Old Nov 02, 2013, 07:04 PM
Bmx2996 is offline
Find More Posts by Bmx2996
United States, SC, Goose Creek
Joined Jun 2013
$26 Turnigy Accucel 6 charger review
So I just got this the other day and I have to say I'm impressed. especially for the price. One thing that is a bummer is that you will need an adapter for a wall plug. It has clips that can clip on a battery. I usually just bring along my extra car battery or I can simply just hook it up to the charging quarters at the local club. It has a nice bright screen that makes reading easier. There are quite a few options to choose from. I only charge my lipos on this ad it's great. Small, easy, and dummy proof. For the price it is definitely worth it.
Here is the link:
http://www.hobbyking.com/hobbyking/s...66&aff=1195875
Bmx2996 is offline Find More Posts by Bmx2996
Old Nov 02, 2013, 07:13 PM
stamp80 is offline
Find More Posts by stamp80
stamp80's Avatar
United States, NC, Sherrills Ford
Joined Aug 2013
I have had one for several months now. Love it works great. I bought a a/c power supply off amazon that works great! Was only like $12 shipped
Power supply link.. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Gotta use the 15v on the power supply. Hope this helps you.
stamp80 is offline Find More Posts by stamp80
Old Nov 02, 2013, 07:24 PM
Bmx2996 is offline
Joined Jun 2013
I'll definitely check that power option. I was looking around and I think you might have caught my eye on that one from amazon. Thanks!!!
Old Nov 02, 2013, 08:19 PM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
I have a clone of that charger and power supply to charge at home... it's been running strong for about 4 years, great simple, cheap charger to start.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Nov 02, 2013, 08:39 PM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Good charger, I still have mine, but unless you want to stick with about 3S 2200, IMO 50W is a little limiting. I think better value overall is the Eco6-10 - http://www.hobbyking.com/hobbyking/s...er_w_acc_.html
I run multiple 500W chargers at home, but the 6-10 is my faithful field charger
scirocco is offline Find More Posts by scirocco
Old Nov 05, 2013, 08:09 PM
Bmx2996 is offline
Joined Jun 2013
Does anyone have a scanned manual for this guy? I would like to look it over as I can't find mine.
Thanks!
Happy flying
Old Nov 06, 2013, 02:46 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
The Accucel is a clone itself !!
Nigel
solentlife is online now Find More Posts by solentlife
Old Nov 06, 2013, 02:54 AM
solentlife's Avatar
Joined Jan 2010
The power supply must be capable of delivering more than 60W ...
Most people buy a 12V x 5A mains adaptor .... this is fine but will be working at or near it's limit most time - making adaptor run warm / hot and shortening it's life ... so I advise go higher ... I use a 12V x 10A mains adaptor on my B6 - which is basically same charger ...
I know you can get a higher rated charger for larger packs ... but I do 5S 3000 packs with mine and OK - I accept that it takes a while - but I know I am not pushing limits when charging ...
Many LiPo online sites recc'd 1C rate anyway ... despite people saying go for 2C .. 3C etc.
Here's 4max Uk for example with their high power high C rated packs capable of 5C charge :
http://www.4-max.co.uk/lipos.htm
Nigel
Old Nov 06, 2013, 03:46 AM
scirocco is offline
scirocco's Avatar
Joined Feb 2001
a decent power supply was probably my biggest and best investment. 30A @ 28V lets me charge 3 6S 5000 at 2C. if you're going to use 5 or 6s packs, a higher voltage charger and power supply is a good move
Old Nov 06, 2013, 04:26 AM
solentlife's Avatar
Joined Jan 2010
Agreed ... but a 30A @ 28v adaptor is no use to a person with a '6 charger ... a) its only rated to 18V and only requires 50W for a B6 or 60W for an Accucel 6 at 5A / 6A respectively.
Now a 30A @ 12V ... to max 18V makes sense ...
Nigel
Old Nov 06, 2013, 05:41 AM
scirocco is offline
scirocco's Avatar
Joined Feb 2001
Nigel
Quite true Nigel I drifted off topic there with the charging larger packs bit, but definitely worth considering a power supply capable of the max input voltage of whatever charger you have if you plan to charge 4S or higher.
Old Nov 06, 2013, 06:23 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I used the Acc 6 for many yrs but when I went to the bigger batts I went to the Eco 6-10 as mentioned in post 6. It's pretty much the same charger with the same charging format, just higher amp/batt capability. Both great economical chargers.
Gord
flypaper 2 is online now Find More Posts by flypaper 2
Old Nov 06, 2013, 07:39 PM
Grantham Kid is online now
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
Never had a problem with mine but have only charged up to 4S 4000. I like it.
Grantham Kid is online now Find More Posts by Grantham Kid
Latest blog entry: A bit about me
Old Nov 07, 2013, 12:03 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
I envy your patience. With batteries of that size you could save a lot of time with a faster charger. The 50W limit means you will be charging at about 3 Amps, so you would take 80 minutes to fully charge that battery. If the battery will do 3c charging (many do these days) then a more powerful charger would fully charge it in 20 minutes.
More to the point if you have a few batteries a powerful charger can parallel charge them all in 20 minutes, whereas the 50W charger could quite literally take all day.
Unless you only fly small models IMHO life's too short to use a 50W charger.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Nov 07, 2013, 12:55 AM
solentlife's Avatar
Joined Jan 2010
I suppose because of the work I do and have done - I hate putting all eggs I one basket ... so I have 2 B6's ... yes two 50W chargers .... At less than $30 a pop - I'm happy to have redundancy and also having the two means I am not hanging around so much for batterys. I run from 3S 800 up to 5S 3000 .... and so far not been put out by lack of high rate charging.
If I do need more packs when flying ... I can charge up another of usual packs in the time I have 2 flights and a chat with the guys ... but seldom needed as I have plenty of packs in sizes I use.
The biggest hurdle I had was not charging ... but discharging after session if I didn't use packs.
That's solved as you know.
Nigel
Sold turnigy accucell 6 lipo charger trucker41 Aircraft - Electric - Batteries & Chargers (FS/W) 4 Feb 03, 2013 11:17 AM
Sold Like New Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories MJB9 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Jan 29, 2013 08:58 AM
Discussion No Power for Turnigy Accucel 6 Charger Skylex Batteries and Chargers 4 Jan 18, 2013 01:11 PM
Sold Turnigy Accucel-6 50W 6A Balancer/Charger - $24 shipped nuttcaze Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 09, 2013 12:35 PM
Sold Turnigy Accucel-6 50W 6A Balancer/Charger Mikey 68 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 07, 2013 05:03 AM
