Old Nov 12, 2013, 05:06 AM
tomahl is offline
Find More Posts by tomahl
tomahl's Avatar
Finland
Joined May 2012
Question
Futaba T6J PPM out ??
Hi all,
I am building an ultra micro plane and would like to use Hobbykings supermicro system. I have a Futaba T6J radio and would like to connect the module to it. Does the 6J have a PPM out in the trainer port. Can't be able to figure out if it is PPM, PCM or something else. HK's site states that the module works with PPM signal.
I am thankful for any help here, the indoor season is here now!
Regards,
Tommy
tomahl is offline Find More Posts by tomahl
Old Nov 13, 2013, 12:27 AM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Yes the Futaba T6J output ppm on the trainer port(details here):
http://users.belgacom.net/TX2TX/tx2t...h/tx2txgb3.htm
With the Futaba trainer socket you also get V+/Ground to power your SuperMicro module which can be Velcroed behind the Tx. There is a long thread in the Mircro/indoor forum about the HK SuperMicro system:
http://www.rcgroups.com/forums/showt...ght=supermicro
coriolan is offline Find More Posts by coriolan
Old Nov 13, 2013, 11:32 AM
tomahl is offline
tomahl's Avatar
Finland
Joined May 2012
Thank you for your answer! Supermicro module and receiver etc. now ordered. Hopefully this will work. Have been looking all around for some info about "compability" with the T6J, but nowhere to be found. Might post my results in the supermicro thread you linked to for others to know.
/Tommy
Old Nov 13, 2013, 01:29 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
All you need is to locate the appropriate pins on the module(Futaba or JR type)to connect the ppm out,V+ and ground from your trainer socket. The on line manual for the SuperMicro module is available when you click on "Files" on the HK's site:
http://www.hobbyking.com/hobbyking/s...a_Module_.html
Here is a drawing for Futaba style module pins(JR is different)
Old Nov 24, 2013, 02:35 AM
mrranganator69 is offline
Find More Posts by mrranganator69
FPV Enthusiast
Australia, SA, Port Lincoln
Joined Aug 2012
is there any possible way to use a LRS (long range system) eg. RMILEC, dragonling or ezyuhf with my t6j, i need to know if i should upgrade transmitter
mrranganator69 is offline Find More Posts by mrranganator69
Old Nov 25, 2013, 01:31 PM
tomahl is offline
tomahl's Avatar
Finland
Joined May 2012
The ezuhf is delivered with a futaba square connecting cable. I'm no expert, just have one on my wish list, but it seems to be almost plug and play...
Probably they all work the same way, I guess.
Still waiting for my HK package, took two weeks just the get the tracking number activated , but now it seems to be on its way
/Tommy
Old Dec 15, 2013, 02:38 PM
tomahl is offline
tomahl's Avatar
Finland
Joined May 2012
Module wants to go mode1
Did finally get the parts last week and have now connected the module to the trainer port according to the scheme above. No problems there, just straight forward connecting pins.
Did the binding operation with success, but now I have rudder/aileron and elevator on my left stick. And I used to have a mode2 radio!!!
Probably throttle is on the elevator stick also, didn't connect the motor so I cant be shore.
This really bothers me, hopefully I didn't buy all this stuff for nothing
Figured out the mode problem, by changing mode in the tx menu I got the rudder and elevator changed to the right stick. Now I still have to figure out how to get aileron and throttle to change places...
Old Dec 15, 2013, 07:30 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
Tommy
This might have something to do with SW-1,SW-4&SW-5 position during binding(see the pdf manual under: Files on the HK's site). They have to be set differently for Futaba/Hitec and JR/Spektrum to arrange a channel order compatible with the "Brick" Rx you use:
http://www.hobbyking.com/hobbyking/s...dProduct=18823
http://www.hobbyking.com/hobbyking/s...dProduct=17631
Sold New In Box Futaba T9CAP PCM/PPM 1024 jonathan7x70 Aircraft - General - Radio Equipment (FS/W) 3 Mar 09, 2013 08:52 AM
Discussion Futaba T6J quality??? FCC Radios 7 Feb 18, 2013 07:01 AM
Question Futaba T6J system ironace Radios 0 Feb 17, 2013 05:23 PM
Sold Futaba 7CAP PPM/PCM on Ch. 40 clandestoy Aircraft - General - Radio Equipment (FS/W) 2 Jan 24, 2013 07:03 AM
Question PPM out of R5014 14ch Futaba dude2010 Radios 0 Apr 25, 2012 03:11 PM
