Cinestar Quick Release Gimbal System
Separate the Gimbal and Airframe in Seconds
Quick Release System Makes Life Easier
Allied Drones is offering up a great solution for Cinestar owners who have to break down their rig for transporting. This 15mm rail mount upgrade allows you to separate the gimbal from the airframe in under 10 seconds and without using tools. The clamps are solid and will hold heavy payloads. This is also great when you need balance a new camera as the arms from the copter can get in the way and make it a hassle. Check out the Cinestar Quick Release Gimbal System and more at Allied Drones.
Old Nov 13, 2013, 04:32 PM
RDTague is offline
Find More Posts by RDTague
RDTague's Avatar
United States, IL, Cowden
Joined Mar 2013
VulcanUAV has been doing this for 12mm load rails, for awhile now.
"Quick Release Plate for Gimbals & Other Payloads"on their upgrade page.
RDTague is offline Find More Posts by RDTague
Old Nov 14, 2013, 09:40 PM
DroneBuilder is offline
Find More Posts by DroneBuilder
United States, TN, Brentwood
Joined Oct 2010
Coincidentally, I ordered one of these recently and it arrived yesterday.
Installation was super easy, even on my (clone) Cinestar Octo.
It is not readily obvious from the web site, but the tiny little Carbon Fiber "X-looking things" are attached directly to the 15mm tubes by screws. Then, they are also connected to the existing Cinestar dampeners on the bird.
The part that has the quick-release clamps on it can then be permanently mounted to the 'yaw axis' of your Cinestar Gimbal.
The parts are very sturdy, and the quick release function is really, really nice. It was getting tough to walk around my room with my 1,100mm Motor-to-motor distance Octo sitting on the gimbal on the floor! Now, I can easily (easily) remove the gimbal and hang the Octo with her sisters on the wall!
While this accessory is not cheap (what accessory in this hobby IS cheap?), it is absolutely worth it for the convenience! I'm actually thinking of buying another set to add to my other Cinestar 3-axis gimbal. (Yes, I have two. Its an obsession.)
DroneBuilder is offline Find More Posts by DroneBuilder
Old Nov 18, 2013, 08:51 AM
Jason Cole is online now
Find More Posts by Jason Cole
RCG Staff Member
Jason Cole's Avatar
United States, TN, Nashville
Joined Oct 2003
I like it!
Jason Cole is online now Find More Posts by Jason Cole
Administrator
Old Feb 11, 2014, 07:53 AM
hitinson is offline
Find More Posts by hitinson
Joined Nov 2011
if you already have a 15mm load rails, you are better off buying cheap quick release clamps.
hitinson is offline Find More Posts by hitinson
For Sale Cinestar gimbal "up armor kit" accessory mounting system 1sicknickel Aircraft - Electric - Multirotor (FS/W) 0 Aug 17, 2013 11:23 AM
Alert CINESTAR 3 Axis Brushless GIMBAL system & Handheld Steadicam 3k carbon fiber aopen3434 Hot Online Deals 0 Jun 04, 2013 08:20 PM
Discussion What is the best stabilization system for the CineStar Gimbal? Tarro Aerial Photography 10 Aug 10, 2012 04:50 PM
Discussion CineStar Radian Gimbal Systems Overview Video! BirdsEyeProd Multirotor Electronics 7 Aug 07, 2012 08:24 AM
Sold cinestar 8 with cinestar 3 axis gimbal Tretch5000 Aircraft - Electric - Multirotor (FS/W) 5 May 03, 2012 02:05 PM
