If you cant slope this ship on a little slope, you just cant slope anything there. Id say it only sinks about 1' after traveling maybe 40'. I was catching slope lift in a field with a 5-7° incline in a 10mph breeze... I'm anxious to try it out a local manmade lake. It has a 40' tall hill at one end with a 45° slope and the wind frequently goes right over the lake and up the hill. I'll add some ballast (maybe 3-5 Oz) when I get a chance to fly there.
SAL (side arm launch) is not the same as a discus launch. This is a slight error on Art Hobby's web site. Yes, what you see in the video is the Colibri being SAL'd. You cant launch a 60" glider this way - you'd hit the wingtip on the ground (unless you're over 7' tall). A SAL is a low, sweeping toss with a steep release. A discus launch is much different and includes a full 360° rotation and a couple steps before a shallower release. I havent added a peg yet. I've been thinking about how to accomplish this though. I wouldnt risk the integrity of the sheeting by just drilling a hole and gluing a carbon peg through it. I think you'll need considerable reinforcement, and in the correct direction. I've been thinking about glassing the tips and installing the peg through the glass, but I'm not sure that would be enough either. Ideas? Did you get your kit? |
John,
The Elster is advertised at 9.82 Oz. I covered the original tail (not in the instructions) and the v-tail splitter (for elev only control) was somewhat heavy. I'm not at all sorry about the weight. I think it helps the launch height. Maybe I'm wrong. I'm estimating 5 minute flights from the Up-start by comparing the performance of my old HLG (scratchbuilt foamie with tape reinforcements) to the Elster. I'll report actual times after they take place. I think you're right about the Expert Rx. Looks the same and has the JR ABC&W technology (whatever that is). I'm not sure about the range yet. I had another of these that brought down my 7lb brushless Cub on its 2nd flight, so I'm hesitant to fly it, but since then I've gone back to the Tx's original frequency (had installed different xtals with the Cub). Havent had any problems yet, but I havent had the Elster more than 300' away. |
Wow!
Dang it, the truck passed me by again! No HLG until Christmas??
Thanks for the picture.. Man, that is a small pod! I can see where there might be a problem getting two servos in there for the V-tail.. Is the V-tail splitter hardware explained in the instructions? If not, please tell me about it. Peg: I saw a HLG site photo somewhere that showed a neat air-foil shaped (tear drop) aluminum peg that was mounted through the wing tip and was surrounded by a disk of FG or CF (about 30 or 40 mm in diameter). It looked very solid. I can't relocate the site, but I think the wing may have been wood over foam.. Here is a photo from Art Hobby of the custom pack they sell for the Elster. The nose-end cell is turned on it's side to fit inside the nose. Looking at your photo, it seems like you might be able to move a 'custom' pack forward 8 to 10 mm from you current pack position. |
He don't need no stinking pegs!
Here is part of an Email I got from Andre. If I did this, I would use some sand or grit from some sandpaper. (To avoid loosing my fingerprints).
Rich<> ------ On my gliders I did little an improvement on how the wing tip is finished, and to have an excellent grip: I took a piece of clear glass and (with every safety precaution) hammered it to a powder. Then right after applying the third coat of lacquer to the wing surface I sprinkled the glass powder over the wing tip, and repeated the same operation on the lower surface of the same wing tip. After a few minutes I sprayed final finishing coat of lacquer over the wing. This kind of finish is invisible and allows me to have a very secure grip I highly recommend first practicing this finish on a piece smooth surface hardwood. Then if you are satisfied with your results, duplicate the same operations applying this finish to the wing tip. |
Those cells are the same size as mine. I had the same idea, but I needed room for the nose weight, and the farther forward, the better. I filled the little section of the nose with bb's set in candlewax., and also have 2 X 1/4 Oz lead slabs, one on each side of the battery (visible in photo).
Yeah, Andre sent me that too, but I was a little scared of it (I may use sand however). Also I think a peg will be more effective as you'll be able to give a forward shove with your fingertips at release to arrest some of the rotation. My Elster rotates about 20° to the right (in pure yaw) immediately after launch, but quickly straightens out and the trajectory is straight. I'm sure with more practice, it'll rotate less. Materials for the control joiner are supplied. Make sure you find the extra length on wire in the kit, it is for the joiner. I made a different joiner in versionb of my tail. I used one size smaller wire (.025"?) for the pushrod and 'joiner' pieces. Also I changed the way it is assembled to reduce the weight. I started with about a 5" length of wire. Bent it in a sharp bend (almost doubled over), with a sharp crease at the bend. I did this by making the bend w/ needlenose pliers, then squeezing the round till it was almost flat. I then bend the 2 z bends in the ends, but I didnt use z's I actually used 'L' bends and spread the joiner out a bit so it would be retained between the control horns with a little outward pressure. Then I gave the pushrod a sharp bend about 1/2" from one end and 'interlocked' the bend in the pushrod with the sharp bend in the (front of ) the joiner. Slipped a small piece of heat shrink tubing over this intersection and glued with thick CA before shrinking the tubing. Very light an effective. Make sure you measure very carefully before making the control horn 'L' bends, as any error will produce 'rudder' effect. Here's a pic: Keep in mind this is the new tail, not the one in the kit. Also, it is mounted directly to the boom rather than on the supplied removable mounts. |
Broke it already!
