Old Nov 14, 2013, 01:33 AM
mvd1968 is offline
Find More Posts by mvd1968
The Netherlands, NH, Nieuw-Vennep
Joined Sep 2013
Spektrum DX9 issue (spirals in to the ground)
Hi
I have some problems with my DX9 setup.
Crashed a plane when using the new DX9 with an AR6210 2 weeks ago.
After about 20 seconds it did an uncontrolled dive in to the ground.
Because i suspected an defected servo i rebuild it and flown it yesterday with my old DX6i and theAR6210.
There where no problems with this setup, flew for about 15 minutes with no loss of controls.
After that i binded my new DX9 to this AR6210. Started and within 20 seconds it took a dive again. Tried to recover but could not get it out of the spiral dive.
luckely it leveled above the ground so only the nose was damaged.
So, I am stucked now.
Any advise
mvd1968 is offline Find More Posts by mvd1968
Old Nov 14, 2013, 06:16 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Did you do any range test prior to flying? You could have rf issues that would show up in a range test.
freechip is offline Find More Posts by freechip
Old Nov 14, 2013, 08:11 AM
mvd1968 is offline
Joined Sep 2013
Did a range test with the dx6i but not with the dx9i
Old Nov 14, 2013, 09:34 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
sounds like power failure a strong possibility
richard hanson is online now Find More Posts by richard hanson
Old Nov 15, 2013, 05:34 AM
mvd1968 is offline
Joined Sep 2013
Fixed my plane and took is out today. Did the first run with the DX9 and the new AR10000. No problems or connection lost. Then I used the DX6i with this AR10000, also no problems.
Problem only occurs when using the DX9 with the AR6210
So I got to the conclusion that the DX9 does not like the AR6210. Will only use that receiver with the DX6i from now on
Old Nov 15, 2013, 08:04 AM
Mukenukem is online now
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Range test !!!!!!!!!
That is the first thing you do with a new radio with every model and every now and then if you do not use telemetry/flight log !
There is no such thing like "the DX9 dislikes the AR6210".
Mukenukem is online now Find More Posts by Mukenukem
Old Nov 15, 2013, 08:40 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
I fly a couple planes with AR6210 and DX9. That's not the problem.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Nov 15, 2013, 12:24 PM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
You must have plenty of money to spend on models.
srnet is offline Find More Posts by srnet
Old Nov 15, 2013, 01:35 PM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
How is that?
B12 is offline Find More Posts by B12
Old Feb 24, 2014, 04:35 PM
lethbrp is offline
Find More Posts by lethbrp
Joined Oct 2012
Hi
Any advise
I have a similar problem with mine. I had two lockout on two different aircraft (loosing one) with 2 different types of receiver. I suspected it was the new1.03 firmware, but have been informed that no RF changes were made in that version. Odd because I didn't have an issue with the DX9 before. I'm not happy using the transmitter now, so will send it back for testing
lethbrp is offline Find More Posts by lethbrp
Old Feb 24, 2014, 04:47 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
We haven't made any RF changes at all in the DX9. You might want to provide some information on the aircraft and configurations including receiver, power, servos, and flying style.
Andy
Site Sponsor
Old Feb 25, 2014, 12:26 AM
Mark Powell is offline
Find More Posts by Mark Powell
United Kingdom, England, Southampton
Joined Oct 2013
ALL manufacturers say do a range test. Most modellers say the same. Use a little care and commonsense in your installation, obeying the manufacturers instructions, and it should never be necessary. Sure, do one a year later to check nothing has deteriorated, or after a crash, but that's all.
It's called 'quality control' and it should be done at the r/c manufacturers factory. Ching Chang Wong r/c may not have heard of it but I am sure Spektrum do it.
Mark Powell is offline Find More Posts by Mark Powell
Reply With Quote  (Disabled)
Old Feb 25, 2014, 02:18 AM
lethbrp is offline
Joined Oct 2012
Andy
The two planes were a Parkzone Spitfire and Parkzone Mosquito. The Mosquito has the stock receiver and the Spitfire a Spektrum Sports Gyro Receiver, other than that, both planes unmodified. The flying field is a farmers field with no trees or obstacles (flat land), straight line of sight to both aircraft. The aircraft lost signal in pretty much the same area approx quarter of a mile from me. The mosquito, fortunately had enough height to regain signal. The Spitfire wasn't able to regain signal before hitting the ground. The flying style was plain circuits, no aeros involved.
Old Feb 25, 2014, 03:07 AM
Vienna, Austria
Joined Oct 2010
Did you check the LEDS on the rx or was the battery disconnected during the crash ? You probably had no telemetry on it ? It's a pity the 635 does not support flight log.
I think most ESCs have linear BECs. I had lots of issues with linear BECs and replaced all with ESCs with a switching BEC. They are more reliable, at least for me.
Old Feb 28, 2014, 04:53 PM
lethbrp is offline
Joined Oct 2012
1.4
I notice that within a week I have received notification of two fireware updates. I applaud Spektrum for adding new functionality, but are we sure these are being adequately tested in such a short timeframe. By their own admission it's complex code. I'm not keen on loosing more models. I think I'll wait and see how this works in the wider community.
Discussion Will there be a Spektrum DX9? miksterr Radios 67 Aug 10, 2015 09:57 AM
Sold Spektrum DX9 (new in box) PatternFlyer Aircraft - General - Radio Equipment (FS/W) 2 Nov 10, 2013 02:22 PM
Discussion Spektrum DX9 display issue harrry66 Radios 3 Oct 07, 2013 09:49 AM
Discussion Lindsey Graham: Republicans ‘are in a demographic death spiral’ Broken Wings Life, The Universe, and Politics 23 Jun 17, 2013 12:03 PM
GWS BN-2 spiralled into the ground :( microflite Parkflyers 0 Feb 22, 2004 08:41 PM
