Old Nov 12, 2013, 10:02 AM
Radical RC is offline
Find More Posts by Radical RC
Kevin
Radical RC's Avatar
Joined Dec 2012
New scratch builder from foam
Hey everyone,
I have been building kit planes for years but have never done a large scale scratch foamie build. I have plans for 61 planes that I am wanting to do but have no clue on how. Any help will be great.
Thanks to all
Kevin
Radical RC is offline Find More Posts by Radical RC
Old Nov 12, 2013, 10:22 AM
RcAirplaneNoob is offline
Find More Posts by RcAirplaneNoob
I live on LiPos
RcAirplaneNoob's Avatar
United States, DE
Joined Jul 2012
Go to flitetest.com they have many planes that the designed with dollar tree foamboard (adams foamboard) they have multiple tips for scratch building with foam. Its where i started scratch building and have had much success with less that 10$ per plane 2-4 servos and 1-3 sheets of foam.
RcAirplaneNoob is offline Find More Posts by RcAirplaneNoob
Old Nov 12, 2013, 11:40 AM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Kevin: are these 61 planes foamie designs/plans, or balsa, or just 3 views? If the first, then go to the plane's build thread and follow the designer's lead. Post questions as you get hung up, we are all friendly here! If they are the last two, then i would build a plane that is well documented here, like BluBaby or one of the 600+ ones in that thread and get the methods down, then take on the conversion. You may well find one of your 61 in that thread already done for you!
springer is offline Find More Posts by springer
Old Nov 12, 2013, 01:34 PM
Kevin
Radical RC's Avatar
Joined Dec 2012
These are all plans that can be cad router cut... I plan to do them from hand cut pieces. Yes it is the hard way... and they are not foam planes per-say. Just detailed plans. I really planed to use blue foam or pink from hardware store with some balsa and plywood for strength. If I am messing up please let me know. The covering i planed to use 1/4" foam core sheets with 3mil printed sticker from my local sign shop. Hardware like canopies,cowlings and things in shaped plastic is going to be my real problem...
Old Nov 12, 2013, 01:36 PM
Kevin
Radical RC's Avatar
Joined Dec 2012
Thanks RcAirplaneNoob.Will add the foam to my must get
Old Nov 12, 2013, 01:39 PM
Kevin
Radical RC's Avatar
Joined Dec 2012
Springer... They seem to be mostly balsa plans
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
I think you should follow springer's suggestion only instead of looking up threads on particular airplanes, just go look up build threads on a bunch of foamies and read them. You'll gain a lot of insight on construction methods, materials, and tools. I think you'll have a much better chance of success in building from your plans after doing just a bit of research.
Ben
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Nov 12, 2013, 01:50 PM
I live on LiPos
United States, DE
Joined Jul 2012
Originally Posted by bhoov128 View Post
i think you should follow springer's suggestion only instead of looking up threads on particular airplanes, just go look up build threads on a bunch of foamies and read them. You'll gain a lot of insight on construction methods, materials, and tools. I think you'll have a much better chance of success in building from your plans after doing just a bit of research.
Ben
+1.
Old Nov 12, 2013, 01:51 PM
I live on LiPos
United States, DE
Joined Jul 2012
No problem, glad to help.
Old Nov 12, 2013, 03:17 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
There are many types of foam, and many ways of building using foam. There are also many different sizes of models. So you need to make some decisions on what you want to do.
Perhaps choose the plane/plan you really want first, then look for any builds.
A wish list often stays just that, ..... until you cut the first piece of foam.
You said, "I have been building kit planes for years .....", what sort and have you flown them successfully ?.
eflightray is offline Find More Posts by eflightray
Old Nov 12, 2013, 06:27 PM
Kevin
Radical RC's Avatar
Joined Dec 2012
Hey Ray,
Love your planes... Really love the SBD. Every plan I have is for 64"WS up to 144"WS. The best kit I still have is a Sopwith with a 32"WS. Was a rubber band model but I went electric 4ch with her. Also have a P40 stick build 28", still going. Both are about 12 year old models and both have been converted over to electric. Can fly at parks and soccer fields that way. I have had several over the last 30 years both foamies and stick planes that have flown well. A few not so well...LOL ;-) What I really want to do is a 114" P61 Black Widow. Doing all foam is new to me though. I figured it should be about the same as a stick build. If not... PLEASE let me know.
Old Nov 12, 2013, 08:46 PM
springer is offline
treefinder
springer's Avatar
SE MI
A ten foot wingspan twin warbird isn't exactly the best plane to start scratchbuilding with foam, not that it wouldn't be a cool subject. If you haven't already seen it do a search on 8 foot span B17 to see how it's done.
To your comment about stick builds, building with foam (especially if one is designing and building) isn't really like stick builds at all, other than the obvious craftsmanship shows and lighter flys better, etc. The biggest difference i've found is that with foam, the strength is in the foam skin, so lots of formers, stringers, longerons, gussets, etc are not needed. One can also roll and otherwise form the foam to pretty complex curves, so there are new opportunities in it's use. You will have to change your mindset from building a girder/structure that gets skinned with essentially non structural film to building the shape you want with foam then only adding additional reinforcing where testing shows it is needed.
