This thread is privately moderated by Heppy Ket, who may elect to delete unwanted replies.
Old Nov 11, 2013, 10:01 PM
Heppy Ket is online now
Find More Posts by Heppy Ket
Sent by Touch Typing
Australia, SA, Adelaide
Joined Oct 2011
Build Log
Zeta Science FX-79 Buffalo Professional FPV Flying Wing
Thanks to Jason, who asked me to do the build log and testing as he was unable to proceed due to unforseen last minute commitments elsewhere, Thanks also to Jill from Zeta Science.
Lets begin, I thought I'd get this going and add the video once that has finished uploading.
First Impressions,
She came wrapped in bubble wrap and taped inside a cardboard "tray" which was contained in an outer carton. The outside carton had been pierced by a largish blunt object that had not penetrated the inner carton, the aircraft arrived intact with no damage.
Gosh it's big. I have a Gentle Lady 2 metre sailplane that is an old favourite FPV ship, but this thing has such "presence" it is sure to impress out in the field and in the air.
Compared to the Skywalker the cargo area looks capacious. Another word for big.
FX-79 Build Log part A (1 min 25 sec)
Heppy Ket is online now Find More Posts by Heppy Ket
Old Nov 11, 2013, 11:29 PM
JasonWallis is offline
Find More Posts by JasonWallis
The Aero Scout
Australia, WA, Perth
Joined May 2013
How long does it take to upload a video these days? .... oh that's right the new Govt has scrapped the NBN now hasn't!
Keen as mustard to see this ship matey.
JasonWallis is offline Find More Posts by JasonWallis
Old Nov 11, 2013, 11:46 PM
Joined Oct 2011
Vimeo is still chugging away, off to work for a while now and will commence construction this evening, won't get a lot done, but I'm busting to start.
Old Nov 12, 2013, 06:11 AM
Joined Oct 2011
Slide evening, a closer look, leafing through the instruction manual
Here are some pictures, there is a manual in the first post of the Discussion Thread (Photobucket, bit hard to read the detail)
http://www.rcgroups.com/forums/showthread.php?t=2023676
Recently added PDF manual (much better) thanks Jill
http://www.newzeta.com/download/fx79_manual.pdf
The wing looks to be straight forward, I personally would prefer the servo linkages to be on top of the wing out of the way of landing obstructions, but I'll go with this as it is, there is a belly skid on the fuselage and a wingtip skid that may perhaps keep the linkage clear of most obstacles.
So to the first slide
Description:
A nice clean looking nascelle in the centre of the wing, with a large access hatch that is secured with zip ties to two clips that clip onto the spar, simply grasp the hatch either side of the zip ties and wriggle upwards. That will save you cutting through the zip ties and replacing them later, I may use something a little more "aerodynamic" in any case. Or, you could always use the zip ties as handles, which is most likely why they are there!
Description:
Then you can remove the upper nose section, it is attached with double sided tape. It allows good access to do whatever you want in there unimpeded. I'll be glueing mine back in place once I've decided what to put in there.
Description:
Then there are the two little hatches to left and right (port and starboard if you prefer) of the main hatch. Possible to put vtx and aircraft receiver in here, lots of food for thought here. Many possibilities.
Description:
The twin fins sit on the wing stubs for the moment glued on later I think. and the wing attaches quite neatly outboard of them, there is a machine screw to undo first, fit the wing into place, and replace the screw, it appears to be quite secure. I think you'll want a good stock of spare screws for the great outdoors.
Description:
I didn't tackle the upper motor cowl as yet looks like it should come off allowing access to the motor mount, need to do it carefully, double sided tape again I expect.
Old Nov 12, 2013, 02:52 PM
NutBag is offline
Find More Posts by NutBag
NutBag's Avatar
Australia, QLD, Brisbane
Joined Oct 2005
Good stuff mate, you're doing a much better job than I would here.
I get too excited, build too fast and forget to take any pics
Are you going to make it one piece?
I'm lucky enough to have 2 big cars so I'm planning to glue it all up solid.
NutBag is offline Find More Posts by NutBag
Old Nov 12, 2013, 03:24 PM
Joined Oct 2011
Thanks Chris, it is hard to pause for the pix once you get into a gallop that's for sure. No I am going to leave the wing detachable so it'll be a three piece. I have to find some spare screws as I can see a looming disaster there one day when I drop one in the grass
That will also be a good point of comparison for the viewers!
I have a Holden (Daewoo) Viva wagon, I have a Scout Bee that just goes in, I fear this will be tooooooo big!
Looking forward to your build.
Old Nov 13, 2013, 04:17 AM
Matty12 is offline
Find More Posts by Matty12
Matty12's Avatar
Australia, WA, Broome
Joined Feb 2013
Just tie it to the roof, don't drive too fast though or you'll take off!!!
Where did this one come from, what shop?
