Old Nov 08, 2013, 09:12 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
New Product
Vector from Eagle Tree - Full Color OSD, Fixed Wing & Multirotor Controller with RTH
Note: For Vector pricing and availability information, please click here to visit our website.
Hey guys, we've had our heads down for a while working on the Vector, and finally I can talk about it! The goals for the product (set a long time ago) were to do some seemingly common sense things - things that we wanted ourselves in a controller:
  • A more intuitive display. We have cones in our retinas for a reason. It's been said that a full color OSD that works with any type of camera was super hard to build. I was hooked when I heard that.
  • A flight controller that's equally at home in fixed wings and multis. Most of us have or will eventually fly both, so why have to invest in two different devices (with their own idiosyncrasies) when we want essentially the same features from both. The controller also needs to be integrated with the OSD so it can be tuned with your radios sticks and so you can see controller information on the screen.
  • Simpler, more plug and play wiring and setup. We've tried to simplify every aspect of FPV setup, without sacrificing the features that we all want. You should be able to just plug in your transmitter and camera without fighting with wiring, power supplies, etc.
So, here's what we've come up with.
Eagle Tree is excited to unveil the Vector FPV Controller!
Years in the making, the Vector has everything we've dreamed about having in one small, lightweight product:
  • Built-in OSD with COLOR GRAPHICS and fully customizable screens (make it look as simple or robust as you like!)
  • FIXED WING and MULTIROTOR Flight Controller with GPS modes and RTH
  • SIMPLE to set up and operate "out of the box", with no PC required for most features
  • COMPATIBLE: PCM, SPPM and S.BUS receiver support, with four types of RSSI
  • EXPANDABLE with additional sensors, accessories, and internet firmware updates
  • FLEXIBLE: fly with or without your FPV camera and transmitter
  • REDUCED WIRING: innovative wire harness with power distribution simplifies hookup
  • Current sensor with quiet and efficient filtered 12V* and 5V Power Supply Unit supports up to 6S packs
  • Built-in altimeter, IMU and magnetic compass sensors
*see Current Sensor section for details
Vector on a Funjet (3 min 47 sec)
Vector on a Multirotor! (5 min 31 sec)
Feature Details
The Vector system includes the base controller unit, the GPS/Magnetometer, and the Current Sensor/PSU. The Vector's feature list is quite long, so what follows is an overview of the main features:
Full Color OSD
The Vector's built-in OSD provides features not found anywhere else.
  • Smooth, razor sharp color graphics: tired of staring at hard to read white text with clunky graphics? The Vector changes all that. WARNING: a full color OSD can be addictive! Colors are fully adjustable to your preference.
    In addition to the graphical features shown above, nearly all of the Vector's parameters can be displayed in 3 ways:
    • Numeric - same as always, but in color, with programmable flashing color alarms
    • Gauge - you can easily set up parameters to be displayed in gauge format, with programmable color thresholds
    • Swatch - Instead of staring at a number, you can set up a simple color square (we call them swatches) with programmable color changes, to easily see when a parameter needs your attention.
  • Fully Customizable OSD Screens: Your way is the right way. You can select what features and parameters to display on multiple screens, and switch between them with a click of a switch. The display can be as simple or robust as you want it to be!
  • Voice alerts: The Vector can speak flight information to you periodically, or on programmed alarms.
  • Variometers: The Vector is the first OSD to provide a charting graphical variometer, as well as acoustical tone variometers. The variometers are fully programmable to suit your taste.
  • RSSI: The Vector supports four types of RSSI:
    • Analog (fully buffered input)
    • PCM - some receivers output a varying pulserate to indicate signal strength, which the Vector supports.
    • Spektrum - all Spektrum FlightLog telemetry parameters are available for display, as well as a feature that combines them into a single RSSI display
    • Virtual SPPMRSSI: some receivers output RSSI and link quality via the SPPM interface, which is supported
  • Fast, easy control and menuing system: The Vector utilizes switch "gestures" and your control stick to let you rapidly scroll through menus and change parameters. All OSD parameters can be configured via the stick menus!
