This thread is privately moderated by jrb, who may elect to delete unwanted replies.
Old Sep 16, 2004, 05:11 AM
flo is offline
flo
Find More Posts by flo
flo
flo's Avatar
Near Munich Germany
Joined May 2003
one more
enjoy
flo
flo is offline Find More Posts by flo
Old Sep 16, 2004, 06:57 AM
BandDButton is offline
Find More Posts by BandDButton
BandDButton's Avatar
Rogers AR
Joined Jan 2004
flo,
Just beautiful, Thanks for the pictures!
Darrell
BandDButton is offline Find More Posts by BandDButton
Old Sep 16, 2004, 07:41 AM
olmod is online now
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
complete with wing walker ;-) magnificent
olmod is online now Find More Posts by olmod
Old Sep 16, 2004, 01:12 PM
dmr1954 is offline
Find More Posts by dmr1954
Hartsville, South Carolina, United States
Joined Sep 2004
I'm new to this messaging stuff. Hope I'm doing it right. I have a question I hope someone can help me with. When measuring amp draw the prop is in a static state. Current is high. When the plane is moving, the prop is unloaded and current is low. Static on mine is around 9 amps. Calculated draw after a flight is around 3 amps. Calculated using time in flight and amps put back into the battery. The charts I see posted give high amp ratings. Is the posted amps the Static amps?
dmr1954
dmr1954 is offline Find More Posts by dmr1954
Old Sep 16, 2004, 04:31 PM
flo is offline
flo
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Wingwalker
HI olmod
funny little fellow isn`t he
I havn`t noticed him before as i usually just look at the bigger pics of 2+megs and this particular 2 were further reduced of original 0,4 meg pics taken from a friend.
@dmr1954
usually charts of motor datas show static ampdraw
greetings from munich
flo
Old Sep 17, 2004, 01:12 PM
bouncer1 is offline
Find More Posts by bouncer1
massachusetts
Joined Apr 2004
Is it possible to run two brushless motors off one BL contoler?? I haven't tried it yet.
bouncer1 is offline Find More Posts by bouncer1
Old Sep 17, 2004, 01:38 PM
crashsiegel is offline
Find More Posts by crashsiegel
Tree? That's a Tx weed!
crashsiegel's Avatar
Central Texas
Joined Apr 2003
Sometimes yes but usually no.
There are occasional reports of 2 BL motors working on 1 controller (parallel) but usually the reports are negative. Most common are starting issues (one does, one doesn't).
Better to configure 1 motor with 1 controller x2 and connect to the rx with a Y cable - BUT remember to disable one or both BEC circuits if the controllers have them (remove the controller's red wire from the connector at the Y cable). You do not want 2 BEC's trying to power the system - will cause problems.
You can use 1 or 2 motor batteries. But if you use 1 battery be sure it can supply the amps for both motors without an issue.
You really want to keep the wires short as long wires cause problems for the controller and rx. Consensus seems to be that long battery wires are the worst.
Hope this helps,
Crash
crashsiegel is offline Find More Posts by crashsiegel
Old Sep 17, 2004, 01:56 PM
bouncer1 is offline
massachusetts
Joined Apr 2004
yea it does, I was wondering cause Im trying to save weight(who isnt). I saw a couple of BL motors that would replace the stock motors in my superflea edf. I guess one more controler won't hurt the weight factor.
Old Sep 17, 2004, 03:45 PM
Protocooler is offline
Find More Posts by Protocooler
sloping addict
Protocooler's Avatar
France
Joined Feb 2003
Yes I can attest that it does - and with 2 Outrunners at that. The startup works about 9/10, but works not as good with some sidewind. Does not work with different props of course. I think ESC was a MGM compro TMM and motors were two Axis, but unsure.
It is recommended to keep a little bit of throttle at all times, otherwise it can occur ocassionally to be unable to restart.
Here's a pic of this magnificent and home made model. It flies extremely well, think it was on 2*3S Lipos with power to spare (more than 200W per kg). Retract gear, home made !
