Mini HDMI to AV Converter
Small, Light, Convienent
The smallest HDMI to AV converter we've seen!
For those wanting more duration from their flights, weight is everything. Every gram counts and you are always looking for ways to reduce the weight of your components. HDMI converters are a necessary component for digital cameras that do not output an analog video signal. Our video transmitters need an analog signal to send over the air to the receiver. The converter takes the digital signal from the camera and converts it to analog. Until now most converters have been big, bulky, and heavy.
Copter Frames is offering this super compact mini HDMI converter. It only weighs 3.6g and is only 3mm thick and 50mm long by 15mm wide. It plugs right into the camera and has audio, video, and ground pinouts. It should work with just about any camera that uses a mini hdmi type C interface. [Copter Frames]
Old Nov 25, 2013, 12:51 PM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
I just bought one of the bigger ones. Should have waited...
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Nov 25, 2013, 02:07 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
It should work with just about any camera that uses a mini hdmi type D interface
Some confusion there. Type D is micro HDMI ... Sony RX100M2 for example. This board is for mini HDMI, type C (NEX series etc.).
Bill Glover is offline Find More Posts by Bill Glover
Old Nov 25, 2013, 04:58 PM
Jason Cole is online now
Find More Posts by Jason Cole
RCG Staff Member
Jason Cole's Avatar
United States, TN, Nashville
Joined Oct 2003
Thanks Bill I should have caught that. They had type d on the site specs.
Jason Cole is online now Find More Posts by Jason Cole
Administrator
Old Nov 25, 2013, 05:07 PM
Joined Nov 2000
No worries. I actually have a Sony RX100M2 and am painfully aware that nobody seems to do AV converters with a type D (micro) plug
Old Nov 27, 2013, 04:39 PM
remvideo is offline
Find More Posts by remvideo
bacon and eggs
remvideo's Avatar
United States, FL, West Palm Beach
Joined May 2013
does this require a 12v to 5v converter ? I beleive my gopro was fried after about a month of FPV use because I didn't use one.
remvideo is offline Find More Posts by remvideo
Old Nov 28, 2013, 11:55 AM
markstibbyspot is offline
Find More Posts by markstibbyspot
Joined Feb 2013
Will this work on the sony action cam
markstibbyspot is offline Find More Posts by markstibbyspot
Old Nov 29, 2013, 01:43 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
It draws 5V from HDMI plug, no need for external power.
However, because people asked I did a hack to power this board from external source. Check my attachments for detailed images.
renatoa is online now Find More Posts by renatoa
Old Nov 29, 2013, 01:44 PM
Joined Sep 2007
If it is a PAL version yes.
The OP forgot to specify this board outputs PAL only, a small detail that many find after buy and don't like.
Old Dec 04, 2013, 02:09 PM
Lorisdem is offline
Find More Posts by Lorisdem
undefined, Nicosia
Joined Jan 2012
Not for sony nex7.
Lorisdem is offline Find More Posts by Lorisdem
Old Dec 04, 2013, 05:37 PM
P.I.Engineer is offline
Find More Posts by P.I.Engineer
P.I.Engineer's Avatar
United States, WA, Maple Valley
Joined Mar 2005
i'm using a 3d printed rx100 mount that i designed to relocate the tripod hole and allow a hdmi cable to be plugged in.
I just ordered a mini to micro adapter and one of those soft(flexible) hdmi cables.
P.I.Engineer is offline Find More Posts by P.I.Engineer
Old Dec 05, 2013, 09:54 PM
remvideo is offline
bacon and eggs
remvideo's Avatar
Joined May 2013
this is PAL, there's been ton of discussion about it. we need an NTSC version
Old Dec 22, 2013, 08:41 AM
KevinW (Qwin) is offline
Find More Posts by KevinW (Qwin)
Eschew obfuscation
KevinW (Qwin)'s Avatar
United States, FL, Apollo Beach
Joined May 2011
What are the options for an NTSC verson?
KevinW (Qwin) is offline Find More Posts by KevinW (Qwin)
New Product HDMI to AV SONY converter which is special for SONYSONY nex5 YXmotor Aerial Photography 457 Mar 11, 2016 06:11 AM
Wanted NEED! Freefly Hdmi to Av converter. I'll Paypal immediately. AlchemistAerials FPV Equipment (FS/W) 4 Dec 16, 2013 03:05 AM
Sold Mini HDMI to AV Converter for FPV Photography Telemetry Support SONY 5N/7N simonsay Aircraft - Electric - Multirotor (FS/W) 0 Aug 24, 2013 12:42 PM
Discussion Hdmi 2 av converter mini - wookong-m gps conflict Nilund Multirotor Electronics 0 Aug 20, 2013 04:33 PM
Discussion mini HDMI to AV converter power up options? panos2408 FPV Talk 9 Mar 03, 2013 12:03 AM