If you embrace those differences, you will find foam is more fun than balsa sticks (unless you really like the tedium of cutting and gluing many many small parts together). To get started, i still think you should build a plane that has a good build thread and good set of pdf plans. Even pick a plane that is somewhat below your skill level, as you won't get caught up in the challenge, and can focus more on perfecting your foamie build techniques. You will find that foamie builds go much faster than stick builds, so starting with a "beginner" design (you pick how you define beginner), you can finish it quickly, test it, use it up, fix it (foam breaks into big chunks typically, so repairs go fast too), change it and really learn from it the things you will want to use on the "real plane" you want to do.
Just be aware, foam building is seriously addictive! (He said while working on plane number 80+ .....actually i think i lost count!)
Old Nov 12, 2013, 11:16 PM
BrownEyedFool is online now
Find More Posts by BrownEyedFool
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
http://parkflyerplastics.com/cart/in...roducts_id=644
Very useful book for exactly what you're doing
BrownEyedFool is online now Find More Posts by BrownEyedFool
Old Nov 13, 2013, 06:25 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Ouch!, there is madness and there is MADNESS.
I assume you have the Ziroli P-61 plan.
Have a look at this balsa build of the same model, --
Ziroli P-61 Black Widow Build
Not a project I would fancy taking on in balsa let alone foam at that size. Thought it is quite possible, it's just that at 70 I like to finish planes, before they finish me
There are three P-61 threads I found in the Foamies (Scratchbuilt) forum, (found with a Search this Forum on P-61), but I didn't look in them.
There is really on one answer, Go for it.
Old Nov 13, 2013, 10:08 AM
Kevin
Radical RC's Avatar
Joined Dec 2012
Thanks Springer,
I believe I will take your advice... I have plans for a Arup S-2 40” WS I think I may start with. SEEMS to be an easier build plus it has been done over and over again. There are plenty of things on them to look at.
I got these plans... all LARGE scale... for little to nothing. I figured ... "What the heck... figure it out in foam". I have foamies and see what you are talking about with the shaping of the foam and lack of girder/structure in them.
Here is a list of the plans I have... Any suggestions is most welcome
A6M5 Zero 91” WS
A-26 Invader 61” WS
AD-7 Skyraider 62.5” WS
AD-7 Skyraider 100” WS
Airbus A320 60” WS
Arup S-2 40” WS
AT-6 Texan 101” WS
B-17 Flying Fortress 78” WS
B-17 Flying Fortress 125” WS
B-24 Liberator 110” WS
B-25 Mitchell 101” WS
B-29 Superfortress 140” WS
B-36 Peacemaker 115” WS
Beechcraft D-17S Staggerwing75” WS
Beechcraft D-18/C-45 82” WS
Buckner Jungmeister 65” WS
Cessna 150 Aerobat 120” WS
Citabria104” WS
Douglas DC-3 140” WS
De Havilland DH-103 Hornet 80” WS
Dornier DO 23 60” WS
E2C Hawkeye 60” WS
F-4 Phantom 46” WS
F4F Wildcat 74” WS
F4U Corsair 84” WS
F4U Corsair Folding Wing 93” WS
F6F Hellcat 96” WS
F7F Tigercat 87” WS
F9F Cougar 72” WS
F9F Panther 72” WS
F-14 Tomcat 80” WS
F-16 Falcon 60.5” WS
F-18 Hornet 55" WS
F-86 Sabre 55” WS
Fokker DR-1 65” WS
Focke FW 190A 100” WS
Focke TA-154 Mosquito 71.5”WS
Focke Wulf 152 114” WS
Gloster Meteor MK IV 43” WS
Grumman J2F Duck 58.5” WS
Hawker Hurricane 92.5” WS
Hawker Typhoon 97” WS
Hercules C-130 144” WS
Junkers JU-87 Stuka 100” WS
Lippisch Messerschmitt P-13 26” WS
P2V Neptune 37.5” WS
P-38 Lighting 74” WS
P-38 Lighting 114” WS
P-40 Warhawk 66” WS
P-40 Warhawk 94” WS
P-51 Mustang 98” WS
P-51 Mustang 102” WS
P-61 Black Widow 114” WS
PBY Catalina 108” WS
Piper J3 Cub 141” WS
Piper Senaca II 85” WS
Pitts Special 60.5” WS
SBD-35 Dauntless 100” WS
Spirit of St Louis 105” WS
Spitfire 111” WS
U2 Spy Plane 130” WS
Discussion Novice question for an old scratch builder vil64 Electric Sailplanes 5 Feb 23, 2013 08:13 AM
Discussion Tools of the trade every scratch builder should own jhiggy Foamies (Scratchbuilt) 19 Feb 08, 2013 07:58 PM
Discussion scratch builders software?? foam-cad? Mad King Louie Foamies (Scratchbuilt) 2 Feb 19, 2007 01:28 PM
Discussion Need a little help from San Diego Scratch Builders sl33pdirt Slope 6 Jan 06, 2006 09:52 AM
Great Foam FInd for Scratch Builders Ralph A. D'Amelio Electric Plane Talk 5 Jan 04, 2002 05:51 AM