But this is not mine
Protocooler is offline Find More Posts by Protocooler
Old Sep 17, 2004, 04:28 PM
IT Flyer is offline
Find More Posts by IT Flyer
Joined Aug 2004
Wow, "9/11-Incredible video with facts!" in a few days from 629 to 1282 hits.
A great success.
I agree with Contest 2004. The two Twin Towers could not crash that way because of some ridiculous Boeing 757, very ridiculous with regard to the immense weight of the two skyscrapers.
Vittorio from Italy
IT Flyer is offline Find More Posts by IT Flyer
Old Sep 19, 2004, 08:45 AM
dmr1954 is offline
Joined Sep 2004
Is there an advantage to using a 12 pole stator over a 9 pole stator? This is in a CD Rom go brushless motor. 25mm
Old Oct 04, 2004, 11:09 AM
electroboy is offline
Find More Posts by electroboy
can ya do that??...
electroboy's Avatar
California
Joined Jan 2004
A-7
Model/subject:A-7 II Flying Styro
Motor:ModelMotors MiniAC 1215/16
Speed Control:Jeti 18-3p
Cell type/count:Lipoly 3s1p
Prop/fan:vasa55
Reduction method and ratio:
Amps: 14
Watts:145
RPM:?lots
Weight Read to Fly:15 oz.
Picture:http://img.photobucket.com/albums/v3...A7LTqtview.jpg
Comments, etc.: Flies great with above setup. Fan is buried approx. 1.5" aft of wing TE with mylar ducting aft of fan to smooth flow. That alone made a big difference in resultant thrust and speed. 2"x2" cheater hole on bottom fuse cut along molded panel lines1" in front of fan lip.
Hatch secured with 3 rare earth magnets, clean and strong.
Controlled with Airtronics Stylus system,PCM rec'r 92186, Hitec HS85s x3
electroboy is offline Find More Posts by electroboy
Old Oct 05, 2004, 11:51 AM
Serial Krasher is offline
Find More Posts by Serial Krasher
Love new planes
Serial Krasher's Avatar
Valencia, Spain
Joined Aug 2004
1.5 m. glider: Kyosho Soarus 1600
Model: Kyosho Soarus 1600
Motor: Jamara 480 Pro HS BB
Gearbox: Jamara 4:1 planetary
Propeller: folding 11x8
Battery: Sanyo NiMH 2300 AA
AUW: 28 oz. (830 gr.)
With this combination, the plane goes up there in 20-30 seconds .
Serial Krasher is offline Find More Posts by Serial Krasher
Old Oct 06, 2004, 02:43 AM
Love new planes
Valencia, Spain
Joined Aug 2004
Oops, I forgot to mention full throtle rpm of the above mentioned setup: 5100-5200 rpm at the first 20-30 seconds, then 4900-5000 rpm for the following minutes, until the pack gets flat.
Old Oct 07, 2004, 06:11 AM
minifly is offline
Find More Posts by minifly
Robots... robots everywhere
minifly's Avatar
Switzerland, VD, Lausanne
Joined Jan 2003
model: edge-rc devestator
motor: mega 16/15/4C (has a 5mm shaft vs. 3.2mm, C stands for combat)
prop: graupner 6X5.5 speed (NOT CAM prop)
batts: 9 X 1800HECells ni-mh
esc:cc25, normal timing, fast start
16k rpm, but unloads a LOT in flight
6-7 mins of full throttle, usually about 20 mins flight time per charge
amps, auw unknown
comments: almost unlimited vertical, VERY fast in flight, great manuverability, about 100 mph, but still good low speed handling, although acceleration is not great until i get some speed up.
several other pilots have had frights (sorry, flights ) on it, all agree that power setup is awsome...
minifly is offline Find More Posts by minifly
Discussion from Successful Power Systems e-geezer Power Systems 3 Sep 21, 2014 03:32 AM
Successful Power Systems sandburr Power Systems 0 Jul 31, 2005 06:57 PM
Successful Power Systems II superflyX Power Systems 0 May 18, 2005 11:47 PM
Another question from Successful Power Systems helisfreak Power Systems 1 Apr 16, 2004 10:28 AM
Discussion removed from Successful Power Systems thread SharksTooth Power Systems 4 Apr 15, 2004 11:45 AM