  • Kitchen sink: Of course, all the other OSD features you've come to expect from Eagle Tree, such as RADAR, ladders, compass, full 'F16' AHI, flight simulator, manual waypoints, monitoring of up to four battery voltages, and a huge list of parameters available for display are there in the Vector.
Flight Controller
Utilizing our proven Guardian technology, the Vector's built-in, full featured flight controller is equally at home with both fixed wing (traditional, elevon, v-tail, etc.) and multirotor (quadcopter, hexacopter) aircraft.
And, since the controller is fully integrated with the OSD, everything can be adjusted via the onscreen menus, rather than needing to drag a laptop or other device to the field.
You can even move the Vector back and forth between your fixed wing and your multirotor at the field, with no PC configuration needed!
Advanced Flight Modes
Numerous flight modes are available, and are easily selectable via one or more switches on your radio:
  • 2D: multirotor or fixed wing leveling with or without altitude and heading hold
  • 3D: direct rate 3D with or without heading lock, for doing acrobatics when you get bored just flying along. Great for holding 3D positions such as knife edges or inverted flight, or doing flips with your quad (experts only!). Pitch, roll and yaw direct rates are programmable of course.
Additionally, the following GPS control modes are supported, with additional modes planned:
  • Return to Home (RTH): Whether you fly fixed wing or multirotors, our advanced RTH algorithm means few if any adjustments are needed.
  • Geofence: lets you program a maximum ceiling and distance for your model.
  • Loiter: for multirotors, this holds the present position using the altimeter and GPS, and for fixed wing, the plane circles when loiter is triggered
  • Cartesian: this multirotor control mode remembers the direction that the 'copter was pointing when you armed it. Stick-left makes it fly to the left, stick-back makes it fly backwards, etc.
Simple but Powerful Radio Control Interface
The Vector's receiver input harness with labeled connectors makes it easy to connect to any receiver.
The Vector supports three types of RC inputs:
  • Standard/PCM: the Vector's labeled servo connectors just plug into the appropriate receiver channels
  • SPPM and S-BUS: a single cable connects to your SPPM or Futaba S.BUS compatible outputs, for reduced wiring and more flexibility. The PC software lets you dedicate up to 11 serial channels to the Vector, making it easy to support a variety of OSD features.
The Vector's flight modes are easily accessed via a 2 or 3 position "mode switch" on your radio. Further, a "submode" switch can be configured to allow more modes to be easily selected during flight. The meaning of each switch position is easily programmable via the Vector's menus.
Current Sensor with Integrated, Filtered Power Supply Unit (PSU)
Tired of using multiple batteries, LC filters, BECs for your video, etc.? The Vector's current sensor/PSU makes it super easy to power your equipment.
The current sensor is available with Deans, XT60, or wire leads.
The high efficiency, low noise PSU accepts up to 6S voltage input, and provides filtered 12V* and 5V output. It's perfect for powering most FPV gear, and also powers your receiver on multirotors with 'opto' ESCs, eliminating the need for an external BEC (the PSU should NOT be used to power servos!).
*Note that the 12V regulator does NOT boost the voltage, like a SEPIC. However, the Vector's 12V PSU has a unique Low Voltage Loss feature that drops the regulator's output by only about 0.5V if you are using a 3S pack operating below 12.5V. For example, if your 3S pack is at 11.5V, the regulator outputs about 11V. Other non-boost switching regulators typically drop the output voltage by 1.3V or more.
NOTE: SEPIC and other voltage boost regulators are generally less efficient and generate more UHF band noise, especially as your pack voltage drops, and in many cases you don't need one. All known cameras and many transmitters will operate well across the 3S voltage range. Check your transmitter manual's specs to determine this. If your transmitter does need a boost when operating at the lower end of 3S, a JST equipped boost regulator can easily be connected into the Vector's AV harness without needing to solder or cut wires.[/LIST]
Wiring Made Simple!