Matty12 is offline Find More Posts by Matty12
Old Nov 13, 2013, 04:30 AM
Joined Oct 2011
Had one like that I called it Miss Piggy, has been stripped of FPV duties and awaiting trial as a slope soarer, possibly Sunday by the weather forecast.
No shops have this as yet, I have it to do this build log and I guess that will promote some interest and provide feedback to the good folks at Zeta Science. This is the same company that brought out the Phantom FX61 that Hobby King sell. Possibly they might sell this one in the future.
I'm currently just painting a few bits and putting the canopy latch together and thinking about the internal layout.
Also planning to put in a tow hook as I think this one will be launched by bungee especially if I'm flying on my own.
Good to hear from you and thank you for your interest, feel free to chime in with any comments, observations, questions or what have you.
Old Nov 13, 2013, 04:49 AM
Joined Oct 2011
Let building commence!
I have decided to leave the wing until later as I am waiting for servo's. According to the manual the fuselage is next.
Description:
I have painted the nose section satin black (after wiping down with metho first) as cameras are going to be mounted there, what looks to be a camera mount has been provided, It's ply wood and some screws etc, I'm deciding how to use it to mount the flight camera. This will be a Fatshark 420line CCD camera on a pan servo.
Description:
Next I have glued the retaining clips to the canopy hatch and re-attached the cable ties to use as handles to remove when necessary, seems to have a strong positive action should work well, not a magnet in sight .
Description:
Description:
Old Nov 13, 2013, 05:56 AM
Joined Oct 2011
Pest alert!
Tarnation! While waiting for paint to dry, thoughts to clear I decided to look at the motor mount. It's plastic and you are instructed to use the cross shaped mount that would come with the motor, all good so far, but the screws are too short.
Can't fit to the plastic on it's own (probably not a good idea anyway) so off to get some screws tomorrow, The ones supplied (with the motor) are 8x3mm so I'd better get a selection, after all I want them long enough but not too long.
what a pest!
Old Nov 13, 2013, 09:19 PM
Joined Oct 2011
Onward and upward
Off to Jaycar (electronics store) for some 3mm screws, you can't beat them for a good screw ended up with a packet of 25 10x3mm roundhead screws. I'd have preferred countersunk of course, but one must make do. They appear to be a good fit.
The motor is a Turnigy D3536/6 1250kv erm at 3s a 10x5 prop and 4s a 9x5 prop I think.
As a bonus I now have spare screws for the detachable wings, probably best used with washers.
Description:
Description:
Description:
Regarding the little hatches either side of the central hatch, I have decided to put the Ez-UHF receiver in one side, and the Ez-Osd in the other assuming everything else will fit in around this. They'll be fastened by tape at this stage so I have access to the contents later.
The motor is now in and has been run up with a 10x6 prop on it, will hook up the Watt Meter tomorrow and see What's up. (Gee I don't know where I get them from)
Old Nov 14, 2013, 09:50 AM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
Its is worth $299.00 + shipping?
(opinions).....
p.s.
does it come with Servos?
rclab1 is offline Find More Posts by rclab1
Old Nov 14, 2013, 11:57 AM
fallingdown is offline
Find More Posts by fallingdown
United States, OR, Portland
Joined Apr 2011
Good grief I thought my FX61 was huge! The misses would have my berries in a vise if this one showed up on the door!
fallingdown is offline Find More Posts by fallingdown
Old Nov 14, 2013, 02:10 PM
Joined Oct 2011
It would be very difficult to sneak this one in, that's for sure! I can't wait to see it up against a friend's X8. Worth $300us and then add the shipping, ah well the simple answer is it is worth what you are prepared to pay for it. Compared to others, for myself, probably not unless, it turns out to be a very exceptional airframe. No, there are no servos included.
Old Nov 14, 2013, 03:43 PM
NutBag is offline
NutBag's Avatar
Joined Oct 2005
Looking good Heppy!
Hope to start mine tomorrow.
(opinions).....
p.s.
You could always ask these guys for one and do a full review.... it seems to come with motor, esc etc.
http://www.rcgroups.com/forums/showthread.php?t=2036388
For Sale Zeta Science HobbyKing FX-61 Phantom Huge Flying Wing (Aberdeenshire, UK) fpsazerbaijan FPV Equipment (FS/W) 2 Oct 30, 2015 04:36 AM
Discussion New FPV Age ZETA FX-79 Buffalo 2000mm Professional FPV Fly Wing Jill Liu FPV Aircraft 491 Apr 25, 2015 07:24 AM
Discussion zeta fx-79 fpv flying wing ssteven1 FPV Aircraft 8 Nov 14, 2013 05:20 AM
Discussion New FPV Age ZETA FX-79 Buffalo 2000mm Professional FPV Fly Wing Jill Liu FPV Aircraft 2 Oct 26, 2013 08:59 PM
