This thread is privately moderated by jrb, who may elect to delete unwanted replies.
Old Apr 27, 2004, 01:41 PM
psychosilence is offline
Find More Posts by psychosilence
Joined Aug 2003
ACE Simple Series 'Whizard'
Model: ACE Simple Series 'Whizard'
Motor: Speed 300 6v
Speed Control: SkyPro 30A
Cell type/count: 7 600AE
Prop: APC E 9x6
Reduction method and ratio: SimProp 5:1.
Prop RPM: +- 6000
Amps: 6A -7A
Weight Ready to Fly: 580g
Comments : 6 minutes flight, will fly at 3/4 throttle comfortably. A very nice trainer... very stable.
psychosilence is offline Find More Posts by psychosilence
Old May 01, 2004, 10:51 PM
wireit is offline
Find More Posts by wireit
Registered Rotor Abuser
wireit's Avatar
Wildwood, Florida, United States
Joined Dec 2003
Depron Jet, HV Hacker and Vasa 55
This is Ver 8
All Depron and Carbon Fiber construction, my own design.
AUW 16.25 oz
27" WS, 32" length, wing area about 440sqin.
Power system:
Vasa 55, CC35, Hacker B20 26L on 6s 1500 Tanics
Custom heat sink, inlet ring and exit tube,
350ah rec. pack, 3 Cir 4.4 and FMA M5
Perf:
Speed as yet unkown (read fast), unlimtd Vert, 41000 rpm, 660 grams thrust.
wireit is offline Find More Posts by wireit
Old May 05, 2004, 03:15 PM
edkoz is offline
Find More Posts by edkoz
Watch This !!!
edkoz's Avatar
Rochester, MI
Joined Apr 2003
Model: GWS Corsair
Motor: HiMax 2015/4100
ESC: CC Phoenix 25
Cells: 3s Kokam 1500HD
Prop: APC 11*7 SF
Gearbox: Gws 300
Gear: C Gear 5.3:1
Amps: 13.5 (Static - Full Throttle)
Watts 103 (Static - Full Throttle)
Comments: Flys great half throttle or less.
edkoz is offline Find More Posts by edkoz
Old May 05, 2004, 05:37 PM
SharksTooth is offline
Find More Posts by SharksTooth
Aerobatic Extremist
SharksTooth's Avatar
United States of America For Which We Stand!
Joined Jan 2004
Originally Posted by edkoz
Model: GWS Corsair
ESC: CC Phoenix 25
Prop: APC 11*7 SF
Gearbox: Gws 300
Gear: C Gear 5.3:1
Looks like you're reporting the same things I found with the Kokams. They just don't get the voltage to the motor and the output wattage suffers. I'm curious, what are those 1500's rated at "C" wise. I know the packs I tried were so far overrated that it did damage to them when I run them at what they had told everybody to. They also didn't stand behind them when I called to ask what they were going to do about the issue...even after they had lowered the C rating.
SharksTooth is offline Find More Posts by SharksTooth
Old May 05, 2004, 09:31 PM
edkoz is offline
Watch This !!!
edkoz's Avatar
Rochester, MI
Joined Apr 2003
I got them from Light Flight RC and they're rated at 8 - 10 C. It's really a good fit for this motor because it's efficient operating current is between 5 and 12 amps. They're just "warm" to the touch after a flight - definitely not anywhere near too hot.
Old May 05, 2004, 09:58 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
PLEASE keep discussion of these power systems out of this thread!
Old May 07, 2004, 06:02 AM
Tim Trick is offline
Find More Posts by Tim Trick
Tim Trick's Avatar
The Netherlands
Joined Apr 2004
Model: Flair/ben Buckle Junior 60
Motor: AXI 2820/10
ESC: Model Motors 4012-3
Cells: 7 KAN 3000 NIMH
Prop: MA electric wood 12x8
Gearbox: -
Gear: -
Amps: 32.4 full (volts drop to 6.7)
Watts 214 w input at full throttle
Comments:
Conversion from stock design with Master motor and gearbox to Axi during construction. Flies really well, tends to climb at 50-60 degress on full throtlle, need more down thrust (currently at 2 deg). Idles around the sky without loosing height at approx 6.5 amp draw. Flight times with three or four touch and goes and the rest lazy flight 29 mins measured
Tim Trick is offline Find More Posts by Tim Trick
Old May 08, 2004, 06:54 PM
claysmoke is offline
Find More Posts by claysmoke
Joined Apr 2004
Diablotin Mini
Hacker B50 13S
Jeti 70-3P
TP 5S3P
16x10APC
33amps-700 watts
4 pounds
LEXX
Hacker B50 9XL
Jeti 77-3P
TP 6S3P
14x12 or 15x10 APC
43 amps-990 watts
92 ounces
claysmoke is offline Find More Posts by claysmoke
Old May 10, 2004, 10:03 AM
Boss248
Boss248
Guest
n/a Posts
Axi 2212/26
Jetti 18 3P
3s Kokam 1500, TP 3s 2100
GWS 11/4.7
Plane: 3DX Flat Foamy
AUW 14.5 oz (ouch)
1 comment "I love it" see the video...
