This thread is privately moderated by jrb, who may elect to delete unwanted replies.
Old Aug 24, 2012, 10:12 PM
Rminut is online now
Find More Posts by Rminut
Rminut's Avatar
United States, OK, Tulsa
Joined Sep 2009
Dlewton sounds good, I would like to know what size prop you are using and is it an APC?
Rminut is online now Find More Posts by Rminut
Old Aug 25, 2012, 07:04 AM
Zebi2 is offline
Find More Posts by Zebi2
Finland
Joined Jun 2012
Model: GWS Slow Stick
Motor: Emax GF2210 1200 kv
Speed Control: Riccs 20A
Battery: Rhino 1050mAh 40-50C 3S LiPo
Turnigy nano-tech 1000mAh 25-50C 3S LiPo
Prop: 10x3.8 SF
Amps: ~16
Watts: ~ 170
Comments: great combo, no problems. about 25 minute flight time. Great power for this plane (unlimited vertical...)
Zebi2 is offline Find More Posts by Zebi2
Old Oct 22, 2012, 05:18 PM
ww2birder is offline
Find More Posts by ww2birder
too many planes
ww2birder's Avatar
United States, MI, South Lyon
Joined Sep 2012
Please Help Me
Question, I have a FMS Focke Wulf 190 everytime I hit the throttle the flaps go back to there starting position and the gear gliches moving up and down when deployed?? Is there a voltage regulator or something ? Should I add a battery? It seems to be starving the system of power when the motor is engaged. I would love to run the throttle off its own segregated channel. Spectrum 7010 3300 4s battery bone stock electronics. Flew it once and had to belly land because of the gear only would deploy half way then up then down ect. Help!! Matt I have not run an external 5a BEC thats next.
ww2birder is offline Find More Posts by ww2birder
Old Jan 14, 2013, 04:39 PM
flydown is offline
Find More Posts by flydown
flydown's Avatar
United States, AZ, Peoria
Joined Aug 2010
External BEC and ESC wiring question?
I have a Banana Hobby F-22 Raptor and my external BEC that came with the plane fried so I am putting in a Castle Creations CC 10A BEC.
The BEC that come with the plane has 4 wires (red and black to ESC and red and black to receiver.)
What baffles me is that the Castle ESC has 5 wires (red and black to ESC and red / black and orange to receiver.)
The directions say to disconnect the red wire from the ESC to the throttle channel on the receiver when using this BEC.
Does this seem right?
flydown is offline Find More Posts by flydown
Old Jan 14, 2013, 05:19 PM
Rminut's Avatar
Joined Sep 2009
Flydown, What the directions are saying is correct you do not want power coming from 2 sources. The wires in the cables are black - common, red - voltage, orange - signal. So from the ESC you only want the signal and common wires to be active and the red and common wires from the bec to provide power. The reason for the orange wire from the bec I cannot explain though but I would not fool with it. Hope this makes sense
Old Jan 14, 2013, 05:34 PM
flydown is offline
flydown's Avatar
Joined Aug 2010
So do I still plug the ESC to throttle and the BEC to the AUX or Batt / Bind on the receiver after removing the red power wire from the ESC?
Thanks for your help.
Old Jan 14, 2013, 06:19 PM
Rminut's Avatar
Joined Sep 2009
Flydown, yes you do no change there, you need the ESC in the throttle channel to control the motor and the aux channel will provide the power to the system
Old Jan 14, 2013, 06:31 PM
flydown is offline
flydown's Avatar
Joined Aug 2010
Thanks again. This evening I'll put it in. Not sure if I'll have to rebind the receiver, but I guess I will find out.
Old Jan 17, 2013, 12:03 PM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
Co-axial counter rotating
I need advice regarding a two motor BL setup driving co-axial counter-rotating props.
Would especially appreciate a link to a proven system.
