This thread is privately moderated by jrb, who may elect to delete unwanted replies.
Old Jul 19, 2004, 01:20 PM
Don Leitz is offline
Find More Posts by Don Leitz
West Chester, OH USA
Joined Jan 2000
Hangar 9 Ultra Stick
Model/subject: Hangar 9 Ultra Stick 40
Motor: Plettenberg Orbit 25/18 Outrunner
Speed Control: Jeti Advance Opt 40
Cell type/count: 16xGP3300
Prop/fan: APC-E 14x10
Reduction method and ratio: Direct Drive
Amps: 39
Watts: 650
RPM: Not measured
Weight Ready to Fly: 101 ounces
Comments: Easy conversion, flies just like the .40 glow version with very good vertical and just a little less top end. Motor is very smooth and well made - a definite step up from an AXI.
Thread on this conversion here: http://www.rcgroups.com/forums/showt...60#post2407660
Don
Don Leitz is offline Find More Posts by Don Leitz
Old Jul 25, 2004, 11:16 PM
gfcermak is offline
Find More Posts by gfcermak
gasless
Seattle area
Joined Jun 2004
GWS A-10 Warthog
Model/subject: GWS A-10 Warthog, greatly strengthened with carbon spars in fuselage and wings, 0.75oz fiberglass over everything.
Motor: 2x Himax 2025 2700kV, with 2x Hacker B20S heatsinks per motor
Speed Control: 2x Castle Creations Phoenix 25, low advance timing for extra efficiency, LVC=18.0 volts
Cell type/count: Lipo Kokam 2000 15C 6S1P
Prop/fan: 2x Vasa 55
Reduction method and ratio: n/a
Amps: 17A per fan, ~34A total
Watts: ~700 at start
Thrust: > 1200g
RPM: ~42000 (from video doppler)
Weight Ready to Fly: 39 ounces
Comments: This is a powerful pair of ducted fans! This setup definitely needs heatsinks - the 24mm outer diameter heatsinks for hackers allows the motors a nice fit in the Vasa motor tubes (also 24mm). Did maiden flight today - 4 flights actually, until hard landing ripped off both nacels cleanly - no other damage. It easily flies level at 1/2 throttle, and can loop continuously at 3/4 throttle. Hand launch is possible, will not ROG from grass with skids - these need pavement.
videos: http://rcgroups.com/gallery/showgall...0&ppuser=34746
-Gerry
gfcermak is offline Find More Posts by gfcermak
Last edited by gfcermak; Jan 14, 2005 at 11:48 AM. Reason: upgraded cells from TP2100 5S to Kokam2000 6S
Old Jul 25, 2004, 11:32 PM
Dhughes is offline
Find More Posts by Dhughes
Columbus University, Ohio, United States
Joined Jul 2003
Alfa MiG15
Model/subject: Alfa MiG15
Motor: Himax 2015-5400
Speed Control: CC25, low timing.
Cell type/count: Tanic 3s1p 1550
Prop/fan: Stock
Amps: 14, estimated
Watts: 150, estimated
Thrust: 14oz, estimated
RPM: ~50k
Weight Ready to Fly: 13oz
Comments: I am not too sure about these numbers, most are deduced from the battery temp. I can however tell you that this setup makes for an extremly light aircraft that will fly straight up effortlessly. The key to being able to use such a hot wind motor is drilling air holes in the front of the motor mount and drilling out the rear of the motor mount, this allows for a very severe airflow moving around and past the motor keeping it very cool. I have even flown this plane with a Tanic 4s1p pack WOT up until the wings ripped off and it destroyed itself. This did however allow for me to immediatley check the motor temp and it was just a little hot maybe 110-120F.
-David
Dhughes is offline Find More Posts by Dhughes
Old Aug 09, 2004, 01:10 PM
simingx is offline
Find More Posts by simingx
now that's a wattmeter...
simingx's Avatar
Singapore
Joined May 2002
Model/subject: Filip 600 Sport
Motor: Lehner "Basic" 4200
Speed Control: Schulze future 12.46e, 9kHz, soft timing
Cell type/count: Sanyo RC3300HV x8
Prop/fan: Graupner 12x6 folding
Reduction method and ratio: Maxon 4.4:1
Amps: around 30+
Watts: 240?
