This thread is privately moderated by jrb, who may elect to delete unwanted replies.
Old May 26, 2004, 02:41 PM
climber9 is offline
Find More Posts by climber9
Sierra Nevada foothills of California
Joined Dec 2003
Modeltech Magic
Motor: Mega 22/45/3
Speed Control: Phoenix 60
Cell type/count: 10 cell GP3300 NiMH
Prop/fan: 11x7 and 13x8
Reduction method and ratio: Direct Drive
Amps: 27A for 11x7; 38A for 13x8
Watts: dunno
RPM: dunno
Weight Read to Fly: 5.1 lbs
On the bench, I measured 7 minutes runtime at full throttle with the 11x7. The 13x8 gave me 5m45s at full throttle on the bench. However, at the field I flew the Magic comfortably at half throttle with the 13x8 for nearly 10 minutes. Almost enough power to hover, but not quite. The 11x7 needed more than 1/2 throttle, and didn't have the necessary thrust to do acrobatics.
climber9 is offline Find More Posts by climber9
Old Jun 03, 2004, 02:04 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Model: Carl Goldberg Eagle II ARF
Motor: Jeti Phasor 45-3
Speed Control: Jeti Gold Label 40-3P
Cell type/count: 12xRC2000/P3000
Prop/fan: APC E 12x8
Amps: 31
Watts: 406
RPM: 7.7k (calc)
Weight RTF: 6#-13oz (6.8#, 109oz)
Comments, etc.: Very nice trainer performance @ to 2/3s throttle, also quite quiet. Loops and rolls easily, take-off roll is comparable to glow. Built by my friend Rick for his entry into RC; motor installation and RTF details by me. Plenty of power for me as his IP; might go up to an APC E 13x8 if he goes to a glow IP. See video of a Take Off; "zip" file contains a wmv.
jrb is offline Find More Posts by jrb
Old Jun 04, 2004, 04:46 AM
Insagor is offline
Find More Posts by Insagor
Why'd it do that?
Insagor's Avatar
Erin, WI
Joined Mar 2004
Het-RC Yak 480 Brushless
Model: Het-RC Yak
Motor: Cermark Brushless 480
Battery: ThunderPower 3S 2100mAh
Prop: APC SF 8x3.8
ESC: Phoenix 25
RPM: 11200
http://www.geocities.com/mohr_dave/yak.html
Insagor is offline Find More Posts by Insagor
Old Jun 05, 2004, 09:49 AM
M Ashmore is offline
Find More Posts by M Ashmore
Average User
M Ashmore's Avatar
Bakersfield, California
Joined Aug 2003
Model/subject: 60" Spad - Foam Clark Y High Wing, Gutter Pipe Fuse, Coro Tail
Motor: Kyosho Endoplasma
Speed Control: CC Griffin 55
Cell type/count: 3 paralleled 10xKan950
Prop/fan: 11x7 MAS Electric
Reduction method and ratio: Great Planes GD600 3.8:1
Amps: 39 Measured - AF Whattmeter
Watts: 410 Measured - AF Whattmeter
RPM: dunno - need to get a tach
Weight Read to Fly: 5# 4oz.
ROG in 40 feet at 3/4 throttle. 10+ minutes flight time at average 1/2 throttle.
M Ashmore is offline Find More Posts by M Ashmore
Old Jun 13, 2004, 10:12 PM
irone is offline
Find More Posts by irone
irone's Avatar
Arlington, Texas
Joined Mar 2004
Here is something a little different.
Model/subject:A Shock Flier cut out of blue foam
Motor:A small CD Rom motor without ball bearings, re-wound with 10 turns of #24 wire.
It is using the original BLACK magnet ring and is turning an 11 X 4.7 GWS prop, it hovers the plane at half throttle with a 2cell lipo pack pulling 3.5 to 4 amps.
Speed Control:Phoenix 10 brushless
Cell type/count:Lipo 1200ma with 2cells
Prop/fan: 11 X 4.7
Reduction method and ratio: 6.6 to 1
Amps: 3.4 to 4
Watts:
RPM:
Weight Read to Fly: All up 10 oz.
Picture: No pictures available today.
If there is any interest in this combo I post pics and more info.
irone is offline Find More Posts by irone
Old Jun 18, 2004, 11:52 PM
Bill Sanford is offline
Find More Posts by Bill Sanford
Destructive testing expert!
Bill Sanford's Avatar
Bemidji, MN
Joined Dec 2003
Hanger 9 Funtana 40
AXI 4130/16
TP 5s3p ; 5700 mah ; 8-10c
CC Phoenix 80
APC 18x8e
17.8 Volts
41 Amps
5760 RPM
Static thrust is 8 lbs 15 oz
Unlimited vertical - MUCHO THRUST!
Kyosho Cub (40 sized)
AXI 4120/14
10 cell GP 3300 pack
CC Phoenix 80
APC 14x10e
10.8 Volts
37 Amps
6000 RPM
Static thrust - Haven't measured yet.