Hello Far4,
It came today! The wings looks great. The tail seems too light to survive a sneeze.. The boom was a tad fat, so now I have a split pod.. Did you sand your boom down any? Or did it slide right in? Anyhow, I don't even have any scrap balsa to build the Fuse Jig.. Maybe I'll be flying by Next weekend ![]() When I go do some flight checks on my new radio tomorrow (I'm going to fly it up high in the Razor), I'll drop by the LHS and see if they have any 2-56 rod, Mini-clevises and Hinge Tape. Then I'll go to the other more distant LHS and get the rest of the stuff.. ![]() I wonder if it's wise to use a metric Nylon wing bolt? The local hardware only has standard English Nylon hardware.. Maybe I should have ordered some 3mm with the kit.. Cheers, Rich<> |
Cambridge, MA USA
Joined May 2001
- Mark |
Move the Servo up too!
Wow, those are small. Did you order the pre-built $14 pack or
did you roll your own? And what rate do you charge them at? I've done a lot of soldering, but not too many batteries. Maybe it's time to learn how to make my own packs. Think I'll be calling in my order in the morning. Thanks, Rich<> |
Cambridge, MA USA
Joined May 2001
Re: Move the Servo up too!
I charge them at 1C using my Sirius 200. This charger is just about perfect for the new NiMH HLG packs. www.tgworks.com carries it. - Mark |
Rich, Sorry to hear about breaking the fuse
I'm sure its an easy fix. I just sanded mine a bit to break the glaze and slipped it in with some thick CA. If you fear the strength of the boom is too weak, just try to break it! Its very tough!2-56 rod? for what? I think it'll be too heavy for this application. Keep in mind you must build as light as possible, especially from the CG back. The wire I'm using is thinner than the stuff supplied in the kit, and THAT was smaller than 2-56. I think clevises are too heavy for the tail also. Just make some simple bends in the pushrod wire. If you mess it up, try again! A 3' length only costs $.50 or so! I didnt bother with the jigs in the instructions. I didnt see how they'd be helpful, so I skipped it. Mark, thanks for bringing up these cells, I think they'll be perfect for this plane! Are these AAAA's the same size as the cells that come out of SOME 9V nmh rechargables when you remove the plastic/metal case? I had a wonderful flying session with the Elster today! The wind was about 15-20mph and from the North, so I headed to a nearby lake with a 30-35' tall dam (hill) at the South end. I ballasted the plane with 3 Oz of lead at the CG and added a tell-tale to my Tx antenna. It was great just soaring back and forth across the slope and putting her in a stationary hover! At times I could get her up about 100' and do some nice speed runs. It carves turns nicely and retains energy well. When the wind was higher, I would just shoot from one side of the dam to the other, whip off a turn and shoot back. I was surprised at how well the 15 Oz plane took the gusts - no problem. I had complete control at all times, and even with moderate gusting, it flew very smoothly. Lots of people walking across the dam stopped and watched and asked questions. Next time I think I'll ballast with 6 Oz and get even more speed out of it. Keep it up Rich, you'll be done before you know it. Cheers! |
Sounds like someone is having fun!
The Fuse went on fine, after a little sanding.
After picking up the 2-56 (per the parts list), I put them back when I found some ligher hardware. Thinner wire and mini-nylon clevises. Since this is my first model in many years, I followed the manual and built the jig. It might help a novice ![]() Could not find any Hinge Tape! and I forgot to order the AAAA cells yesterday! (Update:12/17/01 ordered 12 with tabs) Step 2. Glue the tail. Messed that up. It's about 120 deg instead of 110. I'm thinking about breaking it down and doing it again. What do you guys think, 120 too much? It's cold outside, but I'm thinking about flying my Razor today (to check out the HLG rec). Update: Just got back. The GWS R-6N/H worked very well. Got into some serious lift on the last flight, a FS Cessna came over at about 1,200 feet. He passed about 1,000 feet under the Razor. |
Cambridge, MA USA
Joined May 2001
200 mAh AAAA NiMH: 0.275" dia, 5g 120 mAh AAAA NiCd: 0.300" dia, 6g BTW, my NiMH pack tests at 195 mAh. The best I've ever gotten from the NiCds is 100 mAh. These ratings are at a 125mA discharge. You will freak at how tiny the NiMH pack is -- about the same size as the last two segments of your pinky. It has no problem with current requirements for a 4ch HLG. - Mark |
| Thread Tools | |
| For Sale Well used Art Hobby Hyper 1.5 DLG | madhatter227 | Aircraft - Sailplanes (FS/W) | 10 | Dec 05, 2005 09:35 AM |
| New Art Hobby Hybrid 1.5 DL | WGH | Hand Launch | 22 | Jul 15, 2005 03:47 PM |
| Art Hobby Hyper 1.5 dlg | nimffish | Hand Launch | 4 | May 06, 2005 08:21 AM |
| Art Hobby Falco 1.5M HLG | leverick | Electric Sailplanes | 9 | Feb 19, 2002 07:56 PM |
| Art Hobby Elster 1.5M HLG questions | rlt55 | Electric Sailplanes | 5 | Jan 15, 2002 11:50 AM |