Thrust: Not known
RPM: Not measured
Weight Ready to Fly: Not measured, but it's a 2m sailplane...
Very good climb for a plane this size, and the low amp draw makes sure the battery comes out only as warm as when it went in...
Video here: http://rcgroups.com/gallery/data/500/30579080804_F6.wmv (6MB)
simingx is offline Find More Posts by simingx
Old Aug 14, 2004, 11:42 AM
AeroNut45 is offline
Find More Posts by AeroNut45
AeroNut45's Avatar
Australia, VIC, Keysborough
Joined Jun 2004
Model/subject: Indoor/parkflyer /aerobatic sports plane
Motor:CD 20mm dia
Speed Control: TMM 8
Cell type/count: 2s1p 1200 E-tec
Prop/fan: 8x4 HD
Amps:5amps
Watts:36
Thrust: 265g
RPM:guess 6600
Weight Read to Fly: 264g
Great fun, ample power ( not 3D)
AeroNut45 is offline Find More Posts by AeroNut45
Old Aug 26, 2004, 12:40 PM
tho98027 is offline
Find More Posts by tho98027
tho98027's Avatar
Joined Aug 2004
Model/subject: House of Balsa electric P-51 w/retracts
Motor: Mega 16/15/3
Speed Control: CC phoenix-25
Cell type/count: Tanic 5s 2500mh
Prop/fan: 11x8.5
Reduction method and ratio: Mec superbox 5.0:1
Amps: 28 estimated
Thrust: 84 oz
Weight Ready to Fly: 56 oz
Performance: insane!
tho98027 is offline Find More Posts by tho98027
Old Aug 29, 2004, 11:25 PM
207 is offline
207
Find More Posts by 207
207
Unreconstructed
Chickamauga, GA
Joined Jul 2004
Model/subject: Top ModelCZ Electro Kulbutin Motor:Plettenberg Orbit 20/14 Speed control: Jeti Advance 70 3p Cell type/count: Thunder power 6000mah 3s3p or two LightflightRC Irate 3000mah 3s2p's in parallel Prop/fan:Graupner folding 13x10 Reduction method and ratio: Direct drive Amps: 64 amps static Watts:500+ Thrust:n/a RPM:n/a Weight ready to fly: 2.5kg+ est. Comments: Wwaaaaahhoooooo!!! Ok, I tried to line this up like everyone else, Oh well
207 is offline Find More Posts by 207
Old Sep 01, 2004, 09:42 PM
RC4_LIFE is offline
Find More Posts by RC4_LIFE
3D Wannabe
RC4_LIFE's Avatar
Temple, TX
Joined Sep 2004
Model/subject: FFF aerobatic sports plane
Motor:Himaxx 2015-5400
Speed Control: CC25
Cell type/count: 11.1V Kokam 1500
Prop/fan: 10x4.7 HD
Reduction method and ratio: GWS 6.61
Amps:10 amps
Watts:?
Thrust: 20oz +
RPM: no idea
Weight Read to Fly: 17oz
The most fun flying plane that I've built so far.
RC4_LIFE is offline Find More Posts by RC4_LIFE
Old Sep 01, 2004, 11:05 PM
ThinnedDope is offline
Find More Posts by ThinnedDope
Albuquerque, NM
Joined Aug 2004
Model/subject: 2m Sailplanes such as Astro Challenger
Motor: Trinity Serpentine 14 Turn
Speed Control: Jeti JES 500
Cell type/count: 7-cell 1950 mA-Hr Ni-mH
Prop/fan: Aero-Naut 13.5" x 7" carbon folding
Reduction method and ratio: : MP JET MPJ 8063 3.8:1
Amps: 45 Amps
Watts: about 300W
RPM: 5800 (I think)
Weight Read to Fly: 38 - 42 oz
Comments: Advance motor timing 22 degrees. Some additional details with previous CP1300 battery can be seen at:
http://www.soarabq.org/projects.shtml#astro_challenger
Will climb vertically, but optimum climb rate will get about 1400 ft/min. 900-1000 feet for a 7-cell, F5J 40 second climb. I fly at 5500 feet, so smaller prop or higher turn motor may be appropriate for sea level.
