessly.
I do prefer the way the FT009 rides through the water than the comparatively sized WL911 (which porpoises through the water); not to mention that the FT009 feels a lot more powerful.
The improvements on the water-tight seals really make a spectacular difference as very little water (note: almost none) manages to get into the hull after a full-battery worth of high-speed runs.
As for the water-cooling system, well that works very nicely too; the motor had a very slight warmth to it but I would have comfortably ran another battery pack if it weren't for the non-standard battery lead.
For those of you worried about the self-righting system, it works as advertised. I went to test out the boat with our chief test pilot here at HiSKY and we were throwing it into the water in every-which way possible. The FT009 is inherently very stable (VERY low CG) and it almost always self-rights without any input from the user.
Overall, the FT009 builds on the success of its predecessor. She is powerful, affordable and most importantly, reliable. A lot of the problems seen with the FT007 (like the amount of water it likes to ingest) are practically solved with the FT009; this makes me a happy camper.
I do have a few problems with this boat that I would like to point out though, namely the throttle springs (which are barely there), the choice of plugs with the battery (non-standard, Iíll switch mine to Deans plugs) and the lack of run-time.
ďIs it the right boat for me?Ē I think this boat should satisfy those who are just starting out with R/C boats; even those with some experience would enjoy it in my opinion. Iím very happy with her despite the little flaws (remember that thereís never a perfect product) and I think that you get a lot for the price you pay.
Guys, I hope youíve enjoyed my review (and me blabbing on and on) of the FT009. If you have any questions or suggestions, please comment below or send me a PM.
Special thanks goes to Tmart again for the sample and their support of my (always) unbiased reviews.
You can pick the boat up here for the price of 64.89
Here's a video of the FT009 in action, enjoy!
FT009 video in HD (6 min 33 sec)
Pros and Cons
Pros
+ Great value for money
+ Powerful drive-train
+ Water-cooling system
+ Waterproofing performance improved
+ Self-righting feature
Cons
- Transmitter throttle spring provides very faint feedback
- Binding could be a little problematic sometimes
- Non-standard battery plug
*I brought the HiSKY test pilot with me to the pond... and in true pilot fashion, he wanted to make the boat fly!! (I swear these are not photoshopped)
tic-tocs with a boat!
I've always wanted to see a flying boat!
jameschen072 is offline Find More Posts by jameschen072
Old Nov 28, 2013, 08:48 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Nice review partner. I'll have to pick one up.
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
CWBETB is offline
Find More Posts by CWBETB
United States, PA, Reading
Joined Oct 2013
Looks like a great boat for the money!
CWBETB is offline Find More Posts by CWBETB
Old Nov 28, 2013, 10:05 PM
The flightless bird
Joined Aug 2004
Cheers guys, this is really a great boat for the price and its performance is truly amazing, just wait till you see the video! (which I'll upload soon)
Latest blog entry: The Fei-Lun FT011 Review
Old Nov 29, 2013, 08:16 AM
SeByDocKy is online now
Find More Posts by SeByDocKy
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Nice review James
Will order one tmart got them in stock ?
EDIT : They keep the same security system ... I will by-pass it asap
SeByDocKy is online now Find More Posts by SeByDocKy
Old Nov 29, 2013, 08:32 AM
SeByDocKy's Avatar
Joined Dec 2012
I ordered it using the B12 coupon 51 USD
Old Nov 29, 2013, 08:38 AM
SeByDocKy's Avatar
Joined Dec 2012
Now I can't imagine to race it in my favorite Lake close to my home.
FT007 racing in le revest les eaux (5 min 51 sec)
Old Nov 29, 2013, 09:22 AM
CWBETB is offline
Joined Oct 2013
Originally Posted by SeByDocKy View Post
Nice review James
Do you have any pics about disabling it? I had my ft007 flip on me the other day and the sensors didnt pick up and it floated away! Luckily next morning I did a search and found it on the other side of the lake!! :O
Old Nov 29, 2013, 09:28 AM
SeByDocKy's Avatar
Joined Dec 2012
Yes ...
I used a motherboard jumper then I hot glued all the package
Old Nov 30, 2013, 12:17 AM
HeliStorm (FPV America) is offline
Find More Posts by HeliStorm (FPV America)
Working to make things happen!
HeliStorm (FPV America)'s Avatar
United States, OH
Joined Mar 2013
Ok...I was going to stick to flying things. But, I got an inexpensive little RC car...yeah, just one little guy. Why am I trying to build a navy now? This looks very cool, and I cannot wait to see some video. It sounds like it would be a relatively good place to start in RC watercraft.
HeliStorm (FPV America) is offline Find More Posts by HeliStorm (FPV America)
Old Nov 30, 2013, 02:56 AM
The flightless bird
Joined Aug 2004
@Seb: hey ol' pal, I'm still waiting for you to decide on when to come to Asia, we'll go boating as well!
@HeliStorm, here it is!!
FT009 video (6 min 33 sec)
Will hopefully upload a HD version soon, but uploading this 480p one took me all day with my slowww VPN
Old Nov 30, 2013, 03:32 AM
SeByDocKy's Avatar
Joined Dec 2012
http://youtu.be/CWLPGzquNas
Very nice video James .
James, my trip to HK would be probably in first semester 2014. Now moving next saturday to Tahoe Lake haha
Old Nov 30, 2013, 08:44 AM
CWBETB is offline
Joined Oct 2013
Looks great on the water, one concern though, it just strands you when battery dies? No warning?
Old Nov 30, 2013, 08:50 AM
CWBETB is offline
Joined Oct 2013
Yes ...
Thanks! I was just able to follow a red and black wire back to esc and solder the two together and works fine. Looks like it had 4+ water contact points, I can see why this could be a issue if one point fails it wont work. If anyone buys this boat or the Ft007, ditch the safety asap!
Discussion Skywalker 2014 - 1800mm - FPVModel - Spanish Review Japanx FPV Aircraft 10 May 12, 2015 06:29 AM
Mini-Review Turbodrone Micro Quad review stallion explosi Multirotor Talk 0 Nov 22, 2013 08:27 AM
New Product Vitality H36's Brother Vitality H39 2.4G 4-axis RC Quadcopter With camera RTF Aaron qin Mini Multirotors 14 Sep 18, 2013 09:02 AM