http://www.austinslopesoaring.com/videos/wayne3d.wmv
Boss
Old May 11, 2004, 07:13 PM
dk944s2 is offline
Find More Posts by dk944s2
Southern California
Joined Feb 2003
Model: Dare B-25 Mitchell--42" span, 15.8 oz. AUW
Motors: PJS 300SF outrunner brushless
ESCs: CC Phoenix 10s, w/ both BECs enabled
Cells: 3s1p Etec 1200 Li-Polys
Props: 3-bladed Varioprop 7.2 x 4, scale blades
Gearbox: none--direct drive
Gear: -
Amps: 9.3 amps peak--Motocalc #
Watts: 62 (66% efficiency)--Motocalc #
Comments: A nice powerful setup that's more than enough for a stick-and-tissue model designed for rubber power. Just over 1:1 thrust (maybe 16 oz.), will cruise easily at 1/2 throttle, 10-11-minute flights. Night-and-day improvement over IPS power system previously installed.
dk944s2 is offline Find More Posts by dk944s2
Old May 11, 2004, 10:37 PM
zzonie77 is offline
Find More Posts by zzonie77
T A C
Gilbert, Arizona
Joined Sep 2003
Model: All EPP: SLOFLY "MINI" 28" with CF spar
Motor: J250
Prop: GWS 4025
Rx/ESC: Plantraco DSP4SC
Servos: GWS 5.7 GR.
Cells: 3s1p 340 mah
Gearbox: None...Owners design shaft-drive (pictured)
Amps: Limited to 5 A. or less...by throttle management
Avg. Duration: 15 min.
AUW: 6 1/4 oz.
Comments: It's a blast!
zzonie77 is offline Find More Posts by zzonie77
Old May 12, 2004, 11:52 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
SKY RAIDER MACH-I by WORLD MODELS
Model/subject: SKY RAIDER MACH-I by WORLD MODELS
Motor: KYOSHO ENDOPLASMA 16-Turn R/C Truck "BRUSH" Motor
Speed Control: MEC MX-50 Brush ESC (Heli)
Cell type/count: 8-Cells, GP-3300mAH, Ni-MH
Prop/fan: APC "E" 12 X 8
Reduction method and ratio: Great Planes GD-600 (Optinal 3.8:1 Ratio)
Amps: 36.3 AMPS (Measured, ASTRO FLIGHT WATT 101 Meter)
Watts: 330 WATTS (Measured, ASTRO FLIGHT WATT 101 Meter)
RPM: 6,750 RPM @ PROP (Measured Great Planes TACH)
Weight Read to Fly: 5lbs. - 2 1/8 oz. (or 5.13 lbs.)
Comments and links to other forums for more info:
GO TO:
http://www.rcgroups.com/forums/showt...4&page=1&pp=10
and,
http://www.rcgroups.com/forums/showthread.php?t=225134
Carlos
guapoman2000 is offline Find More Posts by guapoman2000
Old May 13, 2004, 07:05 AM
Account closed
Joined Oct 2002
Model/subject: GWS FORMOSA
Motor: RAZOR RZ-400
Speed Control: CC PHX-25 (Programmed without Brake and SOFTEST start)
Cell type/count: THUNDER POWER 2100mAH, 3S1P, Li-POLYs
Prop/fan: APC "SF" 10 X 7
Reduction method and ratio: GWS EPS-300C "C" (5.33:1 ratio)
Amps: 8.2 AMPS @ WOT
Watts: ?
RPM: ?
Weight Read to Fly: 17 oz.
Comments and links to other forums for more info, video, etc.
For those of you that have RAZOR RZ-400/350 motors then, here's another way to secure your motor in the GWS EPS-300/350 gearbox. The O-Ring is available from HOME DEPOT and improves the side loads and reduces the stress on the front attaching hex motor screws!
For those of you that have removed the motor from the gearbox several times you may have notice that the thread on the motor front case my have enlarged or a slightly enlarged that those screws tend to come out at the most unlikely time such as in-flight!
I used plumbers tape (White Flexable and stretchy) with great success. I think they call it TEFLON TAPE? I cut a small strip and wrap it around the hex screw and then, screw it into the motor which acts like Loc Tie but, with much safer conditions!
RESULTS: FANTASTIC!
She flew for a short 8 minute and 19 second flight during lunch time at the Space Center and the motor/gearbox stayed in one piece finally and the landing was super smooth!
Old May 17, 2004, 07:11 PM
WingMan33 is offline
Find More Posts by WingMan33
WingMan33's Avatar
Chicagoland Area
Joined Oct 2003
Acent With Cobalt Motor upgrade.
400 can with Lite AAA 700 cells Good. But 400 Cobalt 190+Watts and 1100 kan 8 cells better.
WingMan33 is offline Find More Posts by WingMan33
Old May 23, 2004, 04:46 PM
ohadvr is offline
Find More Posts by ohadvr
ohadvr's Avatar
Israel
Joined Mar 2004
Reichard Modelsport ELIPSOID
Model/subject:Reichard Modelsport ELIPSOID
Motor: Model Motors AXI2820/10
Speed Control:JETI 40A
Cell type/count:8 X SANYO RC3300HV
Prop:12X9
Reduction method and ratio:n/a
Amps:n/a
Watts:n/a
RPM:n/a
Weight Read to Fly:1850 Kg (~66 Oz)
ohadvr is offline Find More Posts by ohadvr
Discussion from Successful Power Systems e-geezer Power Systems 3 Sep 21, 2014 03:32 AM
Successful Power Systems sandburr Power Systems 0 Jul 31, 2005 06:57 PM
Successful Power Systems II superflyX Power Systems 0 May 18, 2005 11:47 PM
Another question from Successful Power Systems helisfreak Power Systems 1 Apr 16, 2004 10:28 AM
Discussion removed from Successful Power Systems thread SharksTooth Power Systems 4 Apr 15, 2004 11:45 AM
