Old Feb 27, 2004, 04:28 PM
kwhite is offline
Find More Posts by kwhite
Joined Nov 2003
what if you v tailed an 60 or electron? what would happen?
what if you put a v tail an m 60 , with a longer tail boom also,what does reflex do on a conventional glider??my freinds electron seems fast as is.
kwhite is offline Find More Posts by kwhite
Old Mar 01, 2004, 11:05 AM
Antonsoarer is offline
Find More Posts by Antonsoarer
Long to be flyin'
Antonsoarer's Avatar
Wirral, (UK)
Joined Dec 2003
It would be a bit pointless, better to combine the section with the design. Any drag reduction from reduced reflex would probably be offset by the tail. The total effect would increase drag and possibly lift together, so no real gain.
Antonsoarer is offline Find More Posts by Antonsoarer
If you could invent an e-freindly product what would it be ? sonic liner Electric Plane Talk 26 Dec 23, 2004 04:53 PM
What would you do with an old futaba 7 channel radios? darmiejr Electric Plane Talk 26 Mar 14, 2004 06:59 PM
What if you replace the battery in your motorcycle with Nicd's/Nimh's? GregG Life, The Universe, and Politics 25 Oct 18, 2003 05:45 AM
What if you replace the engine in your motorcycle with Nicd's/Nimh's? Fitz Walker Life, The Universe, and Politics 3 Oct 16, 2003 01:02 PM
What do you use for an end insulator on a foam cutter? AW Power Systems 8 Jun 20, 2001 10:49 PM
