Old Nov 04, 2013, 09:14 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Determine Cg distance - how do you measure so accurately and with what?
Guys,
Tools are everything. I have read plenty of guys reporting Cg locations down to the millimeter or less.
What are you using to be able to determine the Cg so accurately?
Photos and/or links for what you are using to determine location would be appreciated if available but not required.
Are you using a tool or determining it mathematically or what?
thanks
Frank
Fly2High is offline Find More Posts by Fly2High
Old Nov 04, 2013, 09:34 AM
ThomasLee is offline
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Honestly, I just use my finger(nails). I can get it accurate to about 0.5mm, but really, I can't feel any difference in flight with CG differences of less than 1mm (heck, maybe even 1.5mm)!!
ThomasLee is offline Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Nov 04, 2013, 01:47 PM
BavarianCharles is online now
Find More Posts by BavarianCharles
Follow me to sink!
BavarianCharles's Avatar
85045
Joined Oct 2005
Works really well ...
http://www.mountainmodels.com/produc...799b765ea89712
BavarianCharles is online now Find More Posts by BavarianCharles
Old Nov 04, 2013, 01:57 PM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Multiplex CG Machine - if you can find one
GoFaster is offline Find More Posts by GoFaster
Old Nov 04, 2013, 02:10 PM
jcats is online now
Find More Posts by jcats
Launch high. Fly low.
United States, CA, Lake Elsinore
Joined Aug 2003
Same here...
I just put a couple of peices of tape (Approx 5mm wide) on each wing where I want the CG range. And I just CG it with my fingers. For my Stobels, I usually range them at 70 to 75 mm. I like to fly a little nose heavy so I just CG the plane in front of the tapes...
Yeah, more power to yah if you can feel/see what 1mm makes.
jcats is online now Find More Posts by jcats
Old Nov 04, 2013, 02:51 PM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
Multiplex CG machine:
http://www.sussex-model-centre.co.uk...xd.asp?id=5319
http://www.wheelspinmodels.co.uk/i/194340/
http://www.rc-toy.de/lshop,showdetai...693054,5,,.htm
Or a less costly wooden version:
http://www.rcgroups.com/forums/showt...3#post26539240
Or the cheapest, possibly most accurate version requires string, some bits of wood, and a bubble line level:
http://iflyrc.hypermart.net/CG1.htm
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Nov 04, 2013, 03:01 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Originally Posted by BavarianCharles View Post
^ I second this one. It's a great little tool.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Nov 04, 2013, 03:09 PM
simonmunro is offline
Find More Posts by simonmunro
Joined Jan 2013
A large pair of scissors. They come with handles and everything.
simonmunro is offline Find More Posts by simonmunro
Old Nov 04, 2013, 03:37 PM
G_T is online now
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
Upside down on the wing upper surface. Anything pointed.
Gerald
G_T is online now Find More Posts by G_T
Old Nov 04, 2013, 04:12 PM
pbm77 is offline
Find More Posts by pbm77
Peter Madsen
pbm77's Avatar
Denmark
Joined Dec 2009
I also use my fingers. But only measures cg before the maiden.
Am I the only one that don't know the precise cg of my planes? I set it accordingly to the manual the first time and then adjust it from there, but must admit that I don't measure it after I have found the spot I like.
pbm77 is offline Find More Posts by pbm77
Old Nov 04, 2013, 05:32 PM
JimZinVT is offline
Find More Posts by JimZinVT
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
2 pencils stuck in a block of styrofoam.
Like pbm77, I don't know what my final CG is. I mark a line at the theoretical CG, balance it, then adjust from there to my liking, but never go back and measure where it ends up. It usually ends up slightly further aft than what SailplaneCalc predicts.
JimZinVT is offline Find More Posts by JimZinVT
Old Nov 04, 2013, 05:36 PM
G_T is online now
G_T
G_T
Joined Apr 2009
I just TLAR, take it out, and fly it. I adjust for conditions anyway. I don't care what it measures but how it flies.
When I get to fly that is...
Gerald
Old Nov 04, 2013, 05:45 PM
JimZinVT is offline
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
Gerald: why upside down?
Old Nov 04, 2013, 06:11 PM
G_T is online now
G_T
G_T
Joined Apr 2009
Unless it is a low wing, it will sort of balance on one point that way, rather than having to have one on each wing.
Gerald
Old Nov 04, 2013, 06:36 PM
LSF226 is offline
Find More Posts by LSF226
United States, WA, Shoreline
Joined May 2004
Great Planes CG Machine
The attached picture shows my Great Planes CG Machine. The URL with a better picture, write-up and a review is:
http://www.greatplanes.com/accys/gpmr2400.html
The plastic rulers are graduated in both inches and millimeters. I'm much better on setting the C of G with this gadget than I ever was without it. The accurate measurement lets you keep track of changes.
Richard S
LSF226 is offline Find More Posts by LSF226
Discussion How do you determine what engine will fit in a plane? cloud_9 Engines 15 Jun 06, 2013 08:06 AM
Question How determine how much torque do you need Great_Goose Beginner Training Area (Aircraft-Electric) 2 Mar 24, 2013 07:08 AM
Discussion How do determine direction of rotation clive_fox Electric Motor Design and Construction 10 Feb 12, 2013 05:13 PM
Discussion CG? How do I determine the CG on my Y6? df60532 Multirotor Talk 12 Sep 02, 2011 08:54 AM
Discussion How do I measure side thrust accurately? dwalk Competition Aerobatics 11 Sep 24, 2010 09:10 PM