ThinnedDope is offline Find More Posts by ThinnedDope
Old Sep 08, 2004, 02:44 PM
bnl2001 is offline
Find More Posts by bnl2001
Gravity Always Wins...
bnl2001's Avatar
Medina, Ohio
Joined Jun 2003
Model/subject: MountainModels Flashback II
Motor: RZ-2500
Speed Control: CC-25
Cell type/count: 8 and 9 cell KANs 950s/1050s
Prop/fan: APC 11x8.5 TE
Reduction method and ratio: Himax gearbox including Himax pinion and spur gear with 5x1 reduction.
Amps: ?
Watts: ?
RPM: ?
Weight Read to Fly: 16oz
Unlimited vertical with 9 cell KANS. Still good vertical performance with 8 cell KANS. Even Himax spur gear is not strong enough. Spur gear developed problem after about 20 flights. GWS spurs only last about 10 flights with this setup. Still looking for a quality gearbox setup.
bnl2001 is offline Find More Posts by bnl2001
Old Sep 14, 2004, 11:16 PM
klong66 is offline
Find More Posts by klong66
Joined Aug 2004
Model/subject: Unicorn
Motor: Mega 16/15/4
Speed Control: CC ESC 35
Cell type/count: 12 cell GP 1100
Prop/fan: 6x4 and 7x4
Amps: ?
Watts: ?
RPM: ?
Weight Read to Fly: ?
Flys great with the 6x4 and even better with the 7x4 but for a much shorter duration.
klong66 is offline Find More Posts by klong66
Old Sep 15, 2004, 05:48 AM
nibbio is offline
Find More Posts by nibbio
Francesco
nibbio's Avatar
Italia, Lazio, Ardea
Joined Sep 2004
Multimotor set up
For a multimotor set up this is my experience:
model : B29 scratch built
w/s : 106 inches
weight : 12 lbs
motor : 4x speed 600
prop : 9x5 slim prop direct drive
cells : 28 Ni-Cd 1600 mAh ( four packs)
amps : 25 A on ground test
flight : 5 minutes
with this set up plenty of power, good climb and half throttle for a cruise flight.
regards
nibbio is offline Find More Posts by nibbio
Old Sep 15, 2004, 11:58 AM
flo is offline
flo
Find More Posts by flo
flo
flo's Avatar
Near Munich Germany
Joined May 2003
EXCALIBUR III no pics :(
Hi:
My plane is scratchbuild semiscale after The ExcaliburIII B-Mustang.
Wingspan 1,80 m
L: 1,59 m
w 5,25 kg
Motor Lehner 1940/10 bl
Gear Reisenauer "Superchief" 6:1
Prop 4bl 15,2x10,5 Ramoser "Varioprop"
Rpm 7400
Bat 9s3p 6000mah Thunderpower (3X 3s3p)
controller Jeti 77 3po (?)
Power 30v x 50 A= 1500W and around 7,2kg trust
retracts, flaps 9 servos around
great flyer, quite tame, no nasty habits, plane is relativly new (4 flights sofar) which took about 2300 mah back after 9 mins of mixed flights.
I have tons of pics but unfortunately the files are too large!
greetings from munich
flo
flo is offline Find More Posts by flo
Old Sep 15, 2004, 01:53 PM
BandDButton is offline
Find More Posts by BandDButton
BandDButton's Avatar
Rogers AR
Joined Jan 2004
Pics!!
flo,
We need to see your pics!!
Just open them into paint, and then rescale them to about 25%, save them and then post them at the new size. Works great.
Darrell B.
BandDButton is offline Find More Posts by BandDButton
Old Sep 16, 2004, 06:10 AM
flo is offline
flo
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Pics
hi darrell,
attached some pics of Esxalibur III.
unfortunately the quality is not as desired, but i don`t have paint and the photoshop trial isn´t suppórting "rescale"- just "cutouts". Thus i had to use the smallest files. for now they will just have to do.
flo
Discussion from Successful Power Systems e-geezer Power Systems 3 Sep 21, 2014 04:32 AM
Successful Power Systems sandburr Power Systems 0 Jul 31, 2005 07:57 PM
Successful Power Systems II superflyX Power Systems 0 May 19, 2005 12:47 AM
Another question from Successful Power Systems helisfreak Power Systems 1 Apr 16, 2004 11:28 AM
Discussion removed from Successful Power Systems thread SharksTooth Power Systems 4 Apr 15, 2004 12:45 PM