Won't prop hang, but a very good flier...
Bill Sanford is offline Find More Posts by Bill Sanford
Old Jun 19, 2004, 02:06 AM
Average User
M Ashmore's Avatar
Joined Aug 2003
Model/subject: JK Aerotech T52
Motor: Kyosho Atomic Force
Speed Control: CC Pegasus-35P
Cell type/count: 8xKan1050, 8xCBP1800, 10xKAN950
Prop/fan: 9x7 MAS
Reduction method and ratio: Great Planes GD600 3.0:1
Amps: 22 Measured - AF Whattmeter
Watts: 187 Measured - AF Whattmeter
RPM: dunno - still need to get a tach
Weight Read to Fly: 38oz.
Old Jun 19, 2004, 07:14 PM
crashsiegel is offline
Find More Posts by crashsiegel
Tree? That's a Tx weed!
crashsiegel's Avatar
Central Texas
Joined Apr 2003
Model/subject: JK Aerotech Big-T
Motor: AXI 4120/14
Speed Control: CC Phoenix 45A
Cell type/count: 12xRC2400 (weak, 6-8 minutes), TP 4S4P 7.8Ah or 8.2Ah (Strong, you get tired before it does)
Prop/fan: 12x8 E (APC or MAS)
Reduction method and ratio: N/A Outrunner
Amps: (using APC 12x8E, measured - AF Whattmeter)
12xRC2400 = 32.2A @ 12.5V
TP 4S4P 8.2Ah (20 flights) = 41.4A @ 14.4V
Watts: (using APC 12x8E, measured - AF Whattmeter)
12xRC2400 = 396W
TP 4S4P 8.2Ah (20 flights) = 589W
RPM: (using APC 12x8E, measured - Globee Tach)
12xRC2400 = 7260 rpm
TP 4S4P 8.2Ah (20 flights) = 8010 rpm
Weight Read to Fly:
12xRC2400 = 107oz
TP 4S4P 8.2Ah (20 flights) = 101oz
An incredible trainer type flyer. 1/2 throttle and it flies well, WOT and it climbs with authority! And very TOUGH. With the lipo pack it will fly longer than you want to. I have not run the a pack down yet (never gotten weak or cutoff - programmed 4S) even after 4 flights on the SAME pack.
Crash
crashsiegel is offline Find More Posts by crashsiegel
Old Jun 23, 2004, 01:55 AM
Protocooler is offline
Find More Posts by Protocooler
sloping addict
Protocooler's Avatar
France
Joined Feb 2003
Home made sailplane, AUW 1870g, 2.27m span
Mega 16/25-3, Maxxon gearbox 4.4:1, Aeronaut 17*13 folder
14 cells Sanyo FAUP 1950
70A ESC and Ubec
about 42 A / 550W input
Goes straight up at about 14 m/s for 2'20 runtime. Lots of climbs. 40 minutes flights on a pack with some aerobatics.
Protocooler is offline Find More Posts by Protocooler
Old Jun 25, 2004, 12:53 AM
kennyc is offline
Find More Posts by kennyc
kennyc's Avatar
Joined Feb 2004
Model/subject: GWS E-STARTER
Motor: Himax 2025 4200
Speed Control: CC phx 25
Cell type/count: Kokam 3S 1500
Prop/fan: APC 9x7.5 SF
Reduction method and ratio: 5.33:1 (GWS 350 C Gear)
Amps:
Watts:
RPM:
Weight Read to Fly: 15Oz All UPz
Comments and links to other forums for more info, video, etc.
Etc.
great plane to fly! if you are a begginner and have been flying stock... putting this in will give it a whole new life!
kennyc is offline Find More Posts by kennyc
Old Jun 25, 2004, 06:01 AM
Insagor is offline
Why'd it do that?
Insagor's Avatar
Erin, WI
Joined Mar 2004
Sig Cadet 20 Conversion
Sig Cadet 20 (no modifications for saving weight)
Motor: AXI 2808/24
Battery: Thunder Power 3S 2100mAH
Speed Control: CC Phoenix 35 (overkill)
Prop: 9x4.7 APC SF
RMP: ~8400
Flight time: 15 minutes and counting
Notes: Will add more info for thrust and plane weight shortly. Take-off from grass is <8 Feet
Old Jun 30, 2004, 12:59 AM
Dhughes is offline
Find More Posts by Dhughes
Columbus University, Ohio, United States
Joined Jul 2003
Model/subject: GWS TM-400
Motor: Himax 2825-3600
Speed Control: CC35
Cell type/count: Tanic 4s1p2200
Prop/fan: MA 10x6 wood
Reduction method and ratio: Cobri 4.11
Amps: 28 est
Watts: 380 est
RPM: 10k est
Weight Read to Fly: 23.5oz
Comments and links to other forums for more info, video, etc. Heavily reinforced with planks of basswood along both sides and bottom of the fuse. Flies just fine with only 3 cells. Rock solid in moderate winds. Scares my kids.
