This thread is privately moderated by Soma, who may elect to delete unwanted replies.
Old Nov 08, 2013, 03:25 AM
Soma is offline
Find More Posts by Soma
Australia, QLD, Brisbane
Joined Sep 2012
Data
Sunnysky V2216 800KV Thrust Test
Bench Test of the Sunnysky V2216 800KV motor with 8 props on 3S & 4S.
Equipment used...
DIY thrust stand and scales
Eagle Tree data logger V3 inc RPM sensor
Hobbyking 30A Blue Series ESC - SimonK 2013-05-15 firmware
3S 9600mAh and 4S 12,000mAh lipo packs
Props...
1. APC 10x4.5MR
2. APC 10x5.5MR
3. APC 11x5.5E Thin Electric
4. Himodel FC 11x5.5 Hyper Drive (APC clone)
5. Carbon Fibre Graupner Style 11x5
6. Gemfan Carbon / Nylon 11x5
7. Gemfan Carbon / Nylon 10x5
8. Gemfan Carbon / Nylon 1045
Notes...
- The test was aimed at 4S, this motor could turn bigger props on 3S
- Lipos were fully charged so somewhat non standard voltages
- The APC 11x5.5E was the only prop balanced out of the packet. All others were OK, except the Gemfans which were very unbalanced.
- Comparing the APC11x5.5E and the plastic clone is very interesting. The difference can be heard in the video. Incredible 225 gram thrust difference between two props that look identical. APC all the way
- The APC 10x5.5MR is almost identical in performance to the 10x4.5MR. Small amount more performance but less efficient.
- The APC multirotor props have slightly less thrust than a slow fly but are more efficient, and are more rigid.
- The carbon high speed (Graupner style) prop was very quiet, efficient and punchy! It would absolutely rock on a higher KV 2216 version
- KV was measured around 770KV by a HK KV tester but the Eagle Tree figures worked out to 875-895KV. I don't know which is more accurate, I would assume the 770KV figure. The right number of poles was selected so go figure?
- The Eagle Tree thermometer was placed in the windings and too affected by air temp. A IR thermometer will be used next time. The comments are a better guide on temp.
- Doc files of the charts are attached
- 4S -
4S - Sunnysky V2216 800KV - Thrust Test (4 min 45 sec)
- 3S -
3S - Sunnysky V2216 800KV Thrust Test (4 min 43 sec)
All Session Comparison
The order of sessions in this chart is... Prop, 3S then 4S etc... The large RPM spikes are errors from the sensor.
I am building a speed quadcopter for FFF and will choose the APC 11x5.5E.
It is powerful, efficient and fast.
It is heavy though, notice it's spool down time and high acceleration current draws.
This prop is just too much for the motor on the bench in static air, hopefully in free air it will rock!
This copter is not for flips but it will be built for size and speed
Soma is offline Find More Posts by Soma
Old Nov 08, 2013, 03:26 AM
Soma is offline
Joined Sep 2012
4S Eagle Tree Data
1. APC 10x4.5MR
2. APC 10x5.5MR
Soma is offline
Joined Sep 2012
3S Eagle Tree Data
1. APC 10x4.5MR
2. APC 10x5.5MR
Old Nov 08, 2013, 04:01 AM
Enforcement is offline
Find More Posts by Enforcement
Australia
Joined Feb 2013
Awesome work mate !
Enforcement is offline Find More Posts by Enforcement
Old Nov 08, 2013, 04:23 AM
Soma is offline
Joined Sep 2012
Thanks mate! Getting there hey
I'll grab a 900KV V2216 now and test it with the CF 11x5 on 4S. Just want to keep it under 20A in flight.
Need some genuine Graupners too!
Old Nov 08, 2013, 05:31 AM
lorenxo.93 is offline
Find More Posts by lorenxo.93
Team Crazy Eagles
Joined Nov 2012
Have you the same test of sunnysky 2212 980kv? I need a comparison between 800kv and 980kv for 3S setup with 10x4.5MR ... Thanks!
lorenxo.93 is offline Find More Posts by lorenxo.93
Old Nov 08, 2013, 08:48 AM
Donnyv is offline
Find More Posts by Donnyv
Donnyv's Avatar
United States, MI, Traverse City
Joined Jan 2012
awesome stuff Soma.. Donny
Donnyv is offline Find More Posts by Donnyv
Old Nov 08, 2013, 03:38 PM
Soma is offline
Joined Sep 2012
I do have some 2212 980's to test. It will just take a while to get it done unfortunately as I don't have a lot of spare time. Hopefully in the next couple of weeks.
