Old Oct 29, 2013, 03:16 PM
Sratch Builder is offline
Find More Posts by Sratch Builder
Joined Oct 2013
reduction gears
Anybody know a good place where I can order/buy reduction gears for electric RC boats?
Sratch Builder is offline Find More Posts by Sratch Builder
Old Oct 29, 2013, 03:21 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
First, ask yourself if reduction is really needed... in many cases, there are both brushed and brushless motors available that will give the needed power at an appropriate speed in direct drive. This will always be cheaper, more efficient, more compact, and quieter if you can make it work.
Part of judging this is knowing your prop size (which leads directly to the appropriate speed requirement, see the chart in the article below), and the battery voltage you prefer to run on.
If gears are wanted: read my article:
http://matthewsmodelmarine.wordpress...all-geared-up/
Note that it's old and some of the recommended gearboxes may be hard to find, or there may be newer choices. If you're running the common 500/600 brushed motor size, then the Master Airscrew box is great if you can find it...OOP, so maybe ebay.
patmat2350 is offline Find More Posts by patmat2350
Old Oct 31, 2013, 07:39 AM
Joined Oct 2013
Since I don’t build race boats, I have found in the past that gearing down most electric motors to a 2/1 ratio usually makes for a more realistic looking speed in work boats and most military ship models plus it increases motor power and reduces the prospect of over-heating and even conserves battery power. I haven’t found that the price of gear setups to be excessive. The problem usually is finding places where to buy them. Dumas orders in hobby shops seems to be the only option. I was just wondering if there were more places where they could be purchased?
Old Oct 31, 2013, 08:19 AM
mike_victoriaBC is offline
Find More Posts by mike_victoriaBC
victoria, bc
Joined Oct 2003
I use the Robbe units - both 3:1 and 5:1, not sure how available they are at present.
mike_victoriaBC is offline Find More Posts by mike_victoriaBC
Old Oct 31, 2013, 12:05 PM
linerfanatic is offline
Find More Posts by linerfanatic
linerfanatic's Avatar
Fort Wayne IN
Joined Aug 2007
gear box
With ten operational boats, I can only point to two that have any sort of gear reduction. One I would consider a success as it greatly extended my running time with no loss of performance. The other installtion may be a bit marginal. Run times are good, but the model lacks the speed and power to punch through choppy water. Props with more pitch might be used, but I have not found any with the correct diameter. So consider the need for gearing with some caution.
This is the gear reduction I used on a pair of 550 motors in one boat.
http://www3.towerhobbies.com/cgi-bin...&I=LXSL79&P=ML
I have another boat that has a pair of geared 400s I bought from this website.
http://www.maxxprod.com/mpi/mpi-10a.html
linerfanatic is offline Find More Posts by linerfanatic
Old Oct 31, 2013, 03:23 PM
Joined Oct 2013
One thing about gearing it’s pretty simple to undo a gear reduction at least for me as a scratch builder I always figure out how to make the entire main deck and super structure removable for easy access to running gear.
I know I can find gear reduction in my local hobby shop if I order it from the Dumas catalog. Looks like my only option.
Thanks guys!
Old Oct 31, 2013, 03:35 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Nooooo! Anything but that Dumas junk! As pointed to above, there's lots of much better hardware available...
Old Nov 01, 2013, 06:53 AM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
SCRATCH BUILDER- May I offer you an optional Motor-Gear Box selection which was stated by Pat in his article, the M.A.C.K. Products Model #2041 Motor-Gearbox Combo.
http://www.mackproductsrc.com/Power%20p2.htm
frankg is online now Find More Posts by frankg
Old Nov 05, 2013, 08:26 AM
Tollytime is offline
Find More Posts by Tollytime
Tollytime's Avatar
United States, MI, Macomb
Joined Nov 2006
Did you see this post?
http://www.rcgroups.com/forums/showthread.php?t=2028875
Tollytime is offline Find More Posts by Tollytime
Old Dec 04, 2013, 10:57 PM
Greg Hiltz is offline
Find More Posts by Greg Hiltz
Saint John, NB(East Coast) Canada
Joined Apr 2006
Robbe GearSets
I'm in New Brunswick, sub-dealer for Lowell Briggs Hobbies in NS, he and I both have Robbe Gear cases and different gear sets for these, in 3.3:1 and 5:1
Greg Hiltz is offline Find More Posts by Greg Hiltz
Old Dec 05, 2013, 05:31 AM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi SB,
I'm with Pat, if you don't need gearing down because the prop would be too large for the motor in question, don't.
If you use a motor like this:
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
running on 3S (11,1V) gives you about 3500rpm at full throttle.
The motor mentioned is just an example, as you didn't mention which boat(size) you want to power.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Dec 05, 2013, 09:33 PM
Joined Apr 2006
Motor options
Originally Posted by pompebled View Post
Hi SB,
Regards, Jan.
Then of course, there are also the nice Johnson 970 motors, which come in two versions, the single shaft which run very high RPM and draw big amperage, or the double-shaft, 5000 RPM, high torque, low amperage draw, which do work well direct drive for larger boats. I have also converted windshield wiper motors, a Mitsubishi one and a couple VW(Bosch) motors which have two sets of brushes, giving two speeds, 3300 and 5000 RPM, 12 pole fine windings, great bearings and drawing approx. 1.8amp
Old Dec 29, 2013, 07:45 AM
Joined Oct 2013
Hey thanks frank. I hadnít noticed or used M.A.C.K. products before. The gear reduction setups and prices look very interesting. Iíll have to add M.A.C.K. to my list of possible parts and materials list.
Thanks again!
Old Dec 30, 2013, 08:30 AM
Old Wood Boats is offline
Find More Posts by Old Wood Boats
Joined Jan 2013
Forget over priced hobby stuff, try the electronics market. as of this A M Electronics Goldmine has motors and gears and gear boxes..
Old Wood Boats is offline Find More Posts by Old Wood Boats
Old Dec 30, 2013, 08:50 AM
jmolwitz is offline
Find More Posts by jmolwitz
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
This has a few ratio's to choose from . Also they have a few others .
http://www3.towerhobbies.com/cgi-bin...?&I=LXSL79&P=0
jmolwitz is offline Find More Posts by jmolwitz
Sold Gear Reduction Drives (GWS, Eflite, etc) & Venom Motors lafuerza Aircraft - Electric - Power Systems (FS/W) 2 Mar 27, 2013 08:55 PM
Sold Gear Reduction Drives (GWS, Eflite, etc) & Venom Motors lafuerza Aircraft - Electric - Power Systems (FS/W) 1 Mar 26, 2013 09:38 AM
Question Prop Reductions/Gears AirplaneFreak100 Electric Motor Design and Construction 14 Mar 15, 2013 06:35 PM
Sold Himax HA2025-5300, 5300kv & GWS 6:6:1 gear reduction $22 richman03 Aircraft - Electric - Power Systems (FS/W) 3 Mar 07, 2013 06:00 PM
Sold Scale Boaters! Gear Reduction Motorized Dual Anchor Mechanisim $20.00 stevster Boats (FS/W) 2 Jan 19, 2013 12:11 AM
