The RC Truck FPV Project - Phase 1
Have you ever driven an RC truck using first person video? FPV from the driver's seat of a 1/10 scale truck is pretty amazing! Check out phase one of my FPV truck series.
The video really shows you what an FPV truck is all about. Be sure to watch it!
The RC Truck FPV (First Person Video) Project - Phase 1 (7 min 46 sec)
Axial Wraith FPV
Axial Wraith FPV
RC Truck The Axial Wraith
Camera RC Logger Pro
Transmitter RC Logger
LCD Screen RC Logger
TX Antenna IBCrazy BlueBeam
Aluminum Roof AdvancedMetalFab
FPV from an RC truck is a ton of fun and relatively simple to do. This is phase one of my multi part series about turning your RC ground vehicle into a first person video vehicle.
While I'm new to FPV, I'm not new to RC ground vehicles. After putting together an FPV plane I happened to see a video from the driver's seat of an RC truck. I had to try it! The Axial Wraith was a natural choice because of all the aftermarket parts available for it. The RC Logger Pro camera is easy to fit into just about anything and is a rugged unit for FPV applications.
I have some ideas on how to customize this FPV rig even more but before we do that lets get into phase one of the FPV truck build.
The Truck - The Axial Wraith
You can put FPV components in anything as long as you have room and can carry the weight. I choose the Axial Wraith because this is a truck that everyone loves and there are a lot of aftermarket parts for it. In particular there are FPV parts available for it. Axial sent me the RTR Wraith. The only thing I needed was batteries for the truck and a TX. It is truly a plug-and-play vehicle.
The "WOW" factor is pretty high on this rig. The graphics are killer, the stance is tough and the LED lights put the cherry on top of the cake.
A Custom Roof
One thing that I didn't like about the Wraith for FPV was that while the roll cage was great looking and did a great job protecting the truck it also blocked out a lot of the view from the camera. After some late night searching I found an easy solution from the guys at AdvancedMetalFab. They make an aluminum roof that not only gave me more height, it also eliminated the center/front section of the roll bar. This is made with a GoPro mount and I will utilize that in a future article on this truck.
The FPV System
For Phase 1 of this series I wanted an FPV system that was easy to use, inexpensive and light. Luckily for me I already had a setup that fit the bill from RC Logger.
Video - The RC Logger Pro camera can go just about anywhere.
Transmitter - The small RC Logger 5.8 transmitter also was easy to fit anywhere.
Power - I opted to use a secondary lipo to power my video transmitter. I ran it through a BEC to keep the voltages at a safe level
Antenna - IBCrazy is not only an active RC Groups member but a creator of killer RC equipment. I used his BlueBeam clover leaf antenna on my transmitter. NOTE - I really don't like the fact that the antenna is exposed because roll-overs are going to happen. I am looking for better placement for this antenna in phase 2 of this build.
Getting Custom - The Rear Deck Lid
In phase 2 we will utilize some after market parts for our FPV rig but the focus in this article is putting together an FPV truck fast and for low bucks. I needed someplace to mount my camera and transmitter. I needed a rear deck lid that everything could live on and stay secure. I cut out a cardboard piece as a rear deck to make sure it would work. Then I used some hobby grade laminate wood and cut it to shape. I then covered the top in velcro and to make it look good I used a giant black sharpie to make all the exposed wood black. I used zip ties on the front and velcro on the back so it can be popped open for access to the battery compartment.
Tricking Out the Truck TX - Adding a Screen!
So if you are transmitting a video signal from your uber cool RC truck you have to have something to receive it right? For this phase one build I wanted something that was inexpensive but effective. I also wanted something that would mount on the Wraith transmitter.
RC Logger 3.5" Screen - This little screen from RC Logger comes with it's own receiver and is small enough to secure to an RC vehicle's TX. I'll admit I forgot to be careful with the TX a few times and the screen stayed on without an issue. The screen is big enough to enjoy and small enough to not be a hassle...and it looks pretty cool too!
There you have it! A super simple and affordable way to get an FPV system on your truck! Watch my video to check out how it looks and drives. I have enjoyed rock crawling and off-roading with this rig and the Wraith has been rock solid! I'm exited to get going on phase2.
Old Nov 11, 2013, 02:49 PM
Paul Onorato is offline
Find More Posts by Paul Onorato
Paul Onorato's Avatar
United States, CT, Brookfield
Joined Jun 2013
Such a sweet ride! Now I want to make one.
