This thread is privately moderated by paero, who may elect to delete unwanted replies.
Old Nov 27, 2013, 03:25 PM
paero is online now
Find More Posts by paero
Trader Rating: 103
United States, WI, Oconomowoc
Joined Aug 2010
Trader Rating: 103
For Sale
NEW!! EPP Foam Glue
New From Bob Smith
"Foam-Cure" a silicon based clear, flexible adhesive. Will bond any porous surface and is good for use on foam, especially the EPP types. Foam-Cure stays flexable when it is cured, but does NOT cure well when bonding two non-porous surfaces.
1 ounce $2.25
4 ounce $3.40
Orders shipped USPS Priority for a flat $ 6.00 per order
E-mail & Pay Pal Address: rfe45@charter.net
www.precision-aero.com
paero is online now Find More Posts by paero
Old Nov 27, 2013, 05:10 PM
BrendanH is offline
Find More Posts by BrendanH
Trader Rating: 2
build, fly, crash, repeat
BrendanH's Avatar
United States, WA, Spokane
Joined Jul 2012
Trader Rating: 2
I've used the exact same glue (but from HK). It is very nice glue, works flawlessly with EPP.
BrendanH is offline Find More Posts by BrendanH
Old Nov 28, 2013, 10:16 AM
dz1sfb is offline
Find More Posts by dz1sfb
Trader Rating: 30
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Trader Rating: 30
Excellent product and lower cost alternative to Foam Tac. Works great on Extruded Polystyrene as well, a.k.a. Model Plane Foam.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Nov 28, 2013, 11:20 AM
JIMBOJONES is offline
Find More Posts by JIMBOJONES
Trader Rating: 27
JIMBOJONES's Avatar
United States, IN, Milan
Joined Feb 2009
Trader Rating: 27
I use it for epp, depron, cellfoam 88, and all other foams. It is better than foam tac for me because foam tac tends to thicken over time making it very hard to apply with any control. I would buy some but my LHS is now stocking it.
JIMBOJONES is offline Find More Posts by JIMBOJONES
Old Nov 28, 2013, 02:13 PM
blissinindy is offline
Find More Posts by blissinindy
Trader Rating: 37
blissinindy
Indianapolis IN
Joined Jan 2003
Trader Rating: 37
Reviews read as another contact cement - clear, reasonable performance and less expensive.
My question is is it as caustic in terms of aromatics as foam tac? I find UHU and Welders to be a bit less so ... I see silicone based and think maybe better ... That would be appreciated!! Particularly this time of year where a well ventilated area is COLD :-)
Thanks!!
blissinindy is offline Find More Posts by blissinindy
Old Nov 28, 2013, 02:17 PM
BrendanH is offline
Trader Rating: 2
BrendanH's Avatar
Joined Jul 2012
Trader Rating: 2
Thanks!!
Mine didn't smell much at all. It has a little aroma but not bad.
Old Nov 28, 2013, 02:59 PM
Trader Rating: 27
JIMBOJONES's Avatar
Joined Feb 2009
Trader Rating: 27
You can smell it, but it is non-offensive smell with no sign of solvents
Old Nov 28, 2013, 03:03 PM
Trader Rating: 37
blissinindy
Indianapolis IN
Joined Jan 2003
Trader Rating: 37
Originally Posted by JimboJones
You can smell it, but it is non-offensive smell with no sign of solvents.
Ah so not like Foam Tac - sounds good, thanks very much!!
Old Nov 28, 2013, 05:09 PM
Ks.jetflyer is offline
Find More Posts by Ks.jetflyer
Trader Rating: 78
Newton, Ks.
Joined Feb 2004
Trader Rating: 78
what is the cure time?
Ks.jetflyer is offline Find More Posts by Ks.jetflyer
Old Nov 28, 2013, 05:18 PM
BrendanH is offline
Trader Rating: 2
BrendanH's Avatar
Joined Jul 2012
Trader Rating: 2
My bottle says 15-30mins. Full cure in 24hrs.
Old Nov 28, 2013, 06:28 PM
ltc is offline
ltc
Find More Posts by ltc
Trader Rating: 86
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Trader Rating: 86
How does this compare to UHU Por?
ltc is offline Find More Posts by ltc
Old Nov 29, 2013, 01:06 PM
Trader Rating: 27
JIMBOJONES's Avatar
Joined Feb 2009
Trader Rating: 27
For me its a simple comparison,
UHU smells bad, and I can find the BSI foam glue locally.
Old Dec 06, 2013, 01:18 PM
kinetisist is offline
Find More Posts by kinetisist
Trader Rating: 22
kinetisist's Avatar
United States, CA, Burney
Joined Jan 2013
Trader Rating: 22
??? how does it do for making glue hinges .. put it on and pull then stick back and then you have a hinge .. this type of hinge is same as with foam tac ..?????
kinetisist is offline Find More Posts by kinetisist
Old Dec 06, 2013, 05:07 PM
Trader Rating: 27
JIMBOJONES's Avatar
Joined Feb 2009
Trader Rating: 27
Honestly I have never made glue hinges. I have however spread a thin layer if this glue along the joint, then use blendurm for the hinge once it has cured.
Old Dec 06, 2013, 05:08 PM
BrendanH is offline
Trader Rating: 2
BrendanH's Avatar
Joined Jul 2012
Trader Rating: 2
I just put a few drops along the hinge, set the desired hinge gap, and scrape along the hinge with an old gift card. Hasn't failed me yet.
For Sale NEW!! EPP Foam Glue paero Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 15 Jan 07, 2014 05:53 PM
Discussion Goop works the same as welder glue on epp? jackheli Foamies (Kits) 8 Dec 29, 2013 10:00 PM
Discussion Ca Foam Safe Medium Glues papadwight Electric Plane Talk 0 Oct 24, 2013 08:00 AM
Sold NEW!! EPP Foam Glue paero Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Aug 15, 2013 05:59 PM
epp foam glue to cut with hot wire? inedesca Scale Kit/Scratch Built 4 Jun 08, 2001 08:08 AM