I'm building and acro quad with 2212 980's and APC 10x4.5MR's. So that may be done first. I'll post that in the 980 thread when I get it done.
Old Nov 09, 2013, 01:03 AM
Australia
Joined Feb 2013
I'm sending a bunch of Carbon Props your way for testing Soma !
Old Nov 09, 2013, 07:25 AM
Soma is offline
Joined Sep 2012
Cool!
Catchya soon mate.
Old Nov 09, 2013, 09:11 AM
p0st4L is offline
Find More Posts by p0st4L
BUILD.FLY.CRASH.REPEAT.
p0st4L's Avatar
United States, CA, Santa Cruz
Joined Mar 2012
I have an acro w/ the 980's on 4S, they run both 8045 and 1045 w/ ease. (1045 makes it a rocket, and you have to watch for warm motors, but OMG fun)
p0st4L is offline Find More Posts by p0st4L
Old Nov 10, 2013, 04:25 AM
MTB guide is offline
Find More Posts by MTB guide
Portugal, Faro District
Joined May 2013
Amazing work. I have been looking at these motors to replace my SS 2212 980s. I have converted a DJI550 into a Y6. Running the SS 2212 980s on 4s with 1150 gemfan carbon composite props (same as you tested). Completely out of spec for the motors but the lower motor is barely warm to the touch with AP flying. I get 9 minutes flight with 80% of the battery, tarot gimbal, naza v2, DYS opto 40a esc with simonk, GP3, aeroxcraft landing gear, ezosd, immersion 600mw and zippy compact 4s 3700mah. 16.5 minutes with 7400mah battery. Looks like I am getting these motors and the carbon props. Thanks for the thread, looking forward to the 2212 test.
MTB guide is offline Find More Posts by MTB guide
Old Nov 10, 2013, 05:12 AM
Soma is offline
Joined Sep 2012
Thanks for the tip mate! What's your AUW and prop brand on that one?
I'm just gathering a bunch more test props and even more have been graciously donated by Blackout. So I should have a good selection for the 2212 980 test
Old Nov 10, 2013, 10:28 AM
Sputnik is offline
Find More Posts by Sputnik
Portugal, Lisbon
Joined Nov 2013
Great work! This is what I was looking for. I am struggling choosing motors between 800KV and 900KV for my next copter.
Awaiting for V2216 900kv tests
I really would appreciate if you include 10x5 graupner props in the next tests.
Sputnik is offline Find More Posts by Sputnik
Old Nov 10, 2013, 03:02 PM
Soma is offline
Joined Sep 2012
Thanks mate, I'll buy a 900KV as soon as I get a few more funds together for an order. I'm looking forward to the comparison too. It will be a week or two away though unfortunately.
I have been wanting to sell a few body parts on the black market to get some Graupners Most of my builds I try to balance price and performance and the Graupners have been on the high side. It will be good to see them head to head with the cheaper props though so I'll try grab some asap.
Cheers
Sold SunnySky V2216 800kv *new in box* p0st4L Aircraft - Electric - Multirotor (FS/W) 5 Jun 12, 2013 11:53 AM
Sold SunnySky V2216 800kv p0st4L Aircraft - Electric - Multirotor (FS/W) 2 Apr 09, 2013 06:50 PM
Wanted SunnySky V2216 800kv slowjett Aircraft - Electric - Multirotor (FS/W) 0 Apr 01, 2013 12:54 AM
Sold 4x Sunnysky V2216 800Kv---Lowered price KKUSA Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2012 11:01 PM
For Sale SunnySky Motors V2216 800KV - 1pc 40 usd hdworld Aircraft - Electric - Multirotor (FS/W) 2 May 03, 2012 03:21 PM