-David
Dhughes is offline Find More Posts by Dhughes
Old Jun 30, 2004, 04:28 AM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Model/subject: SKY RAIDER MACH-II by THE WORLD MODELS, LTD.
54 inch wing span (Fully Symmetrical wing design)
KYOSHO ENDOPLASMA 16-Turn MOTOR (Timed to the best reverse rotation)
GD-600 Gearbox with the 3.8:1 optional pinion gear.
APC "E" 11 X 8.5 Prop.
MPI Heat Sink, Motor Mount combo.
Great Planes C-50 Brush Motor ESC.
HITEC 555 Dual conversion receiver (Hitec shift)
Using a HITEC Flash 4 Transmitter with 2-model memory.
HITEC HS-85 MG for Aileron set and for elevator & HS-81 for rudder.
8-Cell, GP-3300mAH (Average Flight Duration: 11 minutes with reserve)
@WOT: 34 AMPs & 300 WATTS (ASTRO FLIGHT WATT METER)
Prop Speed: 7100 RPM
Total flight ready weight 70 3/8 oz. or ~ 4.4lbs. (Actual measure value)
http://www.rcgroups.com/forums/showt...4&page=1&pp=10
This model has great controlled manners, characteristics and I was very comfortable even during my first (maiden) flight. I was flying her and it almost seemed like I have been flying her all along. (Thanks to the high wing Sport model, SKY RAIDER MACH-I)
SKY RAIDER MACH-II turns like if she is on rails and they are crisp and with a controlled look to them without any tail wobble or any other bad habits. Loops are just super and can be as large as you set power to them. She flew for 10 and a half minutes for the maiden and landed with lots of reserve.
July 13, 2004 UPDATE:
9 minutes and 47 seconds of a static run with an 8-cell, GP-3300mAH, Ni-MH pack and ENDOPLASMA in the GD-600 gearbox with 3.8:1 ratio and the APC "E" 11 X 8.5 prop. ( I still had lots of power reserve )
Measured AMPs (Fresh Battery) @ WOT: 31 AMPs in-rush / 29 AMPs steady.
Measured pack Voltage off the charger: 11.45 Volts - 2 Volts load= 10.45 Volts
10.45 Volts X 29 AMPs = 303 WATTS Actual. Wow!
303 WATTS / 4.4 lbs. = 68.86 WATTS per Lbs. !
Not bad at all for a cheap $125.00 'BRUSH' power setup!
July 14, 2004 Update:
3 minutes and 10 seconds of a static run with an 10-cell, GP-3300mAH, Ni-MH pack and ENDOPLASMA in the GD-600 gearbox with 3.8:1 ratio and the APC "E" 11 X 8.5 prop.
Measured AMPs (Fresh Battery) @ WOT: 39.6 AMPs in-rush / 39 AMPs steady.
Measured pack Voltage off the charger: 13.9 Volts - 2 Volts load= 11.9 Volts
11.9 Volts X 39 AMPs = 464 WATTS Actual. Wow!
464 WATTS / 4.64 lbs. = 100 WATTS per Lbs. !
Again, not bad at all for a cheap $125.00 'BRUSH' power setup!
guapoman2000 is offline Find More Posts by guapoman2000
Old Jul 04, 2004, 06:50 PM
SharksTooth is offline
Find More Posts by SharksTooth
Aerobatic Extremist
SharksTooth's Avatar
United States of America For Which We Stand!
Joined Jan 2004
Fredy check your PM's. You have mail!
New Power System
Model/subject: GW 45" 330LX
Motor: Lehner 1020/15
Speed Control: Castle Creations Phoenix 25
Cell type/count: Tanic 3s2200
Prop/fan: APC 12x6 Slo Fly
Reduction method and ratio: Cobri 28 GB, 6.33:1 (76T/12T Stainless)
Amps: 25.1
Watts: 228
RPM: Right Around 6000 if memory serves
Weight Ready to Fly: 21 oz
Etc.
Picture, and comments will come shortly. Model is brand new!
SharksTooth is offline Find More Posts by SharksTooth
Old Jul 13, 2004, 05:51 PM
Insagor is offline
Why'd it do that?
Insagor's Avatar
Erin, WI
Joined Mar 2004
Sig Cadet 20
Electric conversion
Motor: AXI 2808/24
Battery: TP 2s 2100maH
Controller: Castle Creations Phoenix 35
Prop: 9x4.7 APC SF
RPM: 8800
Flight time: In excess of 20 minutes
Video: http://www.geocities.com/mohr_dave/RCPage.html
Discussion from Successful Power Systems e-geezer Power Systems 3 Sep 21, 2014 03:32 AM
Successful Power Systems sandburr Power Systems 0 Jul 31, 2005 06:57 PM
Successful Power Systems II superflyX Power Systems 0 May 18, 2005 11:47 PM
Another question from Successful Power Systems helisfreak Power Systems 1 Apr 16, 2004 10:28 AM
Discussion removed from Successful Power Systems thread SharksTooth Power Systems 4 Apr 15, 2004 11:45 AM
