Old Feb 26, 2004, 06:59 PM
littlepiston is offline
Find More Posts by littlepiston
USA, NM, Carlsbad
Joined May 2002
Rant
Wemotec MINI fan 480! to balance or not to balance??
how in the he11 dose One balance the fan and spinner!!!
ive gone through two and cant figure it out
i have balanced the fan fine but when i add the spinner the thing gose wild!!!!! help!!!
littlepiston is offline Find More Posts by littlepiston
Old Feb 26, 2004, 08:23 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
install the rotor with the spinner, run it up to about 1/4 power, if smooth continue until full power, if not stop, loosen the spinner screw, rotate the spinner only a few degrees, tighten the screw , try again. Repeat until it runs smooth at full power. Don't over tighten the spinner screw.
dave morris is offline Find More Posts by dave morris
Old Feb 26, 2004, 09:37 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
That will only work if the rotor is out of balance too. If it's good and the spinner is not, you'll need to monkey with spinner until it runs nice. You can use pieces of tape inside of it. BTW, it helps to index the parts so you can keep track of what you're doing. Especially when it works, then you want to be able to put it back
Herb is excellent at balancing fans. His jets are the quietest I have ever not heard.
Steve C
Steve C is offline Find More Posts by Steve C
Old Feb 26, 2004, 11:06 PM
USA, NM, Carlsbad
Joined May 2002
ive tryed what you guys are saying but to no aval.
Old Feb 27, 2004, 12:17 AM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
Steve C
I like that. Quietest I have not heard
Kevin Murray is offline Find More Posts by Kevin Murray
Old Feb 27, 2004, 01:50 AM
rorywquin is offline
Find More Posts by rorywquin
Turbines suck ;-)
United Kingdom, Hillam
Joined Mar 2000
Balance the fan first using bits of tape on the inside. Once that is done test run you set up. If there is vibration , turn the spinner 90 degrees and run again. If you are sure that the fan is properly balacned you will be able to balance the complete installation by moving the spinner. When it is balanced make a mark on the fan and spinner so that you always put it back together the same way.
You will need a magnetic balancer for that small fan!
rorywquin is offline Find More Posts by rorywquin
Old Feb 27, 2004, 02:34 AM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Re: Wemotec MINI fan 480! to balance or not to balance??
... i have balanced the fan fine but when i add the spinner the thing gose wild!
You need to first balance the rotor, then the spinner on a good quality prop balancer. I use a $3 steel prop balancer from Prather. Both rotor and spinner need several small vinyl tape pieces on the inside to balance properly. I have run mine at 41+ k rpms for years.
http://www.rcgroups.com/forums/searc...der=descending
Herb is offline Find More Posts by Herb
Old Feb 27, 2004, 02:41 AM
USA, NM, Carlsbad
Joined May 2002
i have done this and the spinner still is unbalanced on both of hem i;; try it again
i think im going to run it without the spinner
Old Feb 27, 2004, 10:26 AM
Steve C is offline
Steve C's Avatar
Joined Feb 2001
I saw someone fly a Kyosho FV-1000 in Las Vegas. It sounded like an IC jet. Way out of balance! That will shorten the blades when it hits the shroud and it's bad for the motor bearings.
Spend the time. It's worth it.
Steve C
Old Feb 27, 2004, 02:53 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Heretical as this may sound.. Leave it OFF.. In real use I've found it makes little to NO actuall perf difference if it's not used.
Bare is offline Find More Posts by Bare
Sold A pair of WeMoTec Mini Fan 480 BruceGao Aircraft - Electric - Airplanes (FS/W) 5 Aug 30, 2005 06:46 PM
Wemotec Mini Fan 480 With Typhoon 2W-20? X-spec Electric Ducted Fan Jet Talk 24 Aug 30, 2005 04:31 PM
WeMotec Mini Fan 480 NIB Andy W Aircraft - Electric - Airplanes (FS/W) 9 Nov 22, 2004 08:10 AM
Wemotec Mini fan 480 RCFLYER0001 Aircraft - Electric - Airplanes (FS/W) 5 Oct 11, 2002 12:04 PM
wemotec mini-fan 480 - 18 oz. thrust?? Voyager E Electric Ducted Fan Jet Talk 10 May 01, 2001 05:03 PM
