This thread is privately moderated by jrb, who may elect to delete unwanted replies.
Old Feb 29, 2004, 05:16 PM
RocketRonbo is online now
Find More Posts by RocketRonbo
the correct 51%
RocketRonbo's Avatar
Rancho Cucamonga, CA
Joined Apr 2002
Wattage Ultimate
Model/: Wattage Ultimate
Motor:Himaxx 2025-5300
Speed Control: Castle Creations 25 amp brushless
Cell type: 3s1p 2100 Thunderpower
Prop/fan: 8 x 6 APC
Reduction method and ratio:GWS 350C 5.33 Gearbox
Amps: moto calc 13 amps
Also used 7 and 8 cell 1300 scr's
15 to 20 minutes probably more but kept landing to check the batteries/motor both stayed just warm to the touch
Weight: W/LiPo's 24.2oz W/8c 29.7oz
Really turned this plane into one of my favorite's.
Way better than the 3 minutes i got before plus faster
Wattage Decathlon (the yellow one)
Model: Wattage Decathlon
Motor: Mpjet 25/25/26
Speed Control: Jeti 18amp
Cell type: 8 cell 1050 2/3 a, and 3s1p 2100 thunderpower
Prop: 9 x 6 APC SF
Stock gearbox: 5 to 1
Amps: not sure but both the motor and batteries were luke warm.
Run time: 8cell 10 to 15 minutes, lithium not sure, probably 20 +
For a $49.00 motor/gearbox combo this thing was awsome...
Weight W/8c 19.1oz W/LiPo's 17.7oz
With LiPo's this thing is fast and climbs great...
Now I need more lithiums
RocketRonbo is online now Find More Posts by RocketRonbo
Old Feb 29, 2004, 05:30 PM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
HOB 43" Mustang - no landing gear
24 ounces
AXI 2808/24
Aero-Naut 10x6 folder
8-1100 mah HECell also 8-1050KAN
16 amps 7500 rpm
HOB Spacewalker
24 ounces
AXI 2808/20
Aero-Naut 9x6 folder
8-1100 mah HECell
19 amps - flew at 3/4 throttle mostly
G-480 Groove
AXI 2814/12
GWS 11x7 HD
8-CBP-1800 4/5A
Ripmax Alliance
AXI 2808/24
GWS 10x6 HD
8-KAN 1050
MM Flashback
16 ounces
AXI 2212/26
GWS 9x5 HD also APC 8x6 sf
9-CBP-650
MM Tantrum
MiniAC 1215/16 GWS "C" Box
GWS 12x6 sf
8-KAN950
GWS Spitfire
15.9 ounces
AXI 2208/34
APC 8x6 sf
8-KAN650
GWS Formosa
18.7 ounces
Mega 16/15/7
GWS 9x5 HD
9-KAN1050
GWS Formosa
14.7 ounces
AXI 2212/34
GWS 1060 HD
GWS 3S 1300 mAh
Best Formosa yet - lighter is better. Draws less than 7 amps.
LenBFP is offline Find More Posts by LenBFP
Old Mar 01, 2004, 04:08 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Model/subject: Rake Kanata tiger moth
Motor: Speed 400 6v
Speed Control: RipMax Xtra 12
Cell type/count: 3s E-tech 1200 LIPOLY
Prop/fan: APC E 8x6
Reduction method and ratio: 4.09:1 MPJET inrunner box.
Amps: About 5.5
Watts: about 55
RPM: Mmm. Can't remember. Probably around 5500-6000
Weight Ready to Fly: 17 oz dead
Comments : Really managed to get the weight down and duration up from stock with this combination. Motor stays cool and has more than enough power to waft this old timer around beautifully.
Links to other forums for more info, video, etc.
http://www.rcgroups.com/forums/showt...hreadid=189554
15/4/04 Tried 4:1 box with APC E 10x7. 7.5A at 9.3v, lots more power. Will upgrade to 3.0 box and 8x6E..
