Old Feb 28, 2004, 12:53 PM
Arbo is offline
Find More Posts by Arbo
Joined May 2000
Building and flying a Guppy....
Ok.. I am starting this thread to document a design I've been working on, through the building and flying of it.....
I start out by building the rear wing hold down tray....
Arbo is offline Find More Posts by Arbo
Reply With Quote  (Disabled)
Old Feb 28, 2004, 12:54 PM
Arbo is offline
Joined May 2000
Then place 4 of the rear formers on the fuse bottom former...
Old Feb 28, 2004, 12:56 PM
Arbo is offline
Joined May 2000
Then install the servo tray... note the 1/4" backings are on different sides to allow the servos to sit at different heights so as not to interfere with each other.
Old Feb 28, 2004, 12:57 PM
Arbo is offline
Joined May 2000
Then the bottom shelf the horizontal stab sits on.....
Old Feb 28, 2004, 12:58 PM
Arbo is offline
Joined May 2000
Then the top shelf that sits on top of the horiz stab....
Old Feb 28, 2004, 12:59 PM
Arbo is offline
Joined May 2000
Here's the rear fuse together....
Old Feb 28, 2004, 01:01 PM
Arbo is offline
Joined May 2000
Now to work on the fuse sides... first I glued the fuse sides togehter as they are in two pieces.. then install the battery tray supports and hatch rail...
Old Feb 28, 2004, 01:02 PM
Arbo is offline
Joined May 2000
Then build the landing gear box.....
Old Feb 28, 2004, 01:03 PM
Arbo is offline
Joined May 2000
Now glue the LG box and forward wing hold down former to the fuse side... as well as the support block just behind the lg box..
Old Feb 28, 2004, 01:04 PM
Arbo is offline
Joined May 2000
Then I connect the rear fuse to that same side....
Old Feb 28, 2004, 01:06 PM
Arbo is offline
Joined May 2000
Now I add the hatch rail to the other fuse side... (if you notice, I put it on the wrong side... I cut it off and fixed it.. )
Old Feb 28, 2004, 01:08 PM
Arbo is offline
Joined May 2000
Now work the other fuse side onto the whole assembly... starting from the front and working back... make sure to put the ply motor mount formers in there... as you work back, the fuse squares itself out nicely.
Old Feb 28, 2004, 01:09 PM
Arbo is offline
Joined May 2000
Now I install the cowl parts...
Old Feb 28, 2004, 01:10 PM
Arbo is offline
Joined May 2000
Now on the underside, attach the little piece of fuse bottom between the LG box and forward wing hold down....
Old Feb 28, 2004, 01:11 PM
Arbo is offline
Joined May 2000
And the little rails and hole where you will get in to screw the gearbox to the motor stick....
Building and Flying a Kwik-E kelvin Sport Planes 152 Aug 17, 2003 11:35 AM
Building and Flying an E3D kelvin Sport Planes 1428 Feb 18, 2003 10:16 AM
AERC F-4 Phantom Building and flying thread! pilatus turbo Electric Ducted Fan Jet Talk 0 Nov 14, 2002 12:44 AM
Who is building/flying SR Batteries X70? CheeseWing Parkflyers 0 Sep 08, 2001 05:36 PM
Building a Flying wing from scratch LyndonC Foamies (Kits) 2 Jun 29, 2001 08:15 PM