The Vector's innovative wiring harness makes it easy to connect your 5V or 12V cameras and transmitters without keeping an electrician on standby. If your camera and transmitter have servo style connectors already, you just need to plug them into the labeled plugs, select the appropriate voltages, and away you go. And, if you prefer to use two or even three flight batteries, additional filters, voltage boosters, etc., that's trivial to do without needing to do any rewiring. The harness also makes it easy to move the Vector from model to model without removing all of the wiring as well.
Additionally, fully plug and play cables for Fatshark/IRC transmitters (with GoPro Hero 3/4 or Fatshark style cameras) make installation even easier!
EagleEyes FPV Ground Station Compatibility
The Vector fully supports our EagleEyes Ground Station. On-screen menus make it easy to set up EagleEyes features. New, greatly simplified antenna tracking setup wizards make it easy to configure your EagleEyes compatible tracker.
Powerful PC Setup Software
Want to configure your Vector via your PC or laptop? Our powerful PC software and the Vector's USB interface make this easy. Drag and drop screen setup lets you see how the display will look as you configure it. Configuration files let you easily move your Vector from model to model without needing to reconfigure everything. Tabs for visualizing GPS flight data, setting manual waypoints , and many others make it quick and simple to fully utilize your Vector.
Data Logging and Telemetry
Of course, the Vector fully supports data logging of sensor and GPS parameters via internal storage, and our PC software lets you display, graph, visualize and save the data. Variable logging rates and advanced logging triggers are supported.
The Vector also embeds real-time telemetry in the video signal for use with the EagleEyes ground station.
Further, the Vector's UART port is compatible with open source telemetry transmitters and other hardware. We plan on supporting the UART interface with a variety of telemetry related features in the future.
Want to Learn More about the Vector Features and Ship Status?
We will be updating this page, our new Facebook page, and our Vector page here with all the latest information. We would love to get your feedback about the Vector also! Don't hesitate to post questions here or to email us directly!
** ALL VECTOR INFORMATION PRELIMINARY AND SUBJECT TO CHANGE!!! **
Deans, Futaba, Spektrum and all other brand and product names are trademarks of their respective holders.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Nov 08, 2013, 10:46 PM
Bonafidepirate is online now
Find More Posts by Bonafidepirate
define("BEASTMODE", "1");
Bonafidepirate's Avatar
United States, LA, Moreauville
Joined Jan 2002
Looking forward to it! Any idea of a price yet?
Bonafidepirate is online now Find More Posts by Bonafidepirate
Old Nov 09, 2013, 02:25 AM
out0f0rder is offline
Find More Posts by out0f0rder
UB9ALF
out0f0rder's Avatar
Joined Jan 2013
Shut up and take my money, Bill.
Very impressive announcement! I think that's the most impressive FPV product for some time past.
Congratulations!
A couple of questions:
* Does the Vector supports old peripherals such as airspeed sensor?
* Does it supports autonomous mission on fixed wings and/or multicopters?
* Any additional requirements for cameras/video TX?
* Any hint on availability/price? Will we get it this year?
out0f0rder is offline Find More Posts by out0f0rder
Old Nov 09, 2013, 03:33 AM
KIR2142 is offline
Find More Posts by KIR2142
KIR2142's Avatar
Russia, Klin
Joined Nov 2010
baro on board?
KIR2142 is offline Find More Posts by KIR2142
Old Nov 09, 2013, 09:54 AM
UB9ALF
out0f0rder's Avatar
Joined Jan 2013
Originally Posted by KIR2142 View Post
baro on board?
Bill, is it true, that new OSD doing video overlay by additive method? That is, it have only one video connector which is common for camera and vTX?
Old Nov 09, 2013, 11:52 AM
GuyPilot is offline
Find More Posts by GuyPilot
Joined Jan 2011
Excellent news ....
GuyPilot is offline Find More Posts by GuyPilot
Old Nov 09, 2013, 12:28 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Thanks, guys!
out0f0rder,
Ha ha!
Yes, it supports our Airspeed V3 sensor. You'll just need to build/buy a cable adapter to JST. We'll be releasing a JST based airspeed sensor for the Vector also.
Not presently. It allows you to program waypoints that display on the screen, though.
No. If your equipment has servo connectors, you just select the right voltage and plug them in.