Old Mar 01, 2004, 04:27 PM
dw1122 is offline
Find More Posts by dw1122
Pasadena, California, USA
Joined Mar 2002
Model: Graupner Terry w/ aileron mod
Motor: Mega 16/7/8
Speed Control: CC Ph25
Cell type/count: 8XKAN1050
Prop/fan: MA 5.5x4, Varioprop 5.6", APC4.75x4.75
Reduction method and ratio: dd
Amps: ~10A
Watts: ~95W
RPM: 15000~16000
Weight RTF: 20oz
Comment: Very happy
Model: Kavan Partenavia
Motor: Twin Mega 16/15/6
Speed Control: Kontronik Beat 40-6-12 driving both motors
Cell type/count: 8XCP2400
Prop/fan: Varioprop 8.2" cut down to 7.2" (L/R prop for counter-rotation)
Amps: ~25A
Watts: ~200W
RPM:
Weight RTF: 56oz
Comment: a little slow, 16/15/5 is probably better
dw1122 is offline Find More Posts by dw1122
Old Mar 02, 2004, 06:15 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
http://www.rcgroups.com/forums/showt...hlight=lue+tic
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Mar 03, 2004, 06:55 PM
Mike Parsons is offline
Find More Posts by Mike Parsons
Forgot how to fly
Mike Parsons's Avatar
Atlanta, Georgia
Joined Oct 2002
Model: Hanger 9 Funtana
Motor: Mega 22/30/2
Speed Control: CC Ph80
Cell type/count: 14- GP 3300
Prop/fan: APC E 17X10
Reduction method and ratio: MEC Superbox 4.6:1
Amps: ~55a
Weight RTF: 102oz
Comment: Penty of power for 3D and Sport
Model: Kyosho Sukhoi SU-31
Motor: Mega 22/30/2
Speed Control: CC Ph60
Cell type/count: 14- GP 3300 & 4S4P 8ah Thunderpower
Prop/fan: APC E 15X10
Reduction method and ratio: MEC Superbox 3.33:1
Amps: ~55a
Weight RTF: 92oz
Comment: Impressive flights and more than enough power for verticle patterns.
Mike Parsons is offline Find More Posts by Mike Parsons
Old Mar 04, 2004, 02:53 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Model: MM Flashback II
Motor: MPJet 2535 4:1
Cell type/count: 8 - 1100 niMH
Prop: 11x10 APC E
Reduction: MPJet 4:1
Amps: unk
Weight RTF: 18 oz
comment: Almost vertical performance. Great power for this pattern plane. Have to set low throttle end or motor will "stutter" when trying to land.
Model: MM Dandy Sport
Motor: Himaxx 2015
Cell type/count: 8 - 800 NiMH and 3-1500 Kokam
Prop: 1080 GWS
Reduction: GWS "C" gearbox (5.3:1)
Amps: unk
Weight RTF: 11 oz (with LiPo)
comment: Great performance. Good improvement over stock GWS 350, including 3 ft takeoff runs. Good vertical performance.
I like the cost of both these systems the most, after burning out many GWS 300/350's.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Mar 04, 2004, 09:54 PM
simingx is offline
Find More Posts by simingx
now that's a wattmeter...
simingx's Avatar
Singapore
Joined May 2002
Model/subject: "Fast E.R. 400" (Plans here)
Motor: Rewound CD-ROM motor, 12 turns 0.5mm dia., star connected, 12x 5x5x1 N44H magnets
Speed Control: Jeti Advance 18-3P
Cell type/count: 8x KAN 950
Prop/fan: APC 6x4E
Reduction method and ratio: None
Amps: around 10 off a fresh pack
Watts: 80?
RPM: around 13k, give or take 1k
Weight Ready to Fly: Haven't measured
Does unlimited acrobatics.... normal flying only requires half throttle.
simingx is offline Find More Posts by simingx
Old Mar 06, 2004, 12:03 PM
JJfromUK
A moderator felt this post violated the following rule: Offensive content (Profanity). It is temporarily hidden while JJfromUK edits it.
Old Mar 07, 2004, 12:06 AM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
Freedom 3D
48" span, 64 oz AUW
Mega 22/45/3
MEC super box at 3.125/1
Phoenix 80
SBEC
6S1P Irate 2200
APC E 16x10
22 amps static
10 to 15 minute flights with lots of aerobatics, touch n goes, hovers
Motor and ESC run very cool
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Mar 10, 2004, 07:09 PM
SharksTooth is offline
Find More Posts by SharksTooth
Aerobatic Extremist
SharksTooth's Avatar
United States of America For Which We Stand!
Joined Jan 2004
Successful? This thing is Perfect!!!
