Team Associated RC10TC6.2 Factory Team Kit
1/10-scale electric 4WD touring car kit
Revised and ready to dominate—the Team Associated RC10TC6.2 FT!
Team Associated wisely took its race-proven, championship-winning TC6 chassis and overhauled it with many performance-boosting upgrades to create the all-new RC10TC6.2. Among the updates is a new bulkhead, top plate and chassis configuration that allows you to adjust flex in the chassis, thus giving maximum grip on any track surface. The suspension arms have a new mounting system where you can swap out toe inserts thus giving the driver a massive amount of tuning options to dial in the TC6.2. Up front, the servo was given a floating mount which helps with steering control and offers more space to mount the receiver and speed control. At the rear you will find a lightweight gear diff for optimum performance, adjustability and decreased required maintenance. Mounted at all four corners are Factory Team VCS3 shocks that are equipped with hard-anodized threaded shock bodies with bottom-loaded seals, Titanium Nitride coated shock shafts and an increased stroke that all add up to improved overall traction.
1/10-scale electric 4WD touring car.
Power SourceElectric
TerrainOn-Road
Body StyleTouring Car
Scale Size1:10 Scale
Build typeKit
Length381mm (15 in.)
Width190mm (7.48 in.)
Wheelbase255mm (10.04 in.)
Weight1,375g (3.03 lbs.)
Internal Gear Ratio2.0:1
Drivetrain4WD
Item no.30109
Price$419.97
KEY FEATURES
  • Updated bulkheads and arm mount system for precise suspension adjustments and consistent flex through the entire length of the chassis.
  • Optimized dual bellcrank ball bearing steering system with adjustable Ackermann and improved steering rates.
  • Floating servo mount fits most popular servo sizes and allows for a tweak free assembly with equal chassis flex in both directions.
  • Narrow 2.25mm graphite laminate chassis provides optimized flex characteristics and minimizes possible dragging at maximum chassis roll angles.
  • Floating spur gear mount design allows for more flex through the rear of chassis to increase traction in all conditions.
  • Ball stud positions are optimized for fine adjustments of roll center and camber gain.
  • Spur gear and top plate have been lowered to allow for more chassis flex and increased traction in any condition.
  • Lightweight rear gear diff with hard anodized aluminum outdrives, and front spool with replaceable composite outdrives.
  • VCS3 shock with hard anodized threaded shock bodies.
  • Titanium turnbuckles with ballcup eyelets for easy access to ball stud.
  • 22 precision ball bearings.
  • Cross-compatibility with all TC6.1 suspension components.
REQUIRED TO COMPLETE
  • Motor, Speed control, Battery, Battery charger, 2-channel radio system, Steering servo, Polycarbonate touring car body, Paint for polycarbonate & Rubber or foam touring car tires
Visit the site for more info on products from—TEAM ASSOCIATED!
Old Dec 14, 2013, 05:29 PM
tommymestdagh is offline
Find More Posts by tommymestdagh
tommymestdagh's Avatar
Joined Jan 2005
Can't wait..... it's in backorder.
tommymestdagh is offline Find More Posts by tommymestdagh
For Sale RC Car Team Associated B4.2 Factory Team Buggy Ready to Drive [$480 shipped] Libtekguy Cars - Cars and Parts (FS/W) 0 Sep 23, 2013 06:08 PM
For Sale Team Associated RC18B, Factory Team Kit, PN# 20107. NIB Jrcon31 Cars - Cars and Parts (FS/W) 0 Aug 27, 2013 10:23 AM
For Sale Brand New! Team Associated RC8.2E Team Factory Kit with tons of extras and upgrades! scienc Cars - Cars and Parts (FS/W) 0 Aug 14, 2013 05:11 PM
Sold Brand New! Team Associated RC8.2E Team Factory Kit with tons of extras and upgrades! scienc Cars - Cars and Parts (FS/W) 4 Aug 14, 2013 05:08 PM
Sold factory team team associated B4.1 I.res.q.u.911 Cars - Trucks and Parts (FS/W) 5 Jan 08, 2013 07:23 PM