Thanks, Steve
dayhead is offline Find More Posts by dayhead
Old Mar 27, 2013, 02:26 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Old E-Flite P-47 Repowered
I inherited an old E-Flite foamy P-47, razor back with yellow and black checkerboard tail fin and rudder. Removed stock 400 brushed motor gear drive, installed a ply box motormount and Scorpion 3008-32 with 2200mah 3S lipo. Went like a bat , but too much motor for fun scale-like flying. Installed a Thunder Tiger "10" outrunner that I had on hand. pulls 22 amps static on 9x6 APC E prop. Flies very nice now, plenty of speed, lots of vertical, consequitve loops at 1/2 throttle. Model is so light that it wants to float forever. Have to almost cut throttle to get it to touch down. Model could carry retracts with no problem. BTW, used a Great Planes heavy spinner nut to compensate for lighter weight of TT 10 vs larger heavier Scorpion 3008-32. Did the trick..
E-Challenged is offline Find More Posts by E-Challenged
Old Mar 28, 2013, 02:31 PM
hobbyclub is offline
Find More Posts by hobbyclub
United States, CA, Orange County
Joined Feb 2003
Plettenberg Predator 37/6 Brute Power EP Outrunner Motor
On sale....what a deal..!!
Please check this link:
http://www.hobbyclub.com/product_inf...roducts_id=822
hobbyclub is offline Find More Posts by hobbyclub
Old May 31, 2013, 03:08 AM
samss is offline
Find More Posts by samss
Joined Jan 2013
reply
So many kinds of Batteries. Really very wonderful.
samss is offline Find More Posts by samss
Old May 31, 2013, 04:16 AM
JoshB is offline
Find More Posts by JoshB
Novice in training
JoshB's Avatar
United States, NC, Statesville
Joined Aug 2011
http://www.headsuphobby.com/Emax-BL2...otor-F-291.htm
http://www.headsuphobby.com/HURC-50-...-ESC-G-750.htm
PZ T28 great combo. 2200mah 40c batteries and 11x7 prop it screams and pulls only 29 amps WOT. Cruising around just over half throttle gets you just over 9 minutes. Pushing it yields around 7 minutes. Enjoy. : )
JoshB is offline Find More Posts by JoshB
Old Jun 13, 2013, 02:29 PM
chamowllie is offline
Find More Posts by chamowllie
1BADA$$
chamowllie's Avatar
United States, FL, Jacksonville
Joined Mar 2013
Model: Eflite P51B 32e
Motor: Eflite Power 46
Speed Control: Turnigy Plush 60amp
Batteries: Gens Ace 4s 3600mah 25C/Flight Power 5s 2450mah 30C
Prop: 13x10
Amps: 45
Watts: 750+
Comments: She can move...She will cover some ground quick..hard and snappy torque on take-offs...she cuts to the left hard when you give power to get that tail up...sometimes takes a few runs to get her decently straight on the runway...lol!! difficult to land due to the high wing loading cant fly her really slow...she has to have some speed to keep her level and steady to land.
chamowllie is offline Find More Posts by chamowllie
Old Jun 13, 2013, 02:36 PM
1BADA$$
chamowllie's Avatar
Joined Mar 2013
Model: Great Planes Syncro
Motor: Dons RC Wicked 4400
Speed Control: Pentium 60amp
Batteries: Enerland 4s 3000mah 20C/Gens Ace 4s 3600mah 25C/Venom 3s 2100 25C/Cheetah 3s 2200mah 35C.
Prop: 55mm EDF
Amps: 40+
Watts: 650
Comments: Whew this one is a smoker...Thanks Don!!! She isnt sluggish either with the 3s battery...normally start off with the 3s to get my thumbs acclimated to the controls...especially when i havent flown her in awhile...but want to get the adrenaline pumping...??? Stick a 4s in there and go hunt some sky...lol!! She is a screamer on a 4s WOW!! 650 watts on a 1.5-2lb plane (AUW with a 3000mah lipo)
Discussion from Successful Power Systems e-geezer Power Systems 3 Sep 21, 2014 03:32 AM
Successful Power Systems sandburr Power Systems 0 Jul 31, 2005 06:57 PM
Successful Power Systems II superflyX Power Systems 0 May 18, 2005 11:47 PM
Another question from Successful Power Systems helisfreak Power Systems 1 Apr 16, 2004 10:28 AM
Discussion removed from Successful Power Systems thread SharksTooth Power Systems 4 Apr 15, 2004 11:45 AM