Model: GW-ezone 40" Extra 330 Foamie
Motor: Himax 2025-5300
Speed Control: Castle Creations Phoenix 25 Brushless ESC
Radio: JR 10x
Servos: JR 241 Sub-Micros
Rx: JR 610M Micro Receiver
Cell type/count:Li-Po 3s 2200 Tanic w/Tanic Taps
Prop/fan: APC 12x6, 12x6 mod, 12x3.8, 11x4.7
Reduction method and ratio: GWS 350c w/Bishop Power Products Motor plate, Cobri Hardened Stainless Shaft, 66T Spur, and 10T Stainless Pinion
Amps: 16.3-24.6a depending on prop
Watts: Varies but greater than 200
RPM: 6,800-7800 at the prop depending on prop used
Weight RTF: 20
Comments, etc.: Plane flies and 3D's like a dream. Will Tumble and has to be see to be believed. Absolutely VULGAR power. Will acclerate straight up like the space shuttle! The Tanic packs are in a class by themselves...they put the voltage to the motor and keep it there the entire 12 minutes of flight! It's almost like flying a gas powered plane...NO dropoff, but quiet, efficient, and cheap! This plane is LOADS of fun. It will do elevators all the way down to less than a 1/2 foot above the ground, transition into a harrier, and touch down all in one simeultaneous motion. Waterfalls are more like flips. It will do clibing flatspins, blinding KE spins, intimidators, walls, and the entire envelope of 3D and precision sequence flying. A truly great airplane! Thanks GW! This thing rocks man!
SharksTooth is offline Find More Posts by SharksTooth
Old Mar 11, 2004, 05:08 AM
psychosilence is offline
Find More Posts by psychosilence
Joined Aug 2003
Storch Fi156
Model: Scratchbuild Storch 156
Motor: Speed 300 6v
Speed Control: SkyPro 30A
Cell type/count: 7 600AE
Prop: APC E 9x6
Reduction method and ratio: SimProp 5:1.
Prop RPM: +- 6000
Amps: 6A -7A
Weight Ready to Fly: 340g
Comments : 6 minutes flight, will fly at 3/4 throttle comfortably. Way faster than full scale version!
psychosilence is offline Find More Posts by psychosilence
Old Mar 23, 2004, 06:40 AM
stapal is offline
Find More Posts by stapal
Scratchbuilder
stapal's Avatar
Oslo, Norway
Joined Sep 2003
Model - Fokker D-VIII 1/4 scale
Motor - HP 370/40/A3
Speed C - Kontronic 40-6-32
Celltype - FlightPower 9S-3700
Gear - Kruse Syncro gear 2500 2,4:1
Propp - 26*14 reworked
Amps - max 38, average 12
Watts - 1250w
Weight - 4950 gram or 175oz
Reduced weight by 1050 gram from 30x3000nimh to lipo. Now it's a very very nice flying machine
stapal is offline Find More Posts by stapal
Old Mar 23, 2004, 06:55 PM
icrashrc is offline
Find More Posts by icrashrc
icrashrc's Avatar
Indiana
Joined Jul 2003
Scratch built SU-26
33.5" wingspan
15.5 oz auw
Astro 010 10 turn
Phoenix 10
Thunder Power 3s-1p 2100
4.3/1
APC 9X6E
8 amps
7200rpm
performance=WOW
icrashrc is offline Find More Posts by icrashrc
Old Mar 23, 2004, 07:26 PM
icrashrc is offline
icrashrc's Avatar
Indiana
Joined Jul 2003
Scratch built SU-26
15 oz auw
Hacker b20-26s
Phoenix 10
4/1
APC 9X6E
Thunder Power 3s1p 2100
10 amps
performance=WOW again
The Astro setup is more efficient, the Hacker setup has a little more power.
Discussion from Successful Power Systems e-geezer Power Systems 3 Sep 21, 2014 03:32 AM
Successful Power Systems sandburr Power Systems 0 Jul 31, 2005 06:57 PM
Successful Power Systems II superflyX Power Systems 0 May 18, 2005 11:47 PM
Another question from Successful Power Systems helisfreak Power Systems 1 Apr 16, 2004 10:28 AM
Discussion removed from Successful Power Systems thread SharksTooth Power Systems 4 Apr 15, 2004 11:45 AM
