DIY Power Meter (Watt Meter)
Some time ago, there used to be a good web site with serveral great projects, one of wich was a Watt Meter. This site is nowhere to be found nowadays. I will attemp to revive that project.
Please note that I am NOT the original autor of this project. I don't remeber the original author's name (a frenchmen), but he deserves credit for at least the original version, using a MAX4372H High-Side current sense amp to monitor current. The project was built around a PIC16F876A, wich is convinient for this application. It has a couple of 10bit AD, enough pins left to drive the LCD and Flash program memory for fast software tweaking Another version that I'm currently working on involves using a Hall Effect current sensor from Allegro (ACS750) - that should make the device Brushless compatible! Fortunately enough I found enough of the original source code left on an old computer to start experimenting. I had to hunt down some missing libraries but it is working now. I don't have a web site, so I will try to post everything I have on this thread. Keep posted! Marc |
Here's the source code.
It has originally been designed using the free version of CC5X: http://www.bknd.com/cc5x/index.shtml The chip originally used is a PIC16F876, I made all my tests using a PIC16F876A, and I suspect that it will work just fine on a PIC16F876B (Not tested) Marc Disclaimer: I'm not the author of this software, an I might have modified it a bit from the original version while experimenting. If you are (or know) the original author, please let me know so that I can give proper credits |
| Thread Tools | |
| Wanted WTB - Watts Up Power Meter / Watt Meter | freedomflyer | Aircraft - Electric - Power Systems (FS/W) | 2 | Jul 08, 2006 11:04 AM |
| Watt meter power and current readings | sdculp | Power Systems | 5 | Oct 08, 2005 01:27 PM |
| FS: "Watts Up" Watt Meter and Power Analyzer | RCFEVER | Aircraft - Electric - Airplanes (FS/W) | 4 | May 12, 2005 06:20 PM |
| Power supply + watt Meter | Littlescreamers | Power Systems | 0 | Dec 04, 2004 09:14 AM |
| WTB: Watt meter & Power supply | nbj6879 | Aircraft - Electric - Airplanes (FS/W) | 2 | May 09, 2003 07:19 PM |
