RJX X-TRON 500 Electric Flybarless 3D Helicopter Kit
High Performance Flybarless Electric Helicopter
Kits are still in
This new kit from Hobby King has all the makings of a fun 3D Heli. It uses all high quality parts including a carbon fiber main frame, and aluminum parts where it counts like the bearing blocks, and head and tail assemblies. It has a CCPM servo setup for precise control and a belt driven tail. The ESC plate is up top and gets airflow from the main blades to keep it cool during hardcore flying abuse. With all the RTF helis out there, it's great to see a kit on the market. If you've never had the pleasure of building a heli from parts, we highly recommend you give it try. It's a great way to learn the mechanics, and will make repairs a lot easier. Check out the RJX X-TRON 500 3D heli at HobbyKing.
Features
Length: 1185mm
Height: 267mm
Width: 210mm
Main Blade Length: 430mm (not included)
Tail Blade Length: 70mm (included)
Main Rotor Diameter: 980mm
Tail Rotor Diameter: 214mm
Motor Drive Gear: 14T/16T
Main Drive Gear: 177T
Autorotation Tail Drive Gear: 155T
Tail Drive Gear: 33T
Drive Gear Ratio: 11.06/12.64:1:4.7
Weight: 1900g~2000g
Price: $242.20
  • Flybarless rotor head
  • Thrust bearings in both main and tail blade grips
  • CCPM direct servo linkage
  • Belt driven tail system
  • Carbon fiber main frame
  • Top mounted ESC platform
  • High torque one-way bearing assembly
  • Carbon fiber 70mm tail blades included
Requires
  • Park size metal gear servo (cyclic control) x 3
  • Park size high-speed servo (tail control)
  • 500 size 1600KV brushless outrunner heli motor
  • 80A brushless ESC w/BEC
  • Flybarless system
  • 420~430mm main blades
  • 6S 2600~3000mAh lipoly battery
  • 6ch or more radio system (transmitter and receiver)
There are no posts
Discussion RJX X-Tron 500 helicopter kit at Hobbyking Atomic Skull Large Electric Helis 226 Jul 29, 2015 10:56 AM
For Sale Brand New RJX 500 Flybarless Head Jim Ryan Aircraft - Electric - Helis (FS/W) 0 Apr 28, 2012 03:04 PM
Sold Brand New RJX 500 Flybarless Head Jim Ryan Aircraft - Electric - Helis (FS/W) 1 Apr 24, 2012 11:02 AM
Sold Brand New RJX 500 Flybarless Head Jim Ryan Aircraft - Fuel - Helis (FS/W) 0 Apr 22, 2012 05:18 PM
Sold NIB RJX FBL (flybarless) head for Trex 500 and similar anatoly Aircraft - Electric - Helis (FS/W) 1 Apr 09, 2011 04:40 AM
