Old Feb 23, 2004, 06:37 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Lipo Charger that will charge multiple packs?
Just what the title says..
Is there a GOOD, RELIABLE charger on the market that will similtaneously (sp) charge more than 1 pack??
Jeff
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Feb 23, 2004, 08:38 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
TTT..
Old Feb 23, 2004, 09:03 PM
buzzsaw 46 is offline
Find More Posts by buzzsaw 46
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
The only one I know of is the Hobbico feild charger MkII(not sure the exact name thats, close though ) I have one of the first SC-2's from Troy@B-P-P and have had a second on order for about 13 months now Last I heard was he was trying for a first of the year release thats come and gone and I'm starting to wonder if its worth waithing for or just buy a second Astro 109!!
buzzsaw 46 is offline Find More Posts by buzzsaw 46
Old Feb 23, 2004, 09:06 PM
FDC is offline
FDC
Find More Posts by FDC
FDC
Joined Jan 2004
Re: Lipo Charger that will charge multiple packs?
Check out this charger, might be what you're looking for...
Miniron website in German and this english translated version translated by babelfish.
FDC is offline Find More Posts by FDC
Old Feb 23, 2004, 10:28 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Yeh, I am seriously looking at the 109... I wish it would charge two packs though...
Old Feb 24, 2004, 12:40 AM
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Just get two of them Tram
Old Feb 24, 2004, 12:47 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Hehehe..
Old Feb 24, 2004, 02:36 AM
goldguy is online now
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Apparently the Apache charger will be available in a twin port version, but when is the magic question............check the Feb. issue of Fly RC, page 75 and there it is, for all to covet. I think it's called sales by anticipation!!!
goldguy is online now Find More Posts by goldguy
Old Feb 24, 2004, 04:23 AM
Greebe is offline
Find More Posts by Greebe
radar jammer
Greebe's Avatar
Bradenton, Florida
Joined May 2003
Tram what packs would you like to charge simutaneously with the 109?
As long as they are of the same capacity and cell count (albiet balanced and in similar good condition) it can (read: 2/ 3s packs used in a 3S2P config discharged together). Just use a parallel Y cable to hook up...
The packs I've made have taps so I can balance cell by cell. This comes in handy only if there is questionable performance related issues where none existed before.
If they are not of the same discharged cpacity then it would be best to charge seperately... but if close simply adding a high wattage 0.1 ohm resistor to each pack Y leg will help balance the current load between packs. Also need to monitor each packs voltage (eg using 1 DMM per pack or similar).
or
This is where Suzanne's cell balancers would really come in handy.
Warning: You must babysit them (watch them like a hawk) at all times when doing this.
Greebe is offline Find More Posts by Greebe
Old Feb 24, 2004, 11:46 AM
Norman Adlam is offline
Find More Posts by Norman Adlam
Official Old Git!
Hampshire, UK
Joined Sep 2000
Hi,
Schulze 6-330d could charge 2 Li-po packs, although one would be limited to 330ma charge rate (and 3 cells - I think)
Cheers,
Norman Adlam is offline Find More Posts by Norman Adlam
Old Apr 05, 2005, 03:06 AM
Alex Titoff is offline
Find More Posts by Alex Titoff
Unregistered User
Alex Titoff's Avatar
Limassol, Cyprus
Joined Oct 2003
or
I have 3 packs for my foamy planes. They are the same capacity 1500mAh, countcell 3S, brand, and date of manufacture. But they are used in a different power setup, so they are at the different charge condition at the end of the fight.
Can I discharge one by one pack with AstroFlight 109 charger disconnecting them at the point when charger reports they are discharged. By such procedure I should rech each pack to be at barrely the same condition. Then let them rest for 10 minutes. Then using parallel Y cable to connect them to make 3S3P and charge them with 4.5A.
Can I do this? Is it safe? Will I damage the packs?
Alex Titoff is offline Find More Posts by Alex Titoff
Old Apr 05, 2005, 06:38 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
Alex et al,
You can safely charge packs with the same S count (Same number of cells in series, no matter how many in parallel), and they do not have to be the same brand or capacity. Moreover, they do not have to be very close in voltage when you connect them together, particularly if all the packs are near depletion (not much energy left in them):
http://www.rcgroups.com/forums/showthread.php?t=170524
The current into each pack should be checked and the total charger output current set so that none of the packs is charging @ greater than 1C.
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Apr 05, 2005, 06:52 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Available soon. ? Four Banger.
Charles
Old Apr 05, 2005, 09:05 AM
Unregistered User
Limassol, Cyprus
Joined Oct 2003
RD
Just to clear out. Do I need to discharge them before charging, or just connect them in parallel and charge at 1.5A?
My packs http://www2.towerhobbies.com/cgi-bin...?&I=LXGHE6&P=0 have SafeCharge circuitry. Should I use them in this kind of charging?
Old Apr 05, 2005, 09:14 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
No NO! NO!!!!! Never ever, ever discharge a pack that is not fully charged! It is not wise to do that with any battery type.
You always give a pack a full charge, then discharge. I would highly recommend charging one pack at a time at first. I usually charge my packs at about .8c so a 1500 mAh pack I would charge at 1.2-1.3amps.
I do parallel charge one of my packs. In fact I have wired two packs together. But that pack has taps and I regularly monitor each of the cells individually. So far, they are all with .01v of each other (after 50 cycles or so).
Anyway - charge all packs (of all battery types) first. Then you can discharge.
Discussion Whats the best lipo charger to charge multiple packs? marcwv Batteries and Chargers 13 Aug 29, 2007 02:31 AM
I need a cheap Lipo charger that will not explode my cells. roundthebend Micro Helis 9 Oct 03, 2005 05:34 PM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
Charger that will charge 2 NiMh's or 2 Lipo's at the same time? Tram Batteries and Chargers 3 Oct 12, 2004 07:28 PM
Least expensive Li-Po charger that will charge a 3s1p Etec? The Blue Max Batteries and Chargers 18 Oct 02, 2003 09:33 PM
