Old Feb 27, 2004, 02:47 PM
JMBRAD is online now
Find More Posts by JMBRAD
Jody Bradshaw
JMBRAD's Avatar
Salisbury, North Carolina, United States
Joined Feb 2004
Question
What is the difference in the GW/EPS-300C (2/1/A/B/C/D)?
GWS lists GW/EPS-300C (2/1/A/B/C/D). All these different models. What's the difference?2/1/A/B/C/D
JMBRAD is online now Find More Posts by JMBRAD
Old Feb 27, 2004, 03:30 PM
10Thumbs is offline
Find More Posts by 10Thumbs
Motor Maniac
Orange County, CA
Joined Feb 2002
These are the different gear ratios. Why they use both letters and numbers to designate the gear ratios is beyond me. Note that the ratios for the EPS-400 are different from the EPS-300, as are the IPS (DX). With enough time you may end up memorizing the more common ones (C=5.33, D=6.6, B=4.4 or so, A=3.75). The higher the gear ratio the larger the prop it can spin, which tends to be more efficient than spinning a smaller prop faster.
10Thumbs is offline Find More Posts by 10Thumbs
Old Feb 27, 2004, 05:06 PM
Jody Bradshaw
JMBRAD's Avatar
Joined Feb 2004
Prop size.
When figuring prop size is the 1st # the length and the 2nd # the aggresivness of the pitch on the blade? Give me an example, Of say a 12x4.
Old Feb 27, 2004, 06:32 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
The best analogy for 'pitch' is to imagine your 12x4 prop is (a bit like a corkscrew) rotating in a mass of Jello. For each complete revolution of the prop it will move forward 4". A 6" prop would move 6" and so on. "Pitch speed" is important in flying planes at a suitable airspeed and can be calculated from an equation, simplified as: pitch speed (mph) = rpm x pitch (inches)/1052.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 27, 2004, 06:43 PM
Jody Bradshaw
JMBRAD's Avatar
Joined Feb 2004
Thanks Phil.
Are there any free programs similar to Motocalc that calculate flight times given a particular motor, prop, and battery?
Old Feb 28, 2004, 08:39 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
http://brantuas.com/ezcalc/dma.asp
Discussion difference in the Huey UH-1 B and C model? jeff262 Mini Helis 5 Dec 24, 2006 12:53 AM
GWS Warbirds on GW/EPS-300C-BS tec319 Parkflyers 3 Jul 11, 2003 11:50 PM
What is the difference in Pico Combat Materials? MarkChinery Foamies (Kits) 1 Mar 01, 2003 12:54 AM
What prop for GWS EPS-300C (AS)? Danny Troy Power Systems 6 Nov 11, 2002 03:38 AM
What's the deal with the EPS-300C? hardlock Parkflyers 3 Sep 29, 2002 05:36 PM
