Old Nov 26, 2013, 03:50 PM
Commandernh is offline
Find More Posts by Commandernh
NH Armored Assault R/C Club
Commandernh's Avatar
Joined Jan 2013
Question
RX18 And 2.4GHZ RX18
Ok I am converting an old rx14 system to the HL 2.4 GHZ system and was using a 27 MHZ RX18 Board as a guideline when I noticed some differences.
1. There is an extra connector on the lower right hand side on the 2.4. See pics.
2. There is a two wire connector on the 2.4 lower left that has what seems to be a switch on the end of it. I have no idea what that switch is.
Any help is appreciated
Mike T
rctanksnh.com
Commandernh is offline Find More Posts by Commandernh
Old Nov 27, 2013, 01:28 PM
afv is offline
afv
Find More Posts by afv
afv
uk
Joined May 2008
Maybe not.
afv is offline Find More Posts by afv
Old Nov 27, 2013, 05:24 PM
Rustbucket is offline
Find More Posts by Rustbucket
Portland Oregon
Joined Aug 2006
OK ON THE NEW HL 2,4 radio can any one tell us what that small black button is for . I have played with it and nothing happens. Any different. Thanks DON
Rustbucket is offline Find More Posts by Rustbucket
Old Nov 27, 2013, 06:11 PM
Joined Jan 2013
I see we both have the same delema. Hope get an answer.
Old Nov 27, 2013, 06:59 PM
Portland Oregon
Joined Aug 2006
IF nothing elest I may try to write to HL not sure if I could get an answer but I am thinking about it. I have not a clue . when you push it nothing happen eather way.? Maybe some one will say it goes to ? I think will put that one the boards . YOU can help me when I do it can you put a picture on for us. I have mind installed all ready and you can add a note between you and I we may the answer we need Thanks DON
Old Nov 28, 2013, 08:01 AM
Oracus is offline
Find More Posts by Oracus
I meant to do that!
Oracus's Avatar
United States, IN, West Terre Haute
Joined Apr 2007
Mike T
rctanksnh.com
I found that the lower right extra plug is for smoke function
Oracus is offline Find More Posts by Oracus
Old Nov 28, 2013, 08:05 AM
Oracus is offline
I meant to do that!
Oracus's Avatar
Joined Apr 2007
I also found that your small black button is for binding
Old Nov 28, 2013, 10:10 AM
Portland Oregon
Joined Aug 2006
Thank you maybe that may explan why the ft lights will go off when the tank starts running .
That explans alot . SO how did you fine that one.? I could not fine any thing . .
OK I plan on re working my other tank today. With all of the information and help.
Just have to build a swich. DON THE Rustbucket
Old Nov 28, 2013, 02:58 PM
Portland Oregon
Joined Aug 2006
WELL i DID WHAT THAT NOTE SAID IT SEEMS TO RUN BETTER BUT STILL dont have my FT lights to work . Sooner or later I will get that work out thank you for the note . I made a copy of it for future notes . have a nice thanks giving. DON THE Rustbucket.
Old Nov 29, 2013, 05:54 AM
Joined Jan 2013
Thanks for the help Oracus
Old Nov 29, 2013, 10:51 AM
Portland Oregon
Joined Aug 2006
Yup this what it takes all of us working together as team this way we all learn and help each other. As well help any one that needs it . IT sure has payed off for me many times so I say thank you again to all of you for what you did for me. DON THE Rustbucket or Rusty
Old Dec 02, 2013, 03:23 PM
Joined Jan 2013
2.4 Hook Ups and Instructions
This should make it easier Rusty
Old Dec 03, 2013, 12:34 PM
Joined Jan 2013
In the connection diagram for the 2.4 ghz does anyone know what is meant by Do no use after "Promotion" on the speaker volume adjusting switch and smoke machine switch.
Old Dec 03, 2013, 07:00 PM
Oracus is offline
I meant to do that!
Oracus's Avatar
Joined Apr 2007
Any smallish 4-8ohm speaker will work just fine. I took mine out of an old set of computer desktop speakers.
Old Dec 03, 2013, 07:52 PM
Portland Oregon
Joined Aug 2006
NOW that is what I like to here what other speakers can be use. Thank you FOR I have had the same question . WISH I could help in parts but mostly of what I have are from the older tanks and mostly 120th scale. A a little samller tank and the cheap boards. . That is why I have up dated my tanks to the RX18. Mostly of what I had in 16th had that cheap board . Ok board but not what i was wanting..
For Sale Good Condition Futaba T6EX 2.4GHz Fasst Tx & Futaba R617FS 2.4GHZ Fasst 7 channel Rx helinut4ever Aircraft - General - Radio Equipment (FS/W) 1 Jan 18, 2013 03:44 PM
For Sale Good Condition Futaba T6EX 2.4GHz Fasst Tx & Futaba R617FS 2.4GHZ Fasst 7 channel Rx helinut4ever Aircraft - General - Radio Equipment (FS/W) 1 Jan 17, 2013 05:59 PM
For Sale Good Condition Futaba T6EX 2.4GHz Fasst Tx & Futaba R617FS 2.4GHZ Fasst 7 channel Rx helinut4ever Aircraft - General - Radio Equipment (FS/W) 1 Jan 17, 2013 05:08 AM
For Sale Good Condition Futaba T6EX 2.4GHz Fasst Tx & Futaba R617FS 2.4GHZ Fasst 7 channel Rx helinut4ever Aircraft - General - Radio Equipment (FS/W) 1 Jan 15, 2013 06:03 PM
For Sale Good Condition Futaba T6EX 2.4GHz Fasst Tx & Futaba R617FS 2.4GHZ Fasst 7 channel Rx helinut4ever Aircraft - General - Radio Equipment (FS/W) 1 Jan 13, 2013 06:58 PM
