Old Nov 13, 2013, 05:52 PM
jcowgar is offline
Find More Posts by jcowgar
United States, OH, Norton
Joined Aug 2013
Good ESC with BEC, is separate BEC required?
Say you have a good ESC with a 5A BEC, is it still recommended to use a separate BEC? For example the Castle Creations Talon 35.
If so, why?
I am trying to think of ways to eliminate equipment in my new Sirius FPV build but do not want to do so at the expense of reliability.
Thanks!
jcowgar is offline Find More Posts by jcowgar
Old Nov 13, 2013, 06:27 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If you have a lot of high drain servos you may exceed the 5A BEC capability. A stand alone UBEC provides good insurance especially where you are using high voltage (>4s)
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 13, 2013, 06:48 PM
jcowgar is offline
Joined Aug 2013
In a situation where 5A were enough. For example, I was going to install a 5A BEC. Would a 5A BEC internal to the ESC be any better/any worse than an external 5A BEC?
Old Nov 13, 2013, 07:53 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
IMO, no worse if you are not planning to use a separate battery to power an external SBEC. and potentially better as you don't have an extra solder connection with dissimilar wires slicing the SBEC into the power leads. And regardless of whether it is external or internal, SBEC capacity up to their rated input voltage is not much affected by that voltage, eg 2s or 6s, unlike linear BECs which suffer from much lower output as input voltage increases.
And as long as you ensure your surfaces and linkages are not binding, you'll be surprised by how low actual servo current draw is, especially on the relatively low speed, low manoeuvring of fpv.
scirocco is online now Find More Posts by scirocco
Old Nov 14, 2013, 02:22 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
If the BEC in your ESC is a switching one and is enough for your needs, the only advantage of a stand-alone BEC is that it won't fail if the ESC smokes.
abenn is offline Find More Posts by abenn
Found 60A ESC for Trex 500 $50 shipped, No BEC required AndyFly01 Aircraft - Electric - Power Systems (FS/W) 2 Apr 20, 2013 08:46 AM
Question ESC with BEC & Separate RX power supply jonathan7x70 Power Systems 4 Jun 23, 2011 09:38 AM
Discussion Higher Amp ESC/BEC combo Vs lower Amp ESC + separate BEC DMala Micro Helis 2 Dec 09, 2010 03:20 PM
Question Using ESC/BEC With a Separate BEC? T3chDad Power Systems 9 Sep 08, 2008 07:38 AM
Sold Jazz 80 ESC with separate BEC verticalflight Aircraft - Electric - Helis (FS/W) 0 Apr 20, 2008 07:19 PM