We have to row a few more ducks before I can comment on that. Soon!
It's done the standard way - the camera input is processed by the OSD, and fed to the video transmitter. Additionally, if you use a mic, the voice prompts are synchronized with the mic input, and output to the transmitter's audio. This is the same as with the OSD Pro, for reference.
Site Sponsor
Old Nov 10, 2013, 04:38 AM
electricmick is offline
Find More Posts by electricmick
electricmick's Avatar
United Kingdom, England, Castle Donington
Joined Aug 2010
Excellent news Bill. Really pleased you are addressing the wiring issue. I have a quad with a Naza FC for FPV. I tried to fit my ET OSD and it was a nightmare, gave up and removed it. The Vector will be an excellent solution for FPV multirotor and fixed wing alike.
One request: can you please implement an autopilot with a simple mission planner, then it will be a worldbeater. Thanks, Mick
electricmick is offline Find More Posts by electricmick
Old Nov 10, 2013, 07:05 PM
surf1punk is offline
Find More Posts by surf1punk
RC FPVer
surf1punk's Avatar
United States, FL
Joined Nov 2011
Looks great! Look forward to getting one of these when they come out! Is it going to replace the OSD Pro Package?
surf1punk is offline Find More Posts by surf1punk
Old Nov 11, 2013, 01:23 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
sub'd.... though pricing will be the the primary factor for whether or not I go with one of these.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old Nov 11, 2013, 09:42 AM
wazoo22 is offline
Find More Posts by wazoo22
wazoo22's Avatar
France, Bourgogne, Nevers
Joined Feb 2012
Aileron, aileron, where art thou, second aileron?
Do we get the second aileron, Bill?
wazoo22 is offline Find More Posts by wazoo22
Old Nov 11, 2013, 12:25 PM
mithrandir is offline
Find More Posts by mithrandir
TEAM FUTABA TEAM DURALITE
mithrandir's Avatar
Joined Nov 2004
Nice!!!
Did you comment on expected ranges?
mithrandir is offline Find More Posts by mithrandir
Old Nov 11, 2013, 02:04 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
This is VERY cool Bill!!
One suggestion, arduplane has a feature called "cruise." I essentially set a waypoint 1km ahead and flies to it, compensating for cross wind. Once it reaches that, it set another way point ahead. This helps it to fly in a perfect line/track. That would be great for long distance flying.
That and some sort of altitude hold function, either with that 'cruise' mode or whatever, would be great. One issue I've had is while trying to circle and look at something, I end up in a dive.
Oh and just to clarify. This will work as a Flight Controller for a multicopter correct? Vs. providing those features in addition to a dedicated (third party) flight controller.
ashdec87 is offline Find More Posts by ashdec87
Old Nov 11, 2013, 03:01 PM
KevinW (Qwin) is online now
Find More Posts by KevinW (Qwin)
Eschew obfuscation
KevinW (Qwin)'s Avatar
United States, FL, Apollo Beach
Joined May 2011
cool stuff.
I like my current ET system so much, Im sure I'll eventually move to this...
Still having fun installing stuff in a new airframe.
KevinW (Qwin) is online now Find More Posts by KevinW (Qwin)
Latest blog entry: What do you call a landing....
Old Nov 11, 2013, 05:52 PM
USA, GA, Atlanta
Joined Nov 2008
Whatcha building kev?
Discussion Pitch curve, we talk about anything and everything scale heli here cap231ex Scale Helicopters 1639 Feb 25, 2016 01:30 PM
Discussion I just had the wildest dream about FPV jhroof FPV Talk 1 Dec 23, 2015 11:29 PM
Discussion Dreaming about Multi Rotor setup : Multi+GoPro+eagle tree everything? crashtested Aerial Photography 11 Apr 10, 2015 10:18 PM
Discussion Why are we up in arms about quad over flights, but not about this? branflakes Multirotor Talk 5 Jan 25, 2015 08:18 PM
Discussion a good interview about gun control and why we carry ... logan5 Life, The Universe, and Politics 8 Jan 08, 2013 06:43 PM