Paul Onorato is offline Find More Posts by Paul Onorato
Old Nov 11, 2013, 03:17 PM
RJOS is offline
Find More Posts by RJOS
United States, CO, Colorado Springs
Joined May 2013
It would be cool if you could devise a servo arm to right the truck if it tips over. Would be nifty.
RJOS is offline Find More Posts by RJOS
Old Nov 11, 2013, 11:06 PM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
5.8ghz has awful penetration through any objects. If your goal is to go farther than 1000 feet, you might want to give 1.28ghz a try or get a directional antenna for 5.8ghz
Koo is offline Find More Posts by Koo
Old Nov 11, 2013, 11:59 PM
Jim T. Graham is online now
Find More Posts by Jim T. Graham
Administrator
Jim T. Graham's Avatar
United States, TN, Nashville
Joined Mar 2002
Phase 2 of this project involves a directional antenna from Mr. IBCrazy.
Jim T. Graham is online now Find More Posts by Jim T. Graham
Administrator
Old Nov 12, 2013, 12:16 AM
AcroFPV
A moderator felt this post violated the following rule: Offensive content (Flatulence). It is temporarily hidden while AcroFPV edits it.
Old Nov 12, 2013, 07:32 AM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
In th elast pic you can see the antenna leaning against an aluminum plate, very bad
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Nov 12, 2013, 07:52 AM
Administrator
Joined Mar 2002
Edit
Administrator
Old Nov 12, 2013, 07:53 AM
Administrator
Joined Mar 2002
Hugo
Thanks for the post. I am looking for better ways to mount the antenna. I appreciate the input.
Administrator
Old Nov 12, 2013, 09:14 AM
Koo is offline
Koo
Koo
Koo's Avatar
Joined Mar 2012
Even as she sits now, she is one heck of a truck. Whenever I see projects like this I'm amazed by the creativity and dedication it takes to get past even the small obstacles
Old Nov 12, 2013, 09:19 AM
Administrator
Joined Mar 2002
I stayed up late last night and moved the battery to the nose of the truck and the ESC and RX to the rear of the truck. I have added all aluminum panels and have the ReadyMadeRC GoPro mount ready to go in. More to come!
Administrator
Old Nov 12, 2013, 12:44 PM
verticalspark is offline
Find More Posts by verticalspark
Aut Viam Inveniam Aut Faciam
verticalspark's Avatar
Joined Oct 2008
Thats pretty cool Jim. I know RCSparks did a FPV summit a while back that was pretty awesome as well.
verticalspark is offline Find More Posts by verticalspark
Old Nov 12, 2013, 01:46 PM
fruitpastile is offline
Find More Posts by fruitpastile
Joined Sep 2012
Get a Tonka! lol
fruitpastile is offline Find More Posts by fruitpastile
Old Nov 17, 2013, 01:35 PM
modelerchina is online now
Find More Posts by modelerchina
Canada, ON, Mississauga
Joined Apr 2006
That's owesome built. I did one on tamiya stampede 100 dollar stuff. It was easy and still a lot fun, the key part is to try to build a realistic cockpit or driver view, where crawler seems an enabler
modelerchina is online now Find More Posts by modelerchina
Old Nov 17, 2013, 01:40 PM
Joined Apr 2006
True. Guess a 0.9 G groundplane can do the trick for ground pounder, buy extra feedline and hang tx up higher, but it will make truck easy to tangle with tall grss etc. And you need much higher ground station antenna too
For Sale rc truck rc buggy 1/5, 1/6, 1/8 Wheels and Tires Sets NEW NEW ksuyeda Cars - Trucks and Parts (FS/W) 0 Sep 07, 2013 10:01 AM
Sold rc truck rc buggy 1/5, 1/6, 1/8 Wheels and Tires Sets NEW NEW ksuyeda Cars - Trucks and Parts (FS/W) 0 Aug 21, 2013 12:23 PM
Discussion my full scale 1:1 rc car project 2013 vintageroad Automobiles 1 Apr 06, 2013 07:08 PM
Looking to trade for a rtr rc boat or a 1/8 scale rc truck. Open to offers Hor2012 Non R/C Items (FS/W) 0 Mar 09, 2013 09:37 PM
Sold Iron Track 1/10 scale FPV Truck airbagit13 FPV Equipment (FS/W) 5 Jan 24, 2013 11:49 PM
