Old Nov 03, 2013, 07:23 PM
Go4it is offline
Find More Posts by Go4it
Go4it's Avatar
United States, FL
Joined Mar 2004
Question
LIPO discharger needed
I am of need of a lipoly discharger with auto cut-off at 3.8v per cell--'commercially' available
For 6S LIPO 5300mah
Go4it is offline Find More Posts by Go4it
Old Nov 03, 2013, 07:36 PM
crashdaily is offline
Find More Posts by crashdaily
crashdaily's Avatar
Down Under
Joined Mar 2008
Imax B6 - the discharge current 0.5A.
crashdaily is offline Find More Posts by crashdaily
Old Nov 03, 2013, 10:36 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Most smart chargers have a storage function. Consult the manual.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Nov 04, 2013, 05:30 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Commercially ? Not many and likely not budget priced !
Search forums like this and Wattflyer and you find threads of constructing dischargers like my Light-Bulb version.
To create an auto-cut-off DIY discharger is not impossible and odd threads have done them ... but in the end KISS rules and a simple stopwatch .. or even clockwork timer is useful !
I have looked at using the clockwork relay that is in my old NiCD car chargers ... it connects system and then cuts when it hits zero. The spring winds up for a max duration of 30mins.
Nigel
solentlife is offline Find More Posts by solentlife
Old Nov 04, 2013, 06:09 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
A Cellpro Powerlab charger or WMR CBA would be your best options. You didn't specify how much discharge power you need.
http://fmadirect.com/
http://www.westmountainradio.com/cba.php
Ohmic is offline Find More Posts by Ohmic
Old Nov 04, 2013, 08:14 AM
Go4it is offline
Go4it's Avatar
United States, FL
Joined Mar 2004
Thanks'
But, I need something in the range of 10 to 30 amps range for discharge so it would not take all day.
Old Nov 04, 2013, 08:50 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Really your only option then is a West Mountain Radio CBA. Hopefully you have a fat wallet.
While a PowerLab 6 or 8 can do a 30 amp discharge it will be regenerative so you will have to put all that energy back into a very large deep cycle battery. I'm guessing that won't fit your needs.
grimbeaver is offline Find More Posts by grimbeaver
Old Nov 04, 2013, 09:17 AM
Ohmic is offline
USA
Joined Jan 2002
Originally Posted by Go4it View Post
Thanks'
What's your budget?
Old Nov 04, 2013, 10:18 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
For 6S LIPO 5300mah
Do you usually end up with discharged packs and some fully charged packs? If so, a simple parallel connector and resistor between discharged and fully charged packs works nicely. Not commercial but very simple.
See this thread.
hoppy is offline Find More Posts by hoppy
Old Nov 04, 2013, 10:43 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Or another simple (but semi commercial) method is to use 2, 100W 12V RV bulbs in series with a 15 min timer like this..
If my figures are correct that will discharge a 6S 6000mah pack in 18 min or one turn of the timer dial.
6000mah/2 = 3000mah to get rid of.
2, 120W bulbs in series at 24V = about a 10A draw.
3000mah/10000ma = 18 min.
So a 5300mah pack should be about 1 turn on the timer.
Somebody check those numbers...
Old Nov 04, 2013, 10:46 AM
Go4it is offline
Go4it's Avatar
United States, FL
Joined Mar 2004
I have a CBA but it is made for smaller lipo's in fact if anyone wants it I'll list it for sale?
Old Nov 04, 2013, 10:53 AM
Go4it is offline
Go4it's Avatar
United States, FL
Joined Mar 2004
Looks good
I have been using a EDF test stand and running the EDF for a few minutes with a cell logger attacked and then disconnect at 3.8 or 3.7v. The reason I ask I am getting tried of the noise of the fan. But it is fast at 85amps discharge . I don;t like lipo's to set at full charge for more then a few days.
Old Nov 04, 2013, 10:59 AM
Ohmic is offline
USA
Joined Jan 2002
You much have some very large LiPos then if the 2,000W version is too small for you.
http://www.westmountainradio.com/pro...d=sys2000_watt
Old Nov 04, 2013, 11:09 AM
solentlife's Avatar
Joined Jan 2010
Looks good
It is true that leaving LiPo standing at more than storage is bad for them ... but also repeated 85A discharges when not necessary are not so good either !!
Do you not consider it would be a nice holiday for your LiPo's to be discharged at a less stressful rate ?
The timer ... I never thought to use a Domestic Wall timer .... One like that fitted into my system would be excellent !! Thanks Hoppy
Ebay here I come .... !!
Nigel
Old Nov 04, 2013, 01:09 PM
Ohmic is offline
USA
Joined Jan 2002
Those timers are designed to switch AC, not DC.
Sold Thunder AC6 Smart LiPo Balance Charger/Discharger w/ AC Adapter for 1-6 Lipo/ 1-15 Ni FieldofDreamsFlyer Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 09, 2013 04:34 PM
Discussion I need help to discharge my lipo!! Prince_Al Batteries and Chargers 15 Apr 09, 2013 09:21 PM
Question Disposing or discharging a puffed lipo finguz Batteries and Chargers 3 Jan 20, 2013 09:39 PM
Discussion Discharging Lipo advice Jmm_jammy Multirotor Electronics 9 Jan 18, 2013 06:32 AM
Discussion Lipo battery discharge rating(S) ham4864 Multirotor Electronics 3 Jan 12, 2013 07:33 PM
