Old Feb 23, 2004, 04:06 PM
hotjava is offline
Find More Posts by hotjava
Hotjava
Norcal
Joined Aug 2002
Making Decals and Where to Buy Fablon?
Hi,
I'm finishing up a Dare SE5a covered with Litespan, and would like to hear suggestions on making decals using a color inkjet printer.
I've tried to print to frosted scotch tape but that never dries. Peter Rake mentioned that there is a material called "fablon." They simply print the decal onto that material, cut it out and then stick it to the Litespan.
It's used primarily in the UK and since I live in the US... well, you get the picture.
Does anybody know where "fablon" can be purchased in the US?
Thanks for the help!
Oliver
hotjava is offline Find More Posts by hotjava
Old Feb 23, 2004, 05:37 PM
Ian Easton is offline
Find More Posts by Ian Easton
Ian Easton's Avatar
United Kingdom, Scotland, Fife
Joined May 1999
Fablon in the US is Con-tact drawer and shelf lining that you can buy in the grocery store. It does not do well in an inkjet printer. The ink just never dries. If you paint your insignia onto it, it works well.
Ian Easton is offline Find More Posts by Ian Easton
Gerry Markgraf is offline
Find More Posts by Gerry Markgraf
Gerry Markgraf's Avatar
S. Calif
Joined Mar 2000
Oliver
Here's something that I tried and am quite happy with, so I'll pass it along. The insignia on my Bengston Bristol Scout was created using the files on Kurt's website. I printed them on a material I purchased from my local electronic supply store (Frey's) called Adhesive Poly Silk. It looks like the thin silky material that they use to cover mouse pads. Its on an adhesive back, prints well in the ink jet printer, sticks well to litespan and even holds up well to a bit of heat shrinking (I used the heat gun to make it conform to compound curves without wrinkles). It looks really good on a simulated fabric surface (litespan) and is nicely transparent when viewed through the Litespan from below. Only downside is that the inkjet inks are not waterproof, so use a clear coat over the final product.
Good Luck
Gerry
Gerry Markgraf is offline Find More Posts by Gerry Markgraf
Old Feb 23, 2004, 05:43 PM
S. Calif
Joined Mar 2000
Here's a closeup of the package. It's part of the creative series from Inkworks. It cost me $11.99 for 10 sheets from Frey's. Just print your art work on the sheet, cut it out, peel off the backing and stick it in place. I was able to remove poorly positioned pieces without too much trouble and as I said, it even shrinks a little with a heat gun.
Gerry
Old Feb 23, 2004, 09:27 PM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Gerry, that looks pretty good. I'm going to look for some.
Oliver,
You can go to an office supply store and get FasTrack paper, it's a sticky back, prints well, sticks well. I think it's probably the equivalent of Fablon here. A little thick but works better than nothing.
J
J Morgan is offline Find More Posts by J Morgan
Old Feb 24, 2004, 01:08 AM
hotjava is offline
Hotjava
Norcal
Joined Aug 2002
Thanks!
Everybody,
Thanks for the replies.
Ian, I did try the shelf lining and it never dried. The ink just sits on top of the material. Glad to know that's "Flabon."
Gerry, I also bought Aerodromerc's Bristol Scout! She is in my opinion the most elegant WW I biplane that ever existed. When I saw the Rake/Bengston design, I fell in love with it. I'll definitely try Inkworks!
J Morgan, I'll take a look at FasTrack paper as well.
Again, many thanks!
Oliver
Old Feb 24, 2004, 07:59 AM
Doc Data is offline
Find More Posts by Doc Data
United States, FL, Starke
Joined Apr 2002
http://www.amazon.com/exec/obidos/AS...051458-8009638
http://www.outpost.com/product/3353472
Doc Data is offline Find More Posts by Doc Data
Old Feb 24, 2004, 12:13 PM
4 Scale is online now
Find More Posts by 4 Scale
Trampling out the vintage
Joined Feb 2002
My issue with inkjet decals is they tend to run when wet.
Lately I have been cutting out Topflite Trim film and am happiest with that.
4 Scale is online now Find More Posts by 4 Scale
Old Feb 24, 2004, 10:19 PM
S. Calif
Joined Mar 2000
Greg
I agree with you about inkjet prints and water. The first time I took the Scout out, it was a dewy day and I got some marks on the lower insignia from brushing against wet grass. Still, I like the dull fabric appearence of the Poly Silk on WW I airplanes. Plus I like the way it looks when looking up at the airplane - the insignia is semi transparent instead of blocking all the light the way other materials do. And there's nothing like printing a complicated marking using your computer and just cutting it out with scissors or a knife. Guess my next option is to try some of the clear sealants they sell in art stores. Also, I have a new Epson printer with (supposedly) waterproof inks. I'll see how that works on the next airplane.
Gerry
Old Feb 24, 2004, 11:07 PM
AerodromeRC is offline
Find More Posts by AerodromeRC
Designing on the edge
AerodromeRC's Avatar
United States, OR, Portland
Joined Mar 2001
I use Krylon clear spray to "fix" my decals. No running when wet. Use three coats.
Kurt
AerodromeRC is offline Find More Posts by AerodromeRC
Old Feb 24, 2004, 11:16 PM
War Bird Radio is offline
Find More Posts by War Bird Radio
"Superior Air Power"
War Bird Radio's Avatar
Stayton, Oregon, USA
Joined May 2003
So inkjet inks don't run if clear coat is applied but they will fade under UV exposure.
John
War Bird Radio is offline Find More Posts by War Bird Radio
Old Feb 25, 2004, 08:57 AM
Joined Mar 2001
John,
The clear coat also protects from fading. Most of the Ink fading is due to oxidation from the air and sealing dramatically slows this process.
I have had no decernable fading in over a year.
Kurt
Old Feb 25, 2004, 01:57 PM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
I make waterslide decals using my inkjet printer with decal paper from McGonigal Paper & Graphics. As part of the decal making process you spray several coats of clear over them before even cutting them out. They apply to the model just like typical water slide decals. You wet them and then slide them into position. Then rub them down gently to wipe off the excess water. They're so thin that when they dry they're almost like paint.
http://www.rcgroups.com/forums/showt...221#post836221
http://www.mcgpaper.com/decals.html
Gerald is offline Find More Posts by Gerald
Old Feb 25, 2004, 09:07 PM
Joined May 2003
Kurt,
That's good to hear. I've seen too many of my inkjet plans fade if left in sun light. Been holding off doing decals on the 'ol HP till somthing better came along. Looks like I don't have to wait or worry.
John
Old Feb 25, 2004, 11:12 PM
rottenron is offline
Find More Posts by rottenron
Wakeman oh.
Joined Oct 2003
I have good luck with Avery inkjet white full sheet lables guaranteed smudge free #8165 and clear full sheet lables #8665 but you cant print anything white it will come out clear
rottenron is offline Find More Posts by rottenron
Where to buy control rods/tubes ? Feodosia Flyer Electric Plane Talk 4 Oct 02, 2007 10:54 AM
Where to buy paint masks/templates and decals? JWC Scale Kit/Scratch Built 14 Aug 26, 2002 12:28 PM
Decalcote for water slide decals, where to buy? Red Baron 47 Electric Plane Talk 9 Oct 31, 2001 09:49 AM
Where to buy Matched Cells in the UK grant_smith Electric Plane Talk 1 Jun 10, 2001 01:03 AM
Where to buy Kruse Introgear 300 pico with VISA hc_lin Electric Plane Talk 0 Apr 25, 2001 10:14 PM
